Online data sheet
GRTB18S-P2412
GR18S
PHOTOELECTRIC SENSORS
GRTB18S-P2412 | GR18S
A
B
C
D
E
F
Ordering information
Type
Part no.
GRTB18S-P2412
1076102
Other models and accessories
www.sick.com/GR18S
Illustration may differ
Detailed technical data
H
I
J
K
L
M
N
O
P
Q
R
S
T
Features
Sensor/detection principle
Photoelectric proximity sensor, Background suppression
Housing design (light emission)
Cylindrical, straight
Thread diameter (housing)
M18 x 1
Optical axis
Axial
Sensing range max.
3 mm ... 300 mm 1)
Sensing range
20 mm ... 150 mm 1)
Type of light
Visible red light
Light source
PinPoint LED 2)
Light spot size (distance)
Ø 7 mm (100 mm)
Wave length
650 nm
Adjustment
Potentiometer, 270°
1)
2)
Object with 90 % reflectance (referred to standard white, DIN 5033).
Average service life: 100,000 h at TU = +25 °C.
Mechanics/electronics
Supply voltage
10 V DC ... 30 V DC 1)
Ripple
± 5 Vpp 2)
Power consumption
≤ 30 mA
1)
2)
3)
4)
5)
6)
7)
8)
9)
2
Limit values when operated in short-circuit protected network: max. 8 A.
May not exceed or fall below Uv tolerances.
At Uv > 24 V or ambient temperature > 49 °C, IA max. = 50 mA.
Signal transit time with resistive load.
With light/dark ratio 1:1.
A = VS connections reverse-polarity protected.
B = inputs and output reverse-polarity protected.
D = outputs overcurrent and short-circuit protected.
At Uv
很抱歉,暂时无法提供与“GRTB18S-P2412”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+977.79682
- 5+958.23963
