GRL18-P2432
GRL18-P2432
    SICK
    SENSOR RETROREFLECTIVE 7.2M PNP
GRL18-P2432 数据手册
Product data sheet GRL18-P2432 GR18 CYLINDRICAL PHOTOELECTRIC SENSORS GRL18-P2432 | GR18 CYLINDRICAL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. GRL18-P2432 1066557 Other models and accessories www.sick.com/GR18 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric retro-reflective sensor, Dual lens Dimensions (W x H x D) 18 mm x 18 mm x 73.5 mm Housing design (light emission) Cylindrical Thread diameter (housing) M18 x 1 Optical axis Axial Sensing range max. 0.03 m ... 7.2 m 1) Sensing range 0.06 m ... 6 m 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 175 mm (7 m) Wave length 650 nm Adjustment Potentiometer Indication LED indicator green Operating indicator Static: power on LED indicator yellow Status of received light beam Static: object not present Static off: object present 1) 2) 2  Reflector PL80A.  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-06-25 16:20:56 Subject to change without notice GRL18-P2432 | GR18 CYLINDRICAL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple 49 °C, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected.  At Uv
GRL18-P2432
物料型号:GRL18-P2432
器件简介:GRL18-P2432 是由 SICK 生产的一款圆柱形光电传感器,采用双镜头光电反射式传感器原理。
引脚分配:1) + (L+),2) - (M),3) 不适用,4) Q
参数特性: - 供电电压:10 V DC ... 30 V DC - 纹波:<5 Vpp - 电流消耗:30 mA - 输出类型:PNP - 响应时间:<500 µs - 开关频率:1,000 Hz - 连接类型:4针 M12 公头连接器 - 保护等级:IP67
功能详解: - 检测原理:光电反射式 - 感应范围:最大 0.03 m 至 7.2 m - 光源:可见红光,650 nm 波长,PinPoint LED - 光斑大小:7 m 处直径约 175 mm - 调整方式:通过电位器调整 - 指示灯:绿色 LED 指示电源,黄色 LED 指示接收到的光束状态
应用信息: - 适用于需要检测物体存在或不存在的应用场景,例如工业自动化中的物体检测。
封装信息: - 外壳设计:圆柱形 - 螺纹直径:M18 x 1 - 材质:金属,镀镍黄铜和 ABS - 光学元件材质:PMMA 塑料
推荐配件包括安装支架、插头连接器和电缆等,更多型号和配件信息可访问 www.sick.com/GR18。
GRL18-P2432 价格&库存
很抱歉,暂时无法提供与“GRL18-P2432”相匹配的价格&库存,您可以联系我们找货
