GTE10-P4212
GTE10-P4212
    SICK
    SENSOR PROXIMITY 1.3M PNP
GTE10-P4212 数据手册
Online data sheet GTE10-P4212 G10 PHOTOELECTRIC SENSORS GTE10-P4212 | G10 PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. GTE10-P4212 1065867 Other models and accessories www.sick.com/G10 Illustration may differ Detailed technical data Features Sensor/detection principle Photoelectric proximity sensor, energetic Dimensions (W x H x D) 20 mm x 50 mm x 39 mm Housing design (light emission) Rectangular Sensing range max. 20 mm ... 1,300 mm 1) Sensing range 40 mm ... 950 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 28 mm (1,400 mm) Wave length 625 nm Adjustment Potentiometer, 270° 1) 2)  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ± 5 Vpp 2) Power consumption ≤ 20 mA 1) 2) 3) 4) 5) 6) 7) 8) 9) 2  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected.  Complies with the UL325 standard when used with sturdy protection hood (e.g. BEF-G10WSG, 2071960). PHOTOELECTRIC SENSORS | SICK Online data sheet | 2017-07-11 19:36:27 Subject to change without notice GTE10-P4212 | G10 PHOTOELECTRIC SENSORS Output type PNP Switching mode Light/dark switching Switching mode selector Selectable via light/dark selector Output current Imax. ≤ 100 mA Response time ≤ 500 µs 3) Switching frequency 1,000 Hz 4) Connection type Male connector M12, 4-pin Circuit protection A 5) B 6) C 7) D 8) Protection class III Weight 35 g Housing material Plastic, ABS/PMMA Enclosure rating IP67 Items supplied Mounting bracket BEF-G10DC01 EMC EN 60947-5-2 Ambient operating temperature –30 °C ... +60 °C Ambient storage temperature –40 °C ... +70 °C UL File No. E348498 More standards UL325 9) 1) 2) 3) 4) 5) 6) 7) 8) 9)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected.  Complies with the UL325 standard when used with sturdy protection hood (e.g. BEF-G10WSG, 2071960). Classifications ECl@ss 5.0 27270903 ECl@ss 5.1.4 27270903 ECl@ss 6.0 27270903 ECl@ss 6.2 27270903 ECl@ss 7.0 27270903 ECl@ss 8.0 27270903 ECl@ss 8.1 27270903 ECl@ss 9.0 27270903 ETIM 5.0 EC001821 ETIM 6.0 EC001821 UNSPSC 16.0901 39121528 2017-07-11 19:36:27 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 GTE10-P4212 | G10 PHOTOELECTRIC SENSORS A B C D E F Adjustments possible 7 6 ⑥  Adjustment of sensing range ⑦  Light/dark selector Connection diagram Cd-066 brn 1 wht 2 blu 3 H I J K L M N O P Q R S T blk 4 + (L+) not connected - (M) Q Characteristic curve GTE10, red light Operating reserve 100 GTE10-Xnn1n 10 3 2 1 1 0 300 600 900 1,200 1,500 (11.81) (23.62) (35.43) (47.24) (59.06) Distance in mm (inch) ①  Sensing range on white, 90% remission ②  Sensing range on gray, 18 % remission ③  Sensing range on black, 6% remission 4 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2017-07-11 19:36:27 Subject to change without notice GTE10-P4212 | G10 PHOTOELECTRIC SENSORS Light spot size GTE10, red light Diameter in mm (inch) Ø 15 Ø 19 Ø 28 (0.7) (1.1) Sensor (0.6) 0.1 0.5 (0.3) 1.4 (1.6) (4.6) Distance in m (feet) Sensing range diagram GTE10, red light 1 20/ 40 2 3 950 40/ 60 400 1,300 600 60/ 300 450 80 0 300 600 900 1,200 1,500 (11.81) (23.62) (35.43) (47.24) (59.06) Distance in mm (inch) Sensing range Sensing range max. Dimensional drawing (Dimensions in mm (inch)) GTE10, GL10, GL10G, DC, connector 0.5 (.02) 5 4 3 (.37) (.56) 3 19.7 (.78) 9.4 14.2 (.46) 1 11.6 2 38.8 (1.53) 34.7 (1.37) 50 (1.97) 36 (1.42) 20 (.79) M12/4pin 7.7 (.3) ①  Center of optical axis, sender ②  Center of optical axis, receiver ③  Mounting hole, Ø 4.2 mm ④  LED indicator yellow: Status of received light beam ⑤  LED indicator green: power on 2017-07-11 19:36:27 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 GTE10-P4212 | G10 PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Recommended accessories Other models and accessories www.sick.com/G10 Brief description Type Part no. BEF-KHS-ISG10 2073756 Q-Lock, bar clamp system for G10 and reflector P250, Die-cast zinc, steel, zinc coated BEF-KHSQ12R01 2071260 Bar clamp system for G10 and reflector P250, Die-cast zinc, steel, zinc coated, mounting hardware included BEF-KHSQ12R02 2087586 Q-Lock, bar clamp system for G10 and reflector P250, Die-cast zinc, steel, zinc coated, incl. slot-in sheet clamp BEF-KHSQ12ZR01 2071262 Mounting bar, straight, 200 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12G-A 4056054 Mounting bar, straight, 300 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12G-B 4056055 Mounting bar, L-shaped, 150 mm x 150 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12L-A 4056052 Mounting bar, L-shaped, 250 x 250 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12L-B 4056053 Mounting bar, Z-shaped, 150 mm x 70 mm x 150 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12Z-A 4056056 Mounting bar, Z-shaped, 150 mm x 70 mm x 250 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12Z-B 4056057 Bar clamp for bar diameter of 12 mm (fixing the mounting rod), Aluminum, 2 screws M6 x 30, 2 spring discs BEF-RMC-D12 5321878 Mounting bracket for wall and floor mounting for G10 DC, steel, zinc coated, mounting hardware included BEF-G10DC01 2071258 Mounting bracket for wall and floor mounting for G10 AC/DC, steel, zinc coated, mounting hardware included BEF-G10UC01 2071259 Head A: female connector, M12, 4-pin, straight Head B: cable Cable: PVC, unshielded, 2 m DOL-1204-G02M 6009382 Head A: female connector, M12, 4-pin, straight Head B: cable Cable: PVC, unshielded, 5 m DOL-1204-G05M 6009866 Head A: female connector, M12, 4-pin, angled Head B: cable Cable: PVC, unshielded, 2 m DOL-1204-W02M 6009383 Head A: female connector, M12, 4-pin, angled Head B: cable Cable: PVC, unshielded, 5 m DOL-1204-W05M 6009867 Universal bar clamp systems Clamp bar to fix G10 sensors on rods of 10 mm, clamp-on design up to 4 mm wall thickness, aluminum (clamp bar), stainless steel (bracket), clamp bar for 10 mm rod mounting and clamp function, mounting bracket, mounting hardware Mounting brackets and plates Plug connectors and cables 6 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2017-07-11 19:36:27 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
GTE10-P4212 价格&库存
很抱歉,暂时无法提供与“GTE10-P4212”相匹配的价格&库存,您可以联系我们找货
GTE10-P4212
    • 1+859.67267
    库存:6
