电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
HDR-EC26LFDTG2-SLG+
HDR-EC26LFDTG2-SLG+
    HONDA
    HDR-EC26LFDTG2-SLG+
HDR-EC26LFDTG2-SLG+ 数据手册
0.8 HDR series mm Pitch Interface Connectors Connectors Outline Features Principal Applications HDR series connectors are very small surface mount (SMT) interface connectors with their contacts arranged at a pitch of 0.8 mm, designed for the purpose of saving extra space on printed circuit boards. • Long-life design allowing up to 5,000 mating cycles • Low profile with overall height of 5mm from the PCB surface • Sequential structure allowing up to two stacked connections • One-touch-lock-type and detachable / re-attachable housing • EMI/ESD-shielded and over-molded type metal housing • IDC type connector on the cable end allows simultaneous termination Portable information terminals, smaller-sized office automation equipment, and their peripherals Rated voltage Electrical Characteristics 125V AC (r.m.s.) Rated current Insulation resistance 0.5 A Over 1000 megohms at 250V DC Dielectric withstanding voltage Contact resistance 350V AC (r.m.s.) 70 milliohms or less Document Disclaimer When placing orders with us, minimum order quantities are set for every product. Be sure to contact us before starting preliminary design of PCBs using our connectors. The specifications and information shown in the catalog are subject to change without notice. Reflow temperature profile (for reference purposes) Flow temperature profile (for reference purposes) 5sec (Peak) 250˚C 260±5˚C 220˚C (Full heating period) 30~60sec 150~180˚C 100~130˚C 30~60sec (Preheating period) 90~120sec The reflow temperature profile shown in this drawing is for reference purposes. This profile depends on requirements such as reflow equipment, soldering paste, and PCB size. Thus, this profile may not meet with your specific situation. Please evaluate your PCB-mounting soldering and set your own reflow temperature profile. The flow temperature profile as shown above is for reference purposes. This profile depends on requirements such as the PCB size. Thus, this profile may not meet with your specific situation. Please evaluate your PCB-mounting soldering and set your own flow temperature profile. ΩApplicable products HDR-EA( )LMYPG1-( )( )+ HDR-EA( )LFYPG1-( )( )+ ΩApplicable products HDR-EC( )FDT( )-( )+ HDR-EC( )LFDT( )-( )+ The profile shown in this drawing is applicable only for those products shown above. The profile shown in this drawing is applicable only for those products shown above. Product List IDC type male connector for cable HDR-E( )MAG1+ Soldering type male connector for cable HDR-E( )MSG1+ Straddle SMT type male connector for PCB HDR-E50MT( )+ Right-angle SMT type male connector for PCB HDR-EA( )LMYPG1-( )( )+ A-6HDR HDR series...4 A-7HDR HDR series...5 A-8HDR HDR series...6 A-9HDR HDR series...7 IDC type female connector for cable HDR-E( )FAG1+ Right-angle SMT type female connector for PCB HDR-EA( )LFYPG1-( )( )+ Straight through hole type female connector for PCB HDR-EC( )FDT( )-( )+ Right-angle through hole type female connector for PCB HDR-EC( )LFDT( )-( )+ A-10HDR HDR series...8 A-11HDR HDR series...9 A-12HDR HDR series...10 A-13HDR HDR series...11 EMI-filtered vertical plastic housing for standard and thin cable HDR-E( )LP( )( )-( ) A-14HDR HDR series...12 EMI-filtered screw-lock vertical type plastic housing HDR-E26LPH A-15HDR HDR series...13 0.8mm pitch connector For cable IDC type male connector for cable HDR- E( )MAG1+ IDC EMI shielded ● Configuration of product Part No. HDR- E ( ) M A G1+ ➀ ➁ ➂ ➃ ➄ ➅ ➀ Series name ➁ E: With metal shell ➂ No. of contacts: 14, 26 or 50 ➃ Type of contact M: IDC type, Male ➄ Compatible cable A: AWG#30 (7/0.1), dia. 0.58mm ➅ Contact plating G1: 0.76μm or more Gold plate A B POS.#1 0.8 3.7 5.4 ➀ LAST POS. C 14 contacts ➂ ➁ 6.7 14 14.9 8 15˚ 26 50 14 contacts B 14 26 ➃ 26 contacts B ➄ ● Components ● Dimensions ➀ Contacts ➁ Shell ➂ Insulator Part No. HDR-E14MAG1+ A 10.8 ➃ Spacer HDR-E26MAG1+ ➄ Cable housing HDR-E50MAG1+ Mating connector: HDR series SMT type or through hole type female connector For use with housings: HDR series upright housing Required tools: Termination tool: FHAT-0029, IDC tool: FHPT-923B, Hand presser: MFC-K1 (Refer to page Tool-10) Through hole SMT Press-in IDC Wire Soldering Crimping wrapping Others B 0.8≈6=4.8 C 9.0 15.6 0.8≈12=9.6 13.8 25.2 0.8≈24=19.2 23.4 0.8mm pitch connector For cable Soldering type male connector for cable HDR-E( )MSG1+ Soldering EMI shielded ● Configuration of product Part No. HDR- E ( ) M S G1+ ➀ ➁ ➂ ➃ ➄ ➅ ➀ Series name ➁ E: With metal shell ➂ No. of contacts: 26 or 50 ➃ Male ➄ Soldering ➅ Contact plating G1: 0.76μm or more Gold plate C 0.8 POS.#1 1 6.7±0.15 13 16.2±0.5 POS.#n/2 A C POS.#1 0.8 5.4±0.3 POS.#n/2 POS.#n 15 ˚ POS.#n/2+1 B 14 POS.#n/2+1 26 POS.#n 0.8 C 26-contact connector ● Dimensions HDR-E26MSG1+ Part No. A 15.6 B 13.8 C 0.8≈12=9.6 HDR-E50MSG1+ 25.2 23.4 0.8≈24=19.2 Mating connector: HDR series female connector For use with housings: HDR-E( )LPH Others Wire wrapping Crimping Soldering IDC Press-in SMT Through hole 0.8 mm pitch connector For PCB Straddle SMT type male connector for PCB HDR-E50MT( )+ Straddle SMT ● Configuration of product Part No. HDR- E 50 MT ( )+ ➀ ➁ ➂ ➃ ➀ Series name ➁ No. of contacts: 50 ➂ Type of contact MT: Straddle SMT type, male ➃ PCB thickness Blank: 0.4 mm A : 0.8 mm 0.8≈24=19.2 0.8 ➀ POS.#1 POS.#25 25 14.9 ➁ 1 6.7 ➂ 25.2 0.8≈24=19.2 POS.#1 POS.#25 5.4 0.8 POS.#26 23.4 POS.#50 POS.#1 ➀ Contacts ➁ Insulator ➂ Shell 3.5±0.05 2-C 0.1 0.45±0.03 0.8±0.05 0.8≈24=19.2±0.1 –0.1 22.6≠0.05 3.5±0.05 2 C0 . 2- ● Components POS.#26 0.45±0.03 0.8±0.05 0.8≈24=19.2±0.1 Prohibited area for mounting parts Recommended PCB layout Mating connector: HDR series SMT type female connector SMT POS.#50 POS.#50 POS.#26 Through hole POS.#25 5.5±0.1 50 5.5±0.1 26 15˚ Press-in IDC Wire Soldering Crimping wrapping Others 0.8mm pitch connector For PCB Right-angle SMT type male connector for PCB HDR-EA( )LMYPG1- ( )( )+ Right-angle SMT ● Configuration of product Part No. HDR- EA ( ) LMY P G1- ( ) ( )+ ➀ ➁ ➂ ➃ ➄ ➀ Series name ➁ Contact pitch: 0.635 mm ➂ No. of contacts: 14 or 26 ➃ Type of contact LMY: Right-angle SMT type, male ➄ Contact plating G1: 0.76 μm or more Gold plate ➅ ➆ ➅ Lock screw Blank : None SL : Provided ➆ Length of lock screw E: 6.6 (standard) K: 3.3 (for HDR-E ( ) LPA-LS) Compatible with B-to-B and B-to-C ➀ ➃ 5 1.7 ➄ ➆ ➁ ➇ A B C 0.8 POS.#n/2 ➂ POS.#n/2≠1 D 15˚ ø1.1 ø1.7 POS.#n 0.8 5 3.7 2.5 POS.#1 ➀ Insulator A ➁ Shell POS.#n/2≠1 0.635±0.03 POS.#n/2 POS.#n ➅ 0.635 F B POS.#n 0.2~0.25 E±0.1 B±0.1 G±0.1 2-ø1.8±0.1 3±0.15 POS.#n/2 2.5±0.1 2-ø2.3±0.05 6±0.15 6.6 0.335 ±0.03 7.2±0.1 3 10.7 REF. POS.#1 F±0.05 POS.#n/2+1 POS.#1 ≠0 4–0.15 ● Components 1.6 17.4 6.7 E 3±0.15 Recommended PCB layout ➂ Contacts : PAD ➃ Insulator B ● Dimensions ➄ Square nuts ➅ Hold down ➆ Hex nuts A Part No. HDR-EA14LMYPG1-( )( )+ 20.0 B 14.4 C 4.8 D 9 E 9.2 ➇ Lock screw HDR-EA26LMYPG1-( )( )+ 24.8 19.2 9.6 13.8 14 F 8.255 G 19.0 15.875 23.8 Mating connector: HDR series IDC type or solder type female cable connector For use with housing: -SLE: HDR series vertical housing -SLK: HDR series vertical housing -LS, -LSA Others Wire wrapping Crimping Soldering IDC Press-in SMT Through hole 0.8mm pitch connector For cable IDC type female connector for cable HDR-E( )FAG1+ IDC EMI shielded ● Configuration of product Part No. HDR- E ( )F A G1+ ➀ ➁ ➂ ➃ ➄ ➅ ➀ Series name ➁ E: With metal shell ➂ No. of contacts: 14 or 26 ➃ Type of contact F: IDC type, female ➄ Compatible cable A: AWG#30 (7/0.1), dia. 0.58 mm ➅ Contact plating G1: 0.76 μm or more Gold plate A B 0.8 POS.#1 5.4 POS.#n/2 POS.#n 15˚ POS.#n/2+1 3.5 14.2 6 C ➂ 14 8 ➀ ➁ ➃ ➄ ● Components ➀ Contacts ● Dimensions ➁ Insulator ➂ Shell Part No. ➃ Spacer HDR-E14FAG1+ A 10.8 B 4.8 C 8.8 ➄ Cable housing HDR-E26FAG1+ 15.6 9.6 13.6 Mating connector: HDR series SMT type male connector For use with housings: HDR series vertical housing Required tools: Termination tool: FHAT-0029, IDC tool: FHPT-923B, Hand presser: MFC-K1 (Refer to page Tool-10) Through hole SMT Press-in IDC Wire Soldering Crimping wrapping Others 0.8mm pitch connector For PCB Right-angle SMT type female connector for PCB HDR-EA( )LFYPG1-( )( )+ Right-angle SMT ● Configuration of product Part No. HDR- EA ( ) LFY P G1- ( ) ( )+ ➀ ➁ ➂ ➃ ➄ ➀ Series name ➁ Contact pitch: 0.635 mm ➂ No. of contacts: 14 or 26 ➃ Type of contact LFY: Right-angle SMT type, female ➄ Contact plating G1: 0.76 μm or more Gold plate ➀ ➃ 5 1.7 ➅ ➆ ➅ Lock screw Blank : None SL : Provided ➆ Length of lock screw E: 6.6 (standard) K: 3.3 (for HDR-E ( ) LPA-LS) Compatible with B-to-B and B-to-C ➆ ➁ ➇ A B C 0.8 ø1.1 ø1.7 F 0.635 F B ±0.15 6 ➅ POS.#1 0.2~0.25 E±0.1 B±0.1 G±0.1 2-ø1.8±0.1 3±0.15 POS.#n/2+1 ➁ Shell 7.2±0.1 2-ø2.3±0.05 6.6 10.7 REF. POS.#n/2 0.635 ±0.03 POS.#n/2+1 POS.#1 0.335 4 1.6 16.7 ➀ Insulator A POS.#n ±0.05 ±0.05 2.5 ±0.1 POS.#n/2+1 POS.#n/2 POS.#n ● Components 0.8 15˚ ≠0 –0.15 D 6 POS.#n 3.5 ➂ 2.5 POS.#1 5 POS.#n/2 ➄ 3 ±0.15 : PAD Recommended PCB layout ➂ Contacts ➃ Insulator B ➄ Square nuts ● Dimensions ➅ Hold down ➆ Hex nuts Part No. HDR-EA14LFYPG1-( )( )+ A 20.0 B 14.4 C 4.8 D 8.8 E 9.2 F 8.255 G 19.0 ➇ Lock screw HDR-EA26LFYPG1-( )( )+ 24.8 19.2 9.6 13.6 14 15.875 23.8 Mating connector: HDR series IDC or solder type male cable connector For use with housing: -SLE: HDR series vertical housing -SLK: HDR series vertical housing -LS, -LSA Others Wire wrapping Crimping Soldering IDC Press-in SMT Through hole 0.8mm pitch connector For PCB Straight through hole type female connector for PCB HDR-EC( )FDT( )-( )+ Straight Through hole EMI shielded ● Configuration of product Part No. HDR- EC ( ) FD T ( )- ( )+ ➀ ➁ ➂ ➃ ➄ ➅ ➀ Series name ➅ Lock screw ➁ No. of contacts: 14 or 26 Blank: None ➂ Type of contact SL : Provided FD: Straight through hole type, female (Panel thickness: 1.12 mm) ➃ With ground contact ➄ Contact plating G2: Min. 0.76 μm Gold plate ∞ £ 6 14 15˚ X+0.2 0 2.2±0.1 R1.1 ● Components M2≈0.4 1.12 Recommended PCB layout 1.3 R0.5 POS.#1 D±0.05 0.775±0.03 7.5±0.3 1 26 POS.#2 2-ø1.75±0.08 POS.#n ø1±0.05 0.8±0.03 (PAD) 2.3 5.2±0.1 5 ±0.3 13 ¢ (PAD) 2-ø2MAX. 2-ø1.2±0.05 1.55 2.975 ±0.15 11.5±0.3 ¡ A±0.2 F C 0.8≈(n/2-1)= B 0.8 ø0.65±0.05 POS.#1 POS.#2 2.975±0.03 1.96±0.03 1.15±0.03 1.15±0.03 0.98±0.03 ™ 0.8 POS.#n E±0.05 B±0.05 2.125±0.03 E D B Y±0.1 Recommended panel cut-out dimensions ➀ Insulator ➁ Contacts ● Dimensions ➂ Shell ➃ Lock screws Part No. HDR-EC14FDT( )-( )+ ➄ Board lock pin HDR-EC26FDT( )-( )+ 24.8 0.8≈12=9.6 13.6 12.3 13.85 14.4 Mating connector: HDR series male connector Through hole SMT Press-in IDC Wire Soldering Crimping wrapping Others A 20 B 0.8≈6=4.8 C 8.8 D 7.5 E F 9.05 19.2 0.8mm pitch connector For PCB Right-angle through hole type female connector for PCB HDR-EC( )LFDT( )-( )+ Right-angle Through hole EMI shielded ● Configuration of product Part No. HDR- EC ( ) LFD T ( )- ( )+ ➀ ➁ ➂ ➃ ➄ ➅ ➀ Series name ➅ Lock screw ➁ No. of contacts: 14, 26 or 50 Blank: None ➂ Type of contact SLD : Screw lock LFD: Right-angle through hole type, female SLE : Spring lock ➃ With ground contact SLG : Screw lock ➄ Through hole length, contact plating (Panel thickness: 1.12 mm) Blank : 1.65 mm, Min. 0.1 μm Gold plate 1 : 2.08 mm, + Min. 0.5 μm Palladium alloy G2 : 2.08 mm, Min. 0.76 μm Gold plate 9.55 REF. ¡ ™ 6 15.55 £ Lock screw § 1.12 6.6 5.8 A±0.2 B POS.#2 POS.#1 5 2.32 3.5 POS.#(n/2) C 0.8≈(n/2-1) =D±0.08 M2≈0.4 POS.#(n/2+1) ∞ POS.#2 POS.#1 6.6 ø0.9+0.15 -0 ● Components ¢ POS.#(n/2+1) 0.8 0.4 E 6.1±0.1 POS.#n POS.#(n/2) 1.2±0.03 1.15±0.03 ø0.65 ±0.05 E±0.1 0.8±0.03 1.15±0.03 4.6±0.05 POS.#n 0.4±0.03 POS.#1 POS.#2 4.5±0.1 POS.#n 15 ˚ 2-ø2.3±0.1 2-ø3+0.2 -0 B±0.05 Edge of PCB Recommended PCB layout ➀ Shell ➁ Insulator ● Dimensions ➂ Contacts Part No. HDR-EC14LFDT( )-( )+ ➃ Bracket ➄ Board lock A 20 B 14.4 C 8.8 D 0.8≈6=4.8 E 5.2 HDR-EC26LFDT( )-( )+ 24.8 19.2 13.6 0.8≈12=9.6 10 HDR-EC50LFDT( )-( )+ 34.4 28.8 23.2 0.8≈24=19.2 19.6 § Lock screw Mating connector: HDR series male connector Others Wire wrapping Crimping Soldering IDC Press-in SMT Through hole 0.8mm pitch connector Housing EMI-filtered vertical plastic housing for standard and thin cable HDR-E( )LP( )( )-( ) Vertical EMI shielded ● Configuration of product Part No. HDR- E ( ) LP ( )( )- ( ) ➀ ➁ ➂ ➃ ➄ ➀ Series name ➁ No. of contacts 14, 26 or 50 ➂ Type of housing: Vertical type ➃ Compatible cable A: Standard cable B: Thin cable ➅ ➄ Color of housing Blank: Gray 5 : Black ➅ Length of lock spring Blank: PCB side lock screw -SLE LS : PCB side lock screw -SLK B 8 25 10 C A ● Dimensions Part No. HDR-E14LPA( )-( ) A 21.0 B 17.0 HDR-E26LPA( )-( ) 25.8 21.8 HDR-E50LPA( )-( ) HDR-E50LPB( )-( ) For use with connectors: HDR series IDC type cable connector HDR-E( )MAG1+, HDR-E( )FAG1+ Required tools: Clamp caulking tools: FHPT-0024A, for 14 contacts cable connectors (Refer to page Tool-10) FHPT-0022A, for 26 contacts and 50 contacts thin cable connectors FHPT-0023A, for 50 contacts thick (standard) cable connectors Through hole SMT Press-in IDC Wire Soldering Crimping wrapping Others 35.4 31.4 C ø5.6 6≈6.7 7≈8.7 6≈6.7 0.8mm pitch connector Housing EMI-filtered screw-lock vertical type plastic housing HDR-E26LPH Vertical EMI shielded ● Configuration of product Part No. HDR- E 26 LP H ➀ ➁ ➂ ➀ Series name ➁ No. of contacts: 26 ➂ Type of housing ➃ Serial number ➃ 6≈7 HONDA JAPAN 3 38.14 34.59 25.34 26.2 19.2 Screw size M2≈0.4 8 24.2 Mating connector: HDR series female connector For use with connector: HDR-E26MAG1+, HDR-E26MSG1+ Required tools: Clamp caulking tools: FHPT-0022A (Refer to page Tool-10) MHPT-0006A Others Wire wrapping Crimping Soldering IDC Press-in SMT Through hole 0.8 mm pitch connector EMI-filtered vertical type plastic housing with mounting hardware for spring-lock, for heavy wires and relay connections HDR-E26LPKA+ Housing For Relay connections EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 26 LP K A+ ➀ ➁ ➂ ➃ ➄ ➀ Series name ➁ No. of contacts: 26 ➂ Form of housing Vertical type housing ➃ Serial number For use with cables: Outside diameter of heavy wire: 10.0-11.7 mm ➄ Thickness of relay panel: 1.6 mm 15.6 15.37 Ø11.7 Max. Ø11.7 £ ∞ 37.09 ™ 1.6 ¡ Panel 19.2 M2≈0.4 Connector ¢ 13.2 8 24.2 ● Components ➀ Plastic Cover ➁ Inner Shell B ➂ Inner Shell A ➃ Lock Screw ➄ Plate (For lock screw) Mating connector: HDR series of spring-lock type connector For use with connectors: HDR series of soldering type male or female connector HDR series of IDC type male or female connector Dip SMT Press-in IDC Wire Soldering Crimping wrapping Others HDR series 0.8 mm pitch connector EMI-filtered screw-lock vertical type plastic housing for heavy wires HDR-E26LPK+ Housing Vertical type EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 26 LP K+ ➀ ➂ ➁ ➃ ➀ Series name ➁ No. of contacts: 26 ➂ Form of housing Vertical type housing ➃ Serial number For use with cables: Outside diameter of cable: 10.0-11.7 mm Ø11.7 13.2 ¢ 38.14 25.34 37.09 £ ™ ¡ 13 24.2 8 M2≈0.4 Connector 11.6 19.2 ● Components ➀ Plastic Cover ➁ Inner Shell B ➂ Inner Shell A ➃ Thumb screw Mating connector: HDR series of screw-lock type connector For use with connectors: HDR series of soldering type male or female connector HDR series of IDC type male or female connector Dip SMT Press-in IDC Wire Soldering Crimping wrapping Others HDR series 0.8 mm pitch connector EMI-filtered spring-lock vertical type plastic housing HDR-E26LPJ+ Housing Vertical type EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 26 LP J+ ➀ ➁ ➂ ➃ ➀ Series name ➁ No. of contacts: 26 ➂ Form of housing Vertical type housing ➃ Serial number 6.4 7 21.8 8 ¡ 35 ™ ∞ ¢ £ § 25.8 ● Components ➀ Plastic Cover A ➁ Plastic Cover B ➂ Inner Shell B ➃ Button ➄ Inner Shell A ➅ Lock spring Mating connector: HDR series of spring-lock type connector For use with connectors: HDR series of soldering type male or female connector HDR series of IDC type male or female connector Dip SMT Press-in IDC Wire Soldering Crimping wrapping Others HDR series 0.8 mm pitch connector EMI-filtered vertical type plastic housing with mounting hardware for spring-lock, for thin wires and relay connections HDR-E26LPHA+ Housing For Relay connections EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 26 LP H A+ ➀ ➁ ➂ ➃ ➄ 6.0 ➀ Series name ➁ No. of contacts: 26 ➂ Form of housing Vertical type housing ➃ Serial number For use with cables: Outside diameter of thin wire: 5.8-6.5 mm ➄ Thickness of relay panel: 1.6 mm 6.7 Ø6.5 Max. £ ∞ ™ 34.59 HONDA JAPAN 1.6 ¡ Panel 19.2 ¢ Connector 8 24.2 ● Components ➀ Plastic Cover ➁ Inner Shell B ➂ Inner Shell A ➃ Lock Screw ➄ Plate (For lock screw) Mating connector: HDR series of screw-lock type connector For use with connectors: HDR series of soldering type male or female connector HDR series of IDC type male or female connector HDR series Others Wire wrapping Crimping Soldering IDC Press-in SMT Dip 0.8 mm pitch connector Soldering type female connector for cables HDR-E26FSG1+ For cables Soldering type EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 26 FS G1+ ➀ ➁ ➂ ➃ ➄ ➀ Series name ➁ With metal shell ➂ No. of contacts: 26 ➃ Form of housing FS: Soldering type, female connector, AWG#28 Insulator OD: 1.0 mm max. ➄ Contact plating G1: Min. 0.76 mm Gold plate 0.8≈12=9.6 0.8 Pos.#13 6 9.4 Pos.#1 15.6 0.8≈12=9.6 Pos.#13 0.8 ™ ¢ 5.4 Pos.#1 Pos.#26 ¡ £ Pos.#14 15 ˚ 13.6 ● Components ➀ Female Contact ➁ Shell ➂ Insulator ➃ Spacer Pos.#26 0.8 Pos.#14 0.8≈12=9.6 Mating connector: HDRA series, male connector For use with connectors: HDR-E26LPH( ), HDR-E26LPJ+, HDR-E26LPK( ), HDR-E26ALP( )+ HDR series Others Wire wrapping Crimping Soldering IDC Press-in SMT Dip 0.8 mm pitch connector EMI-filtered screw-lock right-angle type plastic housing HDR-E26ALPA+ Housing Right-angle EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 26 ALP A+ ➀ ➁ ➂ ➃ 19.1 18.85 ➀ Series name ➁ No. of contacts: 26 ➂ Form of housing Right-angle ➃ Serial number For use with cables: Outside diameter of cable: 6.2-6.8 mm 24.8 19.2 ∞ ¢ £ 19.1 ¡ ™ 5.9 ● Components ➀ Plastic Cover A ➁ Plastic Cover B 14.825 29 6.7 8 7.5 15.6 PCB-side connector ➂ Inner Shell B ➃ Inner Shell A ➄ Thumb screw Mating connector: HDR series of screw-lock type connector For use with connectors: HDR series of soldering type male or female connector HDR series of IDC type male or female connector HDR series Others Wire wrapping Crimping Soldering IDC Press-in SMT Dip 0.8 mm pitch connector EMI-filtered screw-lock vertical type plastic housing HDR-E50LPH Housing Vertical type EMI-filtered countermeasures ● Configuration of product Part No. HDR- E 50 LP H ➀ ➂ ➁ ➃ ➀ Series name ➁ No. of contacts: 50 ➂ Form of housing Vertical type housing ➃ Serial number Ø9 ¢ £ 38.14 34.59 ¡ 3 0.8 25.34 ™ 33.8 M2≈0.4 8 10 Connector HDR-E50MSG1+ 28.8 ● Components ➀ Plastic Cover ➁ Inner Shell B ➂ Inner Shell A ➃ Thumb screw Mating connector: HDR series of screw lock type connectors For use with connectors: HDR-E50MSG1+ HDR-E50M( )G( )+ Dip SMT Press-in IDC Wire Soldering Crimping wrapping Others HDR series
HDR-EC26LFDTG2-SLG+ 价格&库存
很抱歉,暂时无法提供与“HDR-EC26LFDTG2-SLG+”相匹配的价格&库存,您可以联系我们找货
