HD160M331LO18*36TH-2A1E
    BERYL(绿宝石)
    插件,18x36mm
    330UF ±20% 160V
HD160M331LO18*36TH-2A1E 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS HD Series ● High ripple current ,long life,down sized ● Endurance:8000 to 10,000 hours at 105℃ ● RoHS2.0 Compliant ◆ 规格表 Specifications 特性参数Characteristics 项目Items 使用温度范围 ﹣40 ~ +105℃(160~ 400V.DC) Category ﹣25 ~ +105℃(450~ 500V.DC) Temperture Range 额定工作电压范围 Rated Voltage Range 静电容量允许偏差 160 ~ 500V.DC ±20%(M) Capacitance Tolerance (at 20℃,120Hz) I≤0.02CV+10(μA) (施加额定工作电压2分钟后) (After 2 minute application of rated voltage ) 漏电流 Leakage Current Note: I=Max.leakage current (μA), C=Nominal capacitance(μF), V=Rated voltage(V) 160 ~ 250 350 ~ 500 0.20 0.24 (at 20℃) 损耗角正切值tanδ Rated voltage(V) Dissipation Factor tanδ (Max.) 低温特性 阻抗比值不得超过下表中列出的值 The impedance ratio shall not exceed the values listed in the below table. Low Temperature Rated voltage(V) 160 ~ 250 350 ~ 400 450 ~ 500 Characteristics Z(-25℃)/Z(+20℃) 3 5 6 (Max.Impedance Ratio) Z(-40℃)/Z(+20℃) 6 6 - (at 20℃, 120Hz) (at 120Hz) 在105℃环境中,不超过额定电压的范围内叠加最大允许纹波电流,连续加载右表时间,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple Current is applied for the specified period of time at 105℃ Load life 耐久性 Endurance Capacitance change D.F.(tanδ) Leakage current ≦±20% of the initial value ≦200% of the initial specified value ≦The initial specified value 160 ~ 450V.dc ≤20L : 8,000 ≥25L : 10,000 500V.dc ≤Φ10 : 8,000 ≥Φ13 : 10,000 在105℃环境中,不施加电压条件下储存1000小时,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored at 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. 高温储存特性 Shelf Life Capacitance change D.F.(tanδ) Leakage current ≦±20% of the initial value ≦200% of the initial specified value ≦500% of the initial specified value ◆ 尺寸图(单位:mm)DIMENSIONS (Unit:mm) L± α. Safety Vent (Φ8up) 15min. 5min. F±0.5 Vinyl sleeve Rubber end seal Φd±0.05 Tinned copper-ply wire ΦD 10 13 16 18 20 F 5.0 5.0 7.5 7.5 10 Φd 0.6 0.6 0.8 0.8 0.8 D±0.5 α (L
HD160M331LO18*36TH-2A1E 价格&库存
很抱歉,暂时无法提供与“HD160M331LO18*36TH-2A1E”相匹配的价格&库存,您可以联系我们找货
