CM30-16BPP-EC1
CM30-16BPP-EC1
    SICK
    Cylinder,Threaded-M30
    SENSOR PROX CAP 3MM-16MM CYLIND
CM30-16BPP-EC1 数据手册
Product data sheet CM30-16BPP-EC1 CM CAPACITIVE PROXIMITY SENSORS CM30-16BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F Ordering information Type Part no. CM30-16BPP-EC1 6058153 Other models and accessories www.sick.com/CM Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Housing Cylindrical thread design Thread size M30 x 1.5 Diameter Ø 30 mm Sensing range Sn 0 mm ... 16 mm Safe sensing range Sa 12.24 mm 1) Installation type Flush Switching frequency 50 Hz Connection type Male connector M12, 4-pin Switching output PNP Output function Complementary Output characteristic Wire configurable Electrical wiring DC 4-wire Adjustment Potentiometer (Sensitivity) Enclosure rating IP67 1) 2) IP68 2) IP69K  For flush mounting in electrically conductive materials Sa = 0.8 x Sr at temperatures 60 °C.  1 m water depth / 60 min. Mechanics/electronics Supply voltage 1) 2) 3) 4) 5) 6) 2 10 V DC ... 36 V DC  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  +120 °C short time, at the front of the sensor. PROXIMITY SENSORS | SICK Product data sheet | 2022-03-30 15:03:31 Subject to change without notice CM30-16BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS Ripple ≤ 10 % 1) Voltage drop ≤ 2 V DC 2) Current consumption 12 mA 3) Time delay before availability ≤ 200 ms Hysteresis 3 % ... 20 % Reproducibility ≤ 5 % 4) 5) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 Continuous current Ia ≤ 200 mA Short-circuit protection ✔ Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance According to EN 60068 Ambient operating temperature –30 °C ... +85 °C 6) Ambient temperature, storage –40 °C ... +85 °C Housing material Plastic, PBT Housing length 74 mm Thread length 59.5 mm Tightening torque, max. ≤ 7.5 Nm Items supplied Mounting nut, PA12 plastic (2x) Screwdriver for potentiometer adjustment (1 x) UL File No. NRKH.E191603 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  +120 °C short time, at the front of the sensor. Safety-related parameters MTTFD 919 years DCavg 0 % TM (mission time) 20 years Reduction factors Note The values are reference values which may vary Metal 1 Water 1 PVC Approx. 0.4 Oil Approx. 0.25 Glass 0.6 Ceramics 0.5 Alcohol 0.7 Wood 0.2 ... 0.7 2022-03-30 15:03:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 3 CM30-16BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Installation note Remark Associated graphic see "Installation" B 30 mm C 30 mm D 48 mm F 48 mm Classifications ECl@ss 5.0 27270102 ECl@ss 5.1.4 27270102 ECl@ss 6.0 27270102 ECl@ss 6.2 27270102 ECl@ss 7.0 27270102 ECl@ss 8.0 27270102 ECl@ss 8.1 27270102 ECl@ss 9.0 27270102 ECl@ss 10.0 27270102 ECl@ss 11.0 27270102 ETIM 5.0 EC002715 ETIM 6.0 EC002715 ETIM 7.0 EC002715 ETIM 8.0 EC002715 UNSPSC 16.0901 39122230 Installation note Flush installation F B C D Shock and vibration resistance Shock (IEC 60068-2-27): 30 G / 11ms, 3 pos, 3 neg per axis Rough handling shocks (IEC 60068-2-31): 2 times from 1m, 100 times from 0,5m Vibration (IEC 60068-2-6): 10 to 150 Hz, 1 mm / 15 G 4 PROXIMITY SENSORS | SICK Product data sheet | 2022-03-30 15:03:31 Subject to change without notice CM30-16BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS Electromagnetic compatibility (EMC) Electrostatic discharge (EN61000-4-2): Contact discharge > 40 kV Air discharge > 40 kV Electrical fast transients/burst (EN 61000-4-4): +/- 4 kV Surge (EN 61000-4-5): Power supply > 2 kV (with 500 Ohm) Sensor output > 2 kV (with 500 Ohm) Wire conducted disturbances (EN 61000-4-6): > 20 Vrms Power-frequency magnetic fields (EN 61000-4-8): Continous > 60 A/m, 75.9 µ tesla Short-time > 600 A/m, 759 µ tesla Radiated RF electromagnetic fields (EN 61000-4-3): > 20 V/m Connection diagram Cd-006 BN 1 BK 4 WH 2 BU 3 + (L+) NO NC - (M) Characteristic curve CM30, Flush installation mm (inch) 20 (0.79) 10 (0.39) 0 –10 (–0.39) –20 (–0.79) 0 5 (0.2) 10 15 20 25 30 (0.39) (0.59) (0.79) (0.98) (1.18) Distance in mm (inch) 2022-03-30 15:03:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 CM30-16BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS Dimensional drawing (Dimensions in mm (inch)) CM30, flush, connector 74 (2.91) 61 (2.4) 1 2 M30 x 1.5 x 59.5 3 LED M12 x 1 A B C D E F ①  Sensitivity control ②  LED yellow: status indicator ③  LED green: operating indicator Recommended accessories Other models and accessories H I J K L M N O P Q R S T www.sick.com/CM Brief description Type Part no. Mounting plate for M30 sensors, steel, zinc coated, without mounting hardware BEF-WG-M30 5321871 Mounting bracket for M30 sensors, steel, zinc coated, without mounting hardware BEF-WN-M30 5308445 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m YF2A14020UB3XLEAX 2095607 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 2 m YF2A14020VB3XLEAX 2096234 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m YF2A14050UB3XLEAX 2095608 Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m YF2A14050VB3XLEAX 2096235 Head A: female connector, M12, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m YG2A14020UB3XLEAX 2095766 Head A: female connector, M12, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 2 m YG2A14020VB3XLEAX 2095895 Head A: female connector, M12, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m YG2A14050UB3XLEAX 2095767 Mounting brackets and plates Plug connectors and cables 6 PROXIMITY SENSORS | SICK Product data sheet | 2022-03-30 15:03:31 Subject to change without notice CM30-16BPP-EC1 | CM CAPACITIVE PROXIMITY SENSORS Brief description Type Part no. YG2A14050VB3XLEAX 2095897 Head A: female connector, M12, 4-pin, straight Head B: Cable: unshielded DOS-1204-G 6007302 Head A: female connector, M12, 4-pin, angled Head B: Cable: unshielded DOS-1204-W 6007303 Head A: female connector, M12, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m 2022-03-30 15:03:31 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
CM30-16BPP-EC1 价格&库存
很抱歉,暂时无法提供与“CM30-16BPP-EC1”相匹配的价格&库存,您可以联系我们找货
