H3-B1-1B05W2-2-300
H3-B1-1B05W2-2-300
    KINGHOR(微控物联)
    H3-B1-1B05W2-2-300
H3-B1-1B05W2-2-300 数据手册
Page:1/5 KINGHOR SWITCH PRODUCT SPECIFICATION 文件编号 FILE NO. H3-B1-1B05W2-2-300 产品编码 PART NO. H3-B1-1B05W2-2-300 产品描述 Product Name Micro Switch 产品规格书 文件版次 EDITION 1 General Characteristics 一般特性: 1.1 Application: This specification is applied to the micro switch (H3) for general applications. A1 适用范围:该承认书指微动开关(H3)的一般使用范围。 1.2 Operating Temperature Range: -25℃to +85℃ -25℃to +85℃ 使用温度范围: Preservative Temperature Range: -25℃to +85℃ 保存温度范围: 1.3 Operating Relative Humidity: ≤85%RH ≤85%RH 相对湿度: 1.4 -25℃to +85℃ Test Conditions: Unless otherwise specified, the atmospheric conditions for making measurements and tests are as follows: 实验条件:若没有特别说明,则试验大气条件如下: Ambient Temperature: 5~35℃ 5~35℃ 环境温度: Relative Humidity: 45~85% 45~85% 相对湿度: Air Pressure: 86~106Kpa (860~1060mbar) 86~106Kpa (860~1060mbar) 大气压力: 2. Appearance, Structure and Dimensions 外观,结构及尺寸: 2.1 Appearance: 外观: 2.2 产品外观良好,无锈蚀、裂纹和镀层缺陷。 Structure & Dimensions: Refer to individual product drawing. 结构及尺寸: 2.3 The switch shall have good finishing, and no rust, crack or plating defects. Markings: 标识: 参见产品图纸 Refer to individual product drawing. 参见产品图纸。 CERTIFICATION 3. Ratings 额定负荷 4. Electrical Characteristics No. Item 项目 RATING LIFE CYCLES 0.1A 125/250VAC;3A 12VDC 0.1A 48VDC u 25T85 100,000 FILE NO. 电气特性 Criteria 标准 Test Method 实验方法 Insulation Resistance 100 MΩ min. 100VDC voltage is applied between each pair of terminals and between the terminal and the metal frame for 60±5S. 绝缘电阻 100 MΩ min. 在相互绝缘的所有端子之间及各接线端子与外露的非载流金属 零件之间加载100V直流电,持续时间60±5S。 4.1 Page:2/5 KINGHOR SWITCH 文件编号 FILE NO. H3-B1-1B05W2-2-300 产品编码 PART NO. H3-B1-1B05W2-2-300 产品描述 Product Name Micro Switch 文件版次 EDITION A1 1000VAC (50~60Hz,cut –off current 10mA) is applied No dielectric breakdown shall between non-connected terminals and 1000VAC between occur. terminals and the metal frame for 60 ±5s. 抗电强度 无击穿现象发生。 5. Mechanical Characteristics Item 项目 在相互绝缘的所有接线端子之间1000V(50-60Hz)交流电,各 接线端子与外壳或非载流金属零件之间加载1000V(50-60Hz) 交流电,持续时间60±5S。 机械特性 Criteria 标准 Test Method 实验方法 Operating Force See product drawing Apply a tension load on the midpoint of the actuator (or 1mm to the tip of the shaft) to supply a pressure vertically from its free position to operating position. 操作力 参见产品图纸 在操作元件中间(或在离操作元件末端1mm处)沿操作方向均匀 施加静载荷,使操作元件转换到动作位置。 Releasing Force See product drawing A static load shall be reduced to the tip of actuator in operating direction to change component from operating position to release position. 回复力 参见产品图纸 在操作元件末端沿操作方向均刀减少静载荷,使操作元件从动 作位置转换到释放位置。 5.1 5.2 Free position See product drawing The position where the actuator lead the Displacements when its out of force or the force is not enough to drive the actuator. 自由位置 参见产品图纸 驱动件在不承受操作力以及不足以引起位移时所处的位置 Operating Position 操作位置 See product drawing The distance from the end of operating component to the center of mount hole when switch is being transformed 参见产品图纸 开关发生转换时,操作元件末端到开关安装孔中心的距离 5.3 5.4 产品规格书 Dielectric Voltage 4.2 No. PRODUCT SPECIFICATION Pre Travels See product drawing 5.5 The distance vertically through, which the midpoint of the actuator (or tip of the shaft) trip move from its free position to operating position. 行程 参见产品图纸 从自由位置到动作位置的距离。 Differential Travel See product drawing The distance from operating position to release position 差程 参见产品图纸 从动作位置到释放位置的距离。 See product drawing The displacements of actuator form operation to travel position. 参见产品图纸 驱动件从动作位置到全行程位置间的位移 . 5.6 Over travel 5.7 超行程 total Page:3/5 KINGHOR SWITCH PRODUCT SPECIFICATION 文件编号 FILE NO. H3-B1-1B05W2-2-300 产品编码 PART NO. H3-B1-1B05W2-2-300 产品描述 Product Name Micro Switch 产品规格书 文件版次 EDITION A1 6. Durability characteristics No. Item 项目 Criteria 标准 Test Method 实验方法 Mechanical Life After test, Insulation resistance:50MΩ min. The electrical performance requirements specified in 500,000 cycles of operation shall be performed item 4.2 shall be satisfied. continuously at a rate of 60 cycles per minute without The switch shall be free from load. abnormalities in appearance construction. Operating force: within ±30% initialization value. 机械寿命 实验后: 绝缘电阻:50MΩ min. 电气性能应符合第4.2条的要求。 开关外观及结构应无损坏。 操作力变化为初始值的 ±30%。 Operating Life with Load After test, Insulation resistance:10MΩ min. The electrical performance requirements specified in item 4.2 shall be satisfied. The switch shall be free from abnormalities in appearance construction. Operating force: within ±30% initialization value. IEC61058-1:100,000 cycles of oper a shall be performed continuously at a rate of 30 cycles per minute with load as follow: Refer to individual product drawing (Resistive Load) 负荷寿命 实验后: 绝缘电阻:10MΩ min. 电气性能应符合第4.2条的要求。 开关外观及结构应无损坏。 操作力变化为初始值的 ±30%。 IEC61058-1:在产品图纸标示负荷的下,在寿命试验设备上连 续转换100,000次,30次/分。 6.1 6.2 7. Weather Proof Characteristics 在不带负荷的条件下,速度为60次/分,在寿命试验设备上连 续转换500,000次。 耐候性能: Cold Proof After testing at –25 ± 2°C for 96 hours, the switch shall be allowed to stand under normal temperature and humidity conditions for 1 hour, and measurement shall be made within 1 hour after that. Water drops shall be eliminated. 低温 试件在-25±2℃的温控箱内保持96小时,然后在正常温度和湿 度下恢复1小时,并在此后1小时内对试品进行测量,水滴应消 失。 7.1 Page:4/5 KINGHOR SWITCH PRODUCT SPECIFICATION 文件编号 FILE NO. H3-B1-1B05W2-2-300 产品编码 PART NO. H3-B1-1B05W2-2-300 产品描述 Product Name Micro Switch 产品规格书 文件版次 EDITION Hot Proof After testing at 85± 2°C for 96 hours, the switch shall be allowed to stand under normal temperature and humidity conditions for 1 hour, and measurement shall be made within 1 hour after that. 高温 试件在85±2℃的温控箱内保持96小时,然后在正常温度和湿 度下恢复1小时,并在此后1小时内对试品进行测量,水滴应消 失。 7.2 After test,Insulation resistance:50MΩ Min. Moisture Resistance 7.3 After testing at 60± 2°C ,90~95% RH for 96 hours, The Electrical performance the switch shall be allowed to stand under normal requirements specified in temperature and humidity conditions for 1 hour, and item 4.2 shall be satisfied.The switch shall be measurement shall be made within 1 hour after that. Water drops shall be eliminated. free from abnormalities in appearance &construction. 实验后: 绝缘电阻: 50MΩ Min. 电气性能应符合第4.2条的要求。 开关外观及结构应无损坏。 恒定湿热 试件在60±2℃,90-95%RH的温控箱内保持96小时,然后在正 常温度和湿度下恢复1小时,并在此后1小时内对试品进行测 量,水滴应消失。 After 4 cycles of following conditions, the switch can stay under normal temperature and humidity conditions for 2 hours, and measurement shall be made within 1 hour after that. Water drops shall be eliminated. Temperature Cycling 试件按下述实验条件试验 4个循环,然后在正常温度 和湿度 下恢复 2小时,并在此后 1小时内对试品进行测量,水滴应消 失。 7.4 +85℃ 温度转换 -25℃ 8. Material List 图 No. 序号 A1 材料清单 零部件名称 Parts Name 材料,规格 Material and Specifications 数量 Quantity 1 外壳 Cover 1 PA 2 防水壳 Base 1 PA 3 按钮 Actuating button 1 POM 4 密封圈 Sealed Circle 1 Silicone Rubber 5 COM端子 COM Terminal 1 Cu Alloy 防火等级 Prevent fire grade 备注 Remarks Ag PLATED Page:5/5 KINGHOR SWITCH PRODUCT SPECIFICATION 文件编号 FILE NO. H3-B1-1B05W2-2-300 产品编码 PART NO. H3-B1-1B05W2-2-300 产品描述 Product Name Micro Switch 6 弹簧 Spring 1 SWP 7 动片 Moving Blade 1 Cu Alloy 8 动片触点 MB Contact 1 Ag Alloy 9 NO 端子 1 Cu Alloy 10 NO 端子触点 1 Ag Alloy 11 NC 端子 1 Cu Alloy 12 手柄 Handle 1 SUS 13 电线 Electric Wire 2 UL1007-22AWG 14 密封胶水 Sealed Glue 0.01g Silicone Rubber 15 防水壳胶水 Waterproof Shell Glue 0.5g Epoxy Resin NO Terminal NO Contact NC Terminal 文件版次 EDITION :Operating Force :Release Force :Release Position :Over Travel OP : TTP: FP : DT : Operating Position Total Travel Position Free Position Differential Travel A1 Ag PLATED Ag PLATED Cut the terminal 9. Operating data diagram 操作参数示意图 OF RF RP OT 产品规格书 TT :Total Travel TF :Total travel Force PT :Pre Travel REV DRAFTED.BY DESCRIPTION MARK DATE H 18.50±0.1 G Circuit Diagram F UL1007-22AWG BLACK 5.40±0.1 2 1 3.40 3 PT UL1007-22AWG BLUE 16.25 COM NO 2.50 ELECTRICAL DATA E OPERATING LIFE 100,000 CYCLES 0.1A 48VDC 125/250VAC 100,000 CYCLES OP FP RATING 3A 12VDC 12.00±0.1 13.10±0.1 3.15 6.30 1.40 3 1 2* ∅3 .3 0 2 ∅2 .9 5 MECHANICAL LIFE GAP TYPE OPERATING TEMP WATERPROOF CHARACTERISITICS OPERATING FORCE(OF): RELEASE FORCE(RF): OPERATING POSITION: C 2*5±1 14.70±0.1 2*300±10 PRE TRAVEL: DIFFERENTIAL TRAVEL: FREE POSITION: B OUTLINE DRAWING 1 2 3 4 5 6 TITLE H3 SERIES MICRO SWITCH MODEL H3-B1 PART NO. DRAFTED BY CHECKED BY APPROVED BY H3-B1-1B05W2-2-300 Bing Wang DATE 2021-9-8 DATE 2021-9-8 Hua Bai Hong Chen DATE 2021-9-8 7 8 500,000 CYCLES MICRO -25℃~+85℃ IP67 200g Ma . 25g Min. 10.50±0.7 mm. 3.00mm Ma . 0.70mm Ma . 13.50mm Ma . TOLERANCE UNLESS OTHERWISE SPECIFIED ≤3 1~3 3~10 10~30 30~100 100~200 ANGLE ±0.2 ±0.3 ±0.4 ±0.6 ±1.0 ±1.5 ±3.0° SCALE UNIT VERSION REV mm A1 KINGHOR 9 10
H3-B1-1B05W2-2-300 价格&库存
很抱歉,暂时无法提供与“H3-B1-1B05W2-2-300”相匹配的价格&库存,您可以联系我们找货
