CM18-08BPP-EC1
CM18-08BPP-EC1
    SICK
    Cylinder,Threaded-M18
    SENSOR PROX CAP 3MM-8MM CYLINDER
CM18-08BPP-EC1 数据手册
Online data sheet CM18-08BPP-EC1 CM CAPACITIVE PROXIMITY SENSORS CM18-08BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F Ordering information Type Part no. CM18-08BPP-EC1 6058145 Other models and accessories www.sick.com/CM Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Housing Cylindrical thread design Thread size M18 x 1 Diameter Ø 18 mm Sensing range Sn 3 mm ... 8 mm Safe sensing range Sa 6.12 mm 1) Installation type Flush Switching frequency 50 Hz Connection type Male connector M12, 4-pin Output type PNP Output function Complementary Output characteristic Wire configurable Electrical wiring DC 4-wire Adjustment Potentiometer (Sensitivity) Enclosure rating IP68, IP69K 2) Authorizations Ecolab, CE-conformity, cULus 3) 1) 2) 3)  For flush mounting in electrically conductive materials Sa = 0.8 x Sr at temperatures 60 °C.  1 m water depth / 60 min.  P3-topax 19, P3-topax 56, P3-topax 66, P3-topactive DES. Mechanics/electronics Supply voltage 1) 2) 3) 4) 5) 6) 2 10 V DC ... 36 V DC  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  +120 °C short time, at the front of the sensor. PROXIMITY SENSORS | SICK Online data sheet | 2017-05-05 09:40:14 Subject to change without notice CM18-08BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS Ripple ≤ 10 % 1) Voltage drop ≤ 2.5 V DC 2) Current consumption ≤ 12 mA 3) Time delay before availability ≤ 200 ms Hysteresis 3 % ... 20 % Reproducibility ≤ 5 % 4) 5) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 Continuous current Ia ≤ 200 mA Short-circuit protection ✔ Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance According to EN 60068 Ambient operating temperature –30 °C ... +85 °C 6) Ambient storage temperature –40 °C ... +85 °C Housing material Plastic, PBT Housing length 85 mm Thread length 55 mm Tightening torque, max. ≤ 2.6 Nm Items supplied Mounting nuts (plastic) UL File No. NRKH.E191603 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  +120 °C short time, at the front of the sensor. Reduction factors Note The values are reference values which may vary Metal 1 Water 1 PVC Approx. 0.4 Oil Approx. 0.25 Glass 0.6 Ceramics 0.5 Alcohol 0.7 Wood 0.2 ... 0.7 Installation note Remark Associated graphic see "Installation" B 18 mm C 18 mm 2017-05-05 09:40:14 | Online data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 3 CM18-08BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T D 24 mm Classifications ECl@ss 5.0 27270102 ECl@ss 5.1.4 27270102 ECl@ss 6.0 27270102 ECl@ss 6.2 27270102 ECl@ss 7.0 27270102 ECl@ss 8.0 27270102 ECl@ss 8.1 27270102 ECl@ss 9.0 27270102 ETIM 5.0 EC002715 ETIM 6.0 EC002715 UNSPSC 16.0901 39122230 Installation note Flush installation F B C D Connection diagram Cd-006 brn 1 blk 4 wht 2 blu 3 4 + (L+) NO NC - (M) PROXIMITY SENSORS | SICK Online data sheet | 2017-05-05 09:40:14 Subject to change without notice CM18-08BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS Characteristic curve CM18, Flush installation mm (inch) 20 (0.79) 10 (0.39) 0 –10 (–0.39) –20 (–0.79) 0 2 4 6 8 10 12 14 (0.08) (0.16) (0.24) (0.31) (0.39) (0.47) (0.55) Distance in mm (inch) Dimensional drawing (Dimensions in mm (inch)) CM18, flush, connector 85 (3.35) 70 (2.76) 2 1 3 M12 x 1 M18 x 1 x 55 LED 15 (0.59) ①  Sensitivity control ②  LED yellow: output active ③  LED green: operating indicator Recommended accessories Other models and accessories www.sick.com/CM Brief description Type Part no. BEF-KHS-N06 2051612 BEF-KHS-N06N 2051622 Mounting plate for M18 sensors, steel, zinc coated, without mounting hardware BEF-WG-M18 5321870 Mounting bracket for M18 sensors, steel, zinc coated, without mounting hardware BEF-WN-M18 5308446 Universal bar clamp systems Plate N06 for universal clamp bracket, M18, Zinc plated steel (sheet), Zinc die cast (clamping bracket), Universal clamp (5322626), mounting hardware Plate N06N for universal clamp bracket, M18, Stainless steel 1.4571 (sheet), Stainless steel 1.4408 (clamp), Universal clamp (5322626), mounting hardware Mounting brackets and plates 2017-05-05 09:40:14 | Online data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 CM18-08BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Brief description Type Part no. Clamping block for round sensors M18, without fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KH-M18 2051481 Clamping block for round sensors M18, with fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KHF-M18 2051482 Head A: female connector, M12, 4-pin, straight Head B: cable Cable: PVC, unshielded, 2 m DOL-1204-G02M 6009382 Head A: female connector, M12, 4-pin, straight Head B: cable Cable: drag chain use, PUR, halogen-free, unshielded, 2 m DOL-1204-G02MC 6025900 Head A: female connector, M12, 4-pin, straight Head B: cable Cable: PVC, unshielded, 5 m DOL-1204-G05M 6009866 Head A: female connector, M12, 4-pin, straight Head B: cable Cable: drag chain use, PUR, halogen-free, unshielded, 5 m DOL-1204-G05MC 6025901 Head A: female connector, M12, 4-pin, angled Head B: cable Cable: PVC, unshielded, 2 m DOL-1204-W02M 6009383 Head A: female connector, M12, 4-pin, angled Head B: cable Cable: drag chain use, PUR, halogen-free, unshielded, 2 m DOL-1204-W02MC 6025903 Head A: female connector, M12, 4-pin, angled Head B: cable Cable: PVC, unshielded, 5 m DOL-1204-W05M 6009867 Head A: female connector, M12, 4-pin, angled Head B: cable Cable: drag chain use, PUR, halogen-free, unshielded, 5 m DOL-1204-W05MC 6025904 Head A: female connector, M12, 4-pin, straight Head B: Cable: unshielded DOS-1204-G 6007302 Head A: female connector, M12, 4-pin, angled Head B: Cable: unshielded DOS-1204-W 6007303 Terminal and alignment brackets Plug connectors and cables 6 PROXIMITY SENSORS | SICK Online data sheet | 2017-05-05 09:40:14 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
CM18-08BPP-EC1 价格&库存
很抱歉,暂时无法提供与“CM18-08BPP-EC1”相匹配的价格&库存,您可以联系我们找货
