0.8
HDRA series
mm Pitch
0.8 mm Pitch Connectors
Connectors
Outline
Features
Principal
Applications
Electrical
Characteristics
HDRA series connectors have been developed based on the HDR series
products for high speed signal interfaces such as SCSI-III, VHDCI and PCI.
• Conforms to the United States ANSI/SFF8441 standards
• Provided with high performance EMI/ESD-shielded structure
• Mounted with locks or screws
• Low profile
• Sequence structure
Server, Router, Notebook type personal computers and their peripheral
equipment, and mobile equipment
Rated voltage
30V AC (r.m.s.)
Rated current
0.3 A
Insulation resistance
Over 500 megohms at 100V DC
Dielectric withstanding voltage
250V AC (r.m.s.)
70 milliohms or less
Contact resistance
(for combination of MA or MA1 and LFDT)
100 milliohms or less
(for combination with MA1 and W1LFDT)
Document Disclaimer
When placing orders with us, minimum order quantities are set for every product.
Be sure to contact us before starting preliminary design of PCBs using our connectors.
The specifications and information shown in the catalog are subject to change without notice.
Reflow temperature profile
(for reference purposes)
Flow temperature profile
5sec
(Peak)
250˚C
260±5˚C
220˚C
(Full heating
period)
30~60sec
150~180˚C
(Preheating period)
90~120sec
100~130˚C
30~60sec
The reflow temperature profile shown in this drawing is for reference
purposes. This profile depends on requirements such as reflow
equipment, soldering paste, and PCB size. Thus, this profile may not
meet with your specific situation. Please evaluate your PCB-mounting
soldering and set your own reflow temperature profile.
The flow temperature profile as shown above is for reference
purposes. This profile depends on requirements such as the PCB size.
Thus, this profile may not meet with your specific situation. Please
evaluate your PCB-mounting soldering and set your own flow
ΩApplicable products
HDRA series SMT type for PCB
HDRA series through hole type for PCB
The profile shown in this drawing is applicable only for those products shown above.
Product List
IDC type male connector for
cable
HDRA-E36MA+
cable
HDRA-E68MA+
cable
HDRA-E68M( )1+
cable
HDRA-E100M( )1+
A-22HDRA
HDRA series...6
A-23HDRA
HDRA series...7
A-24HDRA
HDRA series...8
A-25HDRA
HDRA series...9
IDC type female connector for
cable
HDRA-E68FAG1+
Straddle SMT type male
connector for PCB
HDRA-E68MT+
Straight through hole type male
connector for PCB
HDRA-EC100MDT-( )+
Straight through hole type female
connector for PCB
HDRA-EC68FDT+
A-26HDRA
HDRA series...10
A-27HDRA
HDRA series...11
A-28HDRA
HDRA series...12
A-29HDRA
HDRA series...13
connector for PCB
HDRA-EC100FDT+
Right-angle through hole type
female connector for PCB
HDRA-E68LFDT-OM18+
HDRA-E68LFD1T-( )+
HDRA-EC68LFDT( )-( )+
A-30HDRA
HDRA series...14
A-31HDRA
HDRA series...15
A-32HDRA
HDRA series...16
A-33HDRA
HDRA series...17
HDRA-EC100LFDT( )-( )+
HDRA-EA36LFDT-( )+
HDRA-E100LFDT( )-( )+
HDRA-E68W1LFDT-( )+
A-34HDRA
HDRA series...18
A-35HDRA
HDRA series...19
A-36HDRA
HDRA series...20
A-37HDRA
HDRA series...21
HDRA-E68W( )LFDT1EC-( )+
HDRA-E100W( )LFDT1EC-( )+
Straight SMT type female
connector for PCB
HDRA-E68FYT-( )+
Right-angle SMT type female
connector for PCB
HDRA-ED68LFZGT( )-( )+
A-38HDRA
HDRA series...22
A-39HDRA
HDRA series...23
A-40HDRA
HDRA series...24
A-41HDRA
HDRA series...25
HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA HDRA
connector for PCB
HDRA-ED136LFZGT( )-( )+
Straddle SMT type female
connector for PCB
HDRA-E68FT+
connector for PCB
HDRA-E68FT2-( )+
connector for PCB
HDRA-E68FT2-OM06+
A-48HDRA
HDRA series...26
A-49HDRA
HDRA series...27
A-50HDRA
HDRA series...28
A-51HDRA
HDRA series...29
connector for PCB
HDRA-EA36FT-NS+
EMI-shielded vertical plastic
housing for standard cable
HDRA-E68LGKP( )
EMI-filtered vertical metallic
housing
HDRA-E100LPA
housing
HDRA-E100LPW( )
A-52HDRA
HDRA series...30
A-53HDRA
HDRA series...31
A-54HDRA
HDRA series...32
A-55HDRA
HDRA series...33
housing
HDRA-E36LPTH
Dust-proof cap
HDRA-E68( )-CP
A-56HDRA
HDRA series...34
A-57HDRA
HDRA series...35
0.8mm pitch connector
For cable
IDC type male connector for cable
HDRA-E36MA+
IDC
ANSI/SFF8441
● Configuration of product Part No.
HDRA- E 36 M A+
➀
➁ ➂ ➃
➀ Series name
➁ No. of contacts: 36
➂ Type of contact
M: IDC type, male
➃ Compatible cable
A: AWG#30(7/0.1), dia. 0.58 mm
21.71
0.8≈17=13.6
POS.#1
POS.#18
3.75
6.48
0.8
POS.#36
POS.#19
25˚
19.16
7.1
➂
14.7
➁
➃
➀
POS.#19
POS.#36
POS.#1
POS.#18
● Components
➀ Contacts
➁ Insulator
➂ Shell
➃ Spacer
➄
➄ Cable housing
Mating connector: HDRA series right-angle through hole type or straddle SMT type female connector
For use with housings: HDRA series upright housing, HDRA-E36LPTH
Required tool: Termination tool: FHAT-0029, IDC tool: FHPT-923B, Hand presser: MFC-K1 (Refer to page Tool-10)
Through
hole
SMT
Press-in
IDC
Wire
Soldering Crimping wrapping
Others
For cable
HDRA-E68MA+
IDC
ANSI/SFF8441
HDRA- E 68 M A+
➀
➁ ➂ ➃
➀ Series name
➁ No. of contacts: 68
➂ Type of contact
M: IDC type, male
➃ Compatible cable
A: AWG#30 (7/0.1), dia. 0.58 mm
34.5
32.6
POS.#34
POS.#1
0.8≈33=26.4
5.4
3.75
0.8
POS.#68
POS.#35
25˚
31.95
7
➂
14.7
➁
➃
➀
POS.#35
POS.#68
POS.#1
POS.#34
● Components
➄
➀ Contacts
➁ Insulator
➂ Shell
➃ Spacer
➄ Cable housing
For use with housings: HDRA series upright housing, HDRA-E68LGKPA
Others
Wire
wrapping Crimping Soldering
IDC
Press-in
SMT
Through
hole
For cable
HDRA-E68M( )1+
IDC
ANSI/SFF8441
HDRA- E 68 M ( ) 1+
35
21.2
➀
➁ ➂ ➃ ➄
➀ Series name
➄ IDC method
1: One side IDC
➂ Type of contact
M: IDC type, male
➃ Compatible cable
Blank: AWG#30 (1/0.254), dia. 0.58 mm
A
C
: AWG#34 (7/0.064), dia. 0.44 mm
68
POS.#35
POS.#68
0.8≈33=26.4
25˚
➀
4.84
2.18
0.8
31.95
POS.#1
POS.#34
➂
1
34
➁
● Components
POS.#34
POS.#1
➀ Contacts
POS.#68
POS.#35
➁ Insulator
➃
➂ Shell
➃ Cable housing
For use with housings: HDRA series vertical housing, HDRA-E68LGKP ( )
Required tool: Termination tool: FHAT-0027, IDC tool: FLPT-0021A, Hand presser: RPS-K4 (Refer to page Tool-10)
Through
hole
SMT
Press-in
IDC
Wire
Others
0.8 mm pitch connector
For cable
HDRA-E100M( )1+
IDC
ANSI/SFF8441
HDRA- E 100 M ( ) 1+
➀
➁
➂
➃
➀ Series name
➁ No. of contacts: 100
➂ Type of contact
M: IDC type, male
➃ Compatible cable
A
POS.#50
POS.#1
POS.#51
21.2
➀
➁
➂
POS.#100
44.2
POS.#100
POS.#51
42.4
0.8
4.84
2.18
7
POS.#1
POS.#50
47.95
● Components
➃
➀ Contacts
➁ Insulator
➂ Shell
➃ Cable housing
Mating connector: HDRA series right-angle through hole type female connector
For use with housings: HDRA series vertical housing, HDRA-E100LPA, HDRA-E100LPW( )
Required tool: Termination tool: FHAT-0038A, IDC tool: FLPT-0021A, Hand presser: RPS-K4 (Refer to page Tool-10)
Others
Wire
IDC
Press-in
SMT
Through
hole
For cable
IDC type female connector for cable
HDRA-E68FAG1+
IDC
ANSI/SFF8441
HDRA- E 68 F A G1+
➀
➁ ➂ ➃ ➄
➀ Series name
➂ Type of contact
F: IDC type, female
➃ Compatible cable
➄ Contact plating
G1: 0.76 μm or more Gold plate
32.6
28.3
0.8≈33=26.4
POS.#34
POS.#1
5.3
0.8
POS.#68
POS.#35
14.7
5.2
31.65
➂
68
35
➁
➃
POS.#35
POS.#68
➀
POS.#1
POS.#34
● Components
➀ Contacts
➁ Insulator
➂ Shell
➄
➃ Spacers
➄ Cable housing
Mating connector: HDRA series right-angle through hole type or straddle SMT type male connector
Through
hole
SMT
Press-in
IDC
Wire
Others
For PCB
Straddle SMT type male connector for PCB
HDRA-E68MT+
Straddle SMT
ANSI/SFF8441
HDRA- E 68 MT+
➀
➁
➂
➀ Series name
➂ Type of contact
MT: Straddle SMT type, male
33.7
0.8≈33=26.4
13.2
➂
14.9
JAPAN
HONDA
0.8
➀
7.1
➁
0.8≈33=26.4
POS.#1
0.8
4.55
3.75
POS.#34
POS.#68
POS.#35
31.95
25˚
2)
2.
POS.#34
0.45 ±0.05
POS.#35
POS.#68
2.5 ±0.05
3 ±0.05
POS.#1
3 ±0.05
2.5±0.05
18.1 REF.
(C
0.45 ±0.05
C0
C0
.5
.2
28.2
30.4
● Components
0.8±0.03
13.2±0.05
0.8
0.8±0.1
±0.03
30.2±0.05
Recommended PCB layout
t=0.8mm
➀ Insulator
➁ Shell
➂ Contacts
Mating connector: HDRA series through hole type or straddle SMT type female connector
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
Straight through hole type male connector for PCB
HDRA-EC100MDT-( )+
Straight Through hole
EMI shielded
HDRA- EC 100 MD T- ( )+
➀
➁
➂
➃
➄
➀ Series name
➄ Presence of guide metal fittings
➂ Type of contact
MD: Straight through hole type, male
➃ With ground contact
Blank: None
GP : Provided with guide hardware.
(The guide pin is required for the mating connector.)
48.35
0.3
46
0.8
0.3≈0.3
5.5
7.1
HDRA MD
58.7
53.7
47.95
42.4
POS.#50
50
100
5
1
51
3.7
POS.#100
21
44.2
51.85
POS.#1
21.4
0.8≈24=19.2±0.05
2.775±0.05
±0.05
1.6±0.03 ø1
(PAD)
±0.03
0.8
21.4
0.4±0.03
POS.#50
POS.#100
100-ø0.65±0.05 POS.#49
● Components
➀ Contacts
3.26
1.175±0.05
POS.#51
ø2.25±0.1(PAD)
ø1.2±0.05
(P.T.H)
42.8±0.1
46±0.1
48.35±0.1
➂ Shell
➃ Hold down
t=1.6mm
➄ Square nuts
Mating connector: HDR series female connector
SMT
0.8±0.03
1.6±0.03
0.8≈24=19.2±0.05
0.4±0.03
➁ Insulator
Through
hole
1.15±0.05
1.85±0.05
2.975±0.05
8.4
2.88
2.25
1.15±0.05
POS.#51
21
M2≈0.4
1.55
2.975
0.8≈24=19.2
7.5
0.8≈24=19.2
POS.#1
Press-in
IDC
Wire
Others
ø1.75±0.05
(T.H)
: PAD
For PCB
Straight through hole type female connector for PCB
HDRA-EC68FDT+
EMI shielded
HDRA- EC 68 FD T+
➀
➁
➂ ➃
➀ Series name
➂ Type of contact
FD: Straight through hole type, female
➃ With hold downs
32.35
30
26.4
POS.#34
2.88
DATE CODE
2.975
1.6±0.03
0.8±0.03
ø1
(PAD)
POS.#1
POS.#35
±0.05
68-ø0.65±0.05
ø1.2±0.05
(P.T.H)
ø1.75±0.05
(T.H)
30±0.1
32.35±0.1
42.7
37.7
t=1.6mm
31.65
2.4±0.08
7.5
7.4
35
5
1
68
POS.#68
4.88±0.08
0.8±0.08
34
: PAD
2.3
2.975
POS.#2
POS.#1
0.3
28.3
0.8≈33=26.4±0.15
1.55
3.46
M2≈0.4
1.96±0.05
2.975±0.05
POS.#68
ø2.25±0.1
(PAD)
1.175±0.05
1.15±0.05
05Z
POS.#33
±0.05
8.4
5.2±0.1 5.5
26.4±0.1
3.26
1.15±0.05
0.3
0.8
34.7±0.08
R1.2REF.
37.7±0.08
Select the connector according to panel thickness.
For the application without panel, use washers or
special lock screw (P/N: HDRA-E68LFD-7C).
Recommended panel cut-out dimensions
Mating connector: HDRA series male connector
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
HDRA-EC100FDT+
EMI shielded
HDRA- EC 100 FD T+
POS.#51
POS.#1
1.15
1.96±0.05
POS.#25
±0.05
POS.#26
100-ø0.65±0.05
±0.05
POS.#50 ø1
(PAD)
8.4
3.26
2.88
1.15±0.05
➀
➁
➂ ➃
➀ Series name
➂ Type of contact
➃ With hold downs
2.975±0.05
POS.#100 0.8±0.03
(96Plc.)
1.6±0.03
(48Plc.)
48.35
46
42.4
4
4±0.03
ø2.25±0.1
(PAD)
ø1.75±0.05(T.H)
ø1.2±0.05
(P.T.H)
42.4±0.1
46±0.1
48.35±0.1
1.6
0.8
t=1.6mm
0.3
: PAD
5.5
5.2
58.7
53.7
47.65
42.4±0.15
0.8±0.08(48PLC.)
51
4±0.08
M2≈0.4
POS.#51
POS.#100
2.3
R1.2REF.
4.88±0.08
2.4±0.08
50.7±0.1
0.3
1.55
2.975
1
100
5
50
7.5
POS.#1
7.4
3.46
POS.#50
53.7±0.1
Through
hole
SMT
Press-in
IDC
Wire
Others
For PCB
Right-angle through hole type female connector for PCB
HDRA-E68LFDT-OM18+
Right-angle Through hole
ANSI/SFF8441
HDRA- E 68 LFD T- OM18+
➃
➀
➁
➂
➄
➀ Series name
➂ Type of contact
LFD: Right-angle through hole type, female
➃ With hold downs
➄ Distance between center of mating section and mounting surface (mm)
26.8±0.1
0.4±0.03
ø0.65±0.05
1.5+0
-0.1
(PAD ø1)
2-C1
29.8±0.1
3.1
ø1.2±0.05
P.T.H.
PAD
ø2.25±0.1
Only for back side
37.7
3.46
2-C1
±0.1
36.47
39.53±0.1
: PAD
t=1.2mm
31.65
POS.#2
POS.#1
28.3
0.8≈33=26.4
POS.#1
1.15±0.05
≠0.2
0.9–0
5.35±0.1
≠0
4.6–0.2
4.65±0.1
1.975±0.05
POS.#68
±0.1
42.7
POS.#2
1.15±0.05
1.2±0.05
HDRA LFD
Bottom of shell
mating section
0.8±0.03
0.3 REF.
10.25
➃
➂
➅
➄
9.55REF.
➁
0.4
7.575
6.365
1.6±0.05
➀
26.8
15.45
±0.05
0.8
1
5
34
68
35
0.3
2.4±0.08
4.88±0.08
39.53
–0
34.7≠0.1
R
● Components
37.7±0.1
➀ Contacts
➁ Brackets
➂ Insulator
➃ Hold downs
Select lock screws according to panel thickness.
➄ Shell
If a panel or washer is not used, use lock screw
➅ Square nuts
Part No. HDRA-E68LFD-7C.
Mating connector: HDRA series IDC type male cable connector, or straddle SMT type male connector
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
HDRA-E68LFD1T-( )+
ANSI/SFF8441
HDRA- E 68 LFD 1 T -( )+
➀
➁
➂
➃ ➄
➅
➀ Series name
➂ Type of contact:
➃ Provided with shell and panel
contact blade
➄ Provided with board lock pin
1.6±0.03
4.3
6.3MAX
2.625±0.05
➅
14
➃
0.4±0.03
POS.#68
28
4.775 REF.
1.15±0.03
4.9±0.1
➂
POS.#1
±0.05
±0.08
2-ø1.2 (P.T.H.)
PADø2.25±0.1
2-ø1.75
32.35±0.05
41.9±0.05
Edge of PCB
42.7
t=1.6mm
: PAD
37.7
31.65
POS.#2
28.3
0.8≈33=26.4
POS.#1
25˚
41.9
0.3
3.925
5.3
34.7
1.55
4.88
2.4
R
1.15
1.2
1.15
● Components
➀ Bracket
➁ Contacts
➂ Insulator
37.7
Through
hole
2.08
2.28
18.85
0.8
3.7
35
6
1
3.5
3.46
0.8
34
68
SMT
Press-in
IDC
Wire
Others
1.2
➁
POS.#2
0.8±0.03
±0.05
68-ø0.65 (P.T.H.)
PADø1±0.1
±0.1
2.25±0.05
➀
9.5
14.7
0.4
1.15±0.03
26.8
➄
26.8±0.05
±0.03
±0.05
3.4±0.1 2.775
➅ Lock screw
Blank: None
SL : Provided
(Thickness of panel: 1.12mm)
➃ Shell
➄ Hold down
➅ Square nuts
For PCB
ANSI/SFF8441
HDRA- EC 68 LFD T ( )- ( )+
➀
➁
➂
➃ ➄
➅
➀ Series name
S : A-2.08 mm contacts
B-2.28 mm board lock pins
➂ Type of contact
C-2.3 mm location peg
LFD: Right-angle through hole type, female 2 : A-2.08 mm contacts
➃ With board lock pin
➄ Length of contact, board lock pins or location peg
C-1.4 mm location peg
Blank: A-2.08 mm contacts
➅ Lock screws
: B-2.28 mm board lock pins
Blank : None
: C-3.7 mm location peg
SL : provided (Thickness of panel: 1.12 mm)
±0.05
26.8±0.05
1.6±0.03
POS.#68
Edge of PCB
4.88±0.08
2.4±0.08
A
0.3
0.8
6
3.5
35
C
1
68
32.35
41.9
: PAD
t=1.6mm
B
3.46
41.9±0.05
0.8
34
±0.08
2-ø1.75
32.35±0.05
POS.#2
POS.#1
±0.05
2-ø1.2 (P.T.H.)
PAD ø2.25±0.1
1.2
±0.03
0.4±0.03
4.775 REF.
42.7
37.7
31.65
28.3
0.8≈33=26.4
POS.#1
4.9±0.1
HDRA LFD
➅
(Two lock screws are supplied with a connector.)
6.3MAX.
➂
➄
4.3±0.1
2.625±0.05
14.7
9.5
➃
POS.#2
0.8±0.03
±0.05
68-ø0.65 (P.T.H.)
PAD ø1±0.1
1.15±0.03
0.4
2.25±0.05
➀
➁
26.8
1.15±0.03
3.4±0.1 2.775
0.3
3.925
≠0.1
34.7–0
1.15
5.3
R
1.55
1.2
1.15
● Components
37.7±0.1
➀ Contacts
➁ Brackets
➂ Insulator
➃ Hold downs
➄ Shell
➅ Lock screws
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
EMI shielded
HDRA- EC 100 LFD T ( )- ( )+
➀
➁
➂
➃ ➄
➅
➀ Series name
➅ Lock screw
Blank: None
➂ Type of contact
SL : Provided
(Panel thickness: 1.12 mm)
female
GP : Guide pin
➄ Through hole length
Blank : 2.08 mm
1
: 3.4 mm (under planning)
2.25±0.05
POS.#50
21.4
0.4+0.03
100-ø0.65±0.05
0.8±0.03
1.6±0.03
0.8≈24=19.2±0.05
2-ø1.75±0.08
42.8±0.1
48.35±0.1
57.9±0.1
3.4
4.78±0.1
9.5
POS.#51
ø1.2+0.05(P.T.H)
1.15±0.05
1.2±0.05
1.15±0.05
2.625±0.05
ø2.25±0.1
Edge of PCB
(PAD)
0.4±0.03
POS.#1
POS.#2
6.3MAX.
4.9
POS.#100
4.3
21.4
0.8≈24=19.2±0.05
1.6±0.03
0.8±0.03 ø1±0.05
(PAD)
HDRA LFD
5.2
t=1.6mm
: PAD
58.7
53.7
47.65
44.3
42.4
0.8≈24=19.2
POS.#1
3.5
0.8≈24=19.2
POS.#50
1
51
6
50
100
3.7
M2≈0.4
POS.#51
POS.#100
0.3≈0.3
21.1
0.8
1.55
3.925
21.1
48.35
57.9
● Components
➀ Bracket
➁ Contacts
➂ Insulator
➃ Shell
➄ Hold downs
Through
hole
SMT
Press-in
IDC
Wire
Others
HDRA-EA36LFDT-( )+
For PCB
ANSI/SFF8441
HDRA- EA 36 LFD T- ( )+
➀
➁
➂
➃ ➄
➀ Series name
➂ Type of contact
➃ Provided with board lock mechanism
➄ Lock screw
Blank: None
SL : Provided (Thickness of panel: 1.12 mm)
2-ø1.2 ±0.05 (P.T.H.)
±0.1
PADø2.25
2.775 ±0.05
POS.#1
1.2
±0.03
0.4 ±0.03
POS.#36
19.55 ±0.05
➃
➅
POS.#2
2.25±0.05
Edge of PCB
6.3MAX.
9.5
➂
HDRA LFD
14.7
➁
➄
0.8 ±0.03
36-ø0.65 ±0.05 (P.T.H.)
PADø1±0.1
1.15 ±0.03
➀
0.4
0.8
1.6 ±0.03
1.15 ±0.03
1.6
t=1.6mm
29.9
24.9
18.86
0.8≈17=13.6
POS.#2
➆
POS.#1
POS.#36
25˚
5.3
0.3
1.15
2.08
2.28
5
3.46
0.8
4.88±0.08
2.4±0.08
1.2
1.15
● Components
21.9
➀ Bracket
≠0.1
–0
R
➁ Contacts
➂ Insulator
➃ Shell
24.9 ±0.1
➄ Square nuts
➅ Lock screw
➆ Board lock pin
Note● Jack screw is not available at present.
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
ANSI/SFF8441
HDRA- E 100 LFD T ( )- ( )+
14.7
9.5
±0.1
4.3
➄
➅
➄ Length of contacts and board lock pins
Blank : A-2.08 mm contacts
1
: A-3.4 mm contacts
B-2.6 mm board lock pins
➅ Lock screws
Blank: None
ø1±0.05
POS.#100 (PAD)
POS.#50
100-ø0.65±0.05
(P.T.H.)
POS.#2 POS.#1
1.15±0.05
➁
➂
4.9±0.1
➀
2.25±0.05
➀
➂
➃
➁
➀ Series name
➂ Type of contact
LFD: Right-angle
3.4
4.775±0.1
2-ø1.75±0.08
58.7
53.7
47.65
44.3
42.4
0.8≈24=19.2
t=1.6mm
3.5
1
51
POS.#100
21.1
6
0.3
POS.#51
21.1
1.55
3.925
5.3
57.9
A
B
50
2.3
3.46
POS.#1
100
0.3
: PAD
0.8≈24=19.2
0.8
POS.#50
0.8
1.2
ø1.2±0.05
ø2.25±0.1 Edge of PCB
(P.T.H.)
(PAD)
±0.05
0.8≈24=19.2±0.05 (4) 0.8≈24=19.2
±0.1
42.4
48.35±0.1
57.9±0.1
1.15±0.05
➆
6.3MAX.
2.625±0.05
➄
➅
±0.05
➃
1.15
4.88±0.08
2.4±0.08
1.2
1.15
50.7±0.1
● Components
R
➀ Contacts
➁ Brackets
➂ Insulator
➃ Hold downs
53.7±0.1
Mating connector: HDRA series IDC type male connector
Through
hole
SMT
Press-in
IDC
Wire
Others
➄ Square nuts
➅ Lock screws
➆ Shell
For PCB
HDRA-E68W1LFDT-( )+
ANSI/SFF8441
HDRA- E 68 W 1 LFD T- ( )+
➀
➁ ➂
➃ ➄
➅
➀ Series name
➁ No. of contacts: 136 (68≈2)
➂ No. of stacks: 2
➃ Type of contact
➄ With location peg
➅ Lock screw
Blank: None
42.7
1.15
1.2
1.15
34.7
1.2±0.03
±0.03
1.15
±0.05
5.08
1.2
1.15
5.08
R
2.4
±0.08
1.15
5.3
37.7
● Components
➀ Bracket
➁ Contacts
5.84
4.88 ±0.08
±0.03
0.3
2.02
11.84
35
3.5
68
POS.#1
(CN2)
2.08
1
POS.#2
(CN2)
5.84
1
34
3.46
35
68
34
32.35
±0.05
6-ø1.2 (P.T.H.)
t=1.6mm
POS.#68
(CN1)
25˚
2.02
ø2.25
PAD
Edge of PCB
0.8≈33=26.4
POS.#68
(CN2)
±0.1
0.4 ±0.03
0.8 ±0.03
0.8≈33=26.4 ±0.05
32.35 ±0.1
POS.#68
(CN2)
37.7
31.65
28.3
1.15
1.2 ±0.03
2.25±0.05
(Four lock screws are supplied with a connector.)
ø0.95
POS.#1(CN2)
POS.#2(CN2)
6.3MAX
➄
POS.#1
(CN1)
1.15
1.6 ±0.03
➃
POS.#2
(CN1)
PAD ø1±0.1
POS.#67(CN1)
POS.#68(CN1)
±0.05
±0.03
JAPAN
HONDA
➁
➂
POS.#1
(CN1)
±0.03
2.78 1.6 136-ø0.65
(P.T.H.)
±0.03
➅
0.8≈33=26.4±0.05
±0.03
±0.03
2.02 2.98
1.15
±0.03
➀
➂ Insulator
➃ Square nuts
➄ Shell
➅ Lock screw
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
ANSI/SFF8441
HDRA- E 68 W ( ) LFD T1 E C -( )+
➀
➁ ➂ ➃
➄
➅ ➆ ➇ ➈
➀ Series name
➅ Earth lock pin (provided with
board lock mechanism)
➂ No. of stacks: 2
➆ Provided with shell connection
➃ Length of contact, through hole
reinforcement
1: 2.08 (PCB: 1.6 mm thick)
➇ Provided with protection cover
2: 3.4 (PCB: 2.4 mm thick)
for contacts and bends
➄ Type of contact
➈ Lock screw
LFD: Right-angle through hole type, Blank: None
female
25˚
32.35
2.02
1.15
1.2
1.15
5.08
1.15
1.2±0.03
5.08
1.2
1.15
±0.05
±0.03
±0.03
3.5
1.2
● Components
➀ Bracket
37.7±0.1
➁ Contacts
–0
34.7 ≠0.1
2.4±0.08
➆
1.15
5.3
11.84
0.3
2.28
➁
2.02
➇
2.08
5.84
3.46
➀
POS.#68
(CN2)
➂ Insulator
R
5.84±0.05
–0
10.72≠0.1
➃ Shell
➄ Square nuts
➅ Lock screw
thickness. For the application without
panel, use washers or special lock
SMT
1.15
t=1.6mm or 2.4mm
POS.#2
(CN2)
POS.#1
(CN2)
Through
hole
±0.05
6-ø1.2 (P.T.H.)
PAD ø2.25±0.1
Edge of PCB
POS.#68
(CN1)
28.3
0.8≈33=26.1
0.4±0.03
0.8±0.03
0.8≈33=26.4 ±0.05
32.35±0.1
POS.#68
(CN2)
37.7
31.65
POS. #1
(CN1)
POS. #2
(CN1)
POS.#1(CN2)
POS.#2(CN2)
1.15
POS.#1
(CN1)
6.3MAX
42.7
PAD ø1±0.1
POS.#67(CN1)
POS.#68(CN1)
±0.03
5.2
2.25±0.05
HONDA
J A PA N
19.1
18.1
➂
➃
➅
±0.03
±0.03
±0.05
2.78 1.6 136-ø0.65
(P.T.H.)
1.6±0.03
➈
➄
0.8≈33=26.4±0.05
±0.03
±0.03
±0.03
1.15
±0.03
2.02 2.98
Press-in
IDC
Wire
Others
➆ Board lock pin
➇ Shell connector
➈ Protection covers
For PCB
ANSI/SFF8441
HDRA- E 100 W ( ) LFD T1 E C- ( )+
➅
(Four lock screws are applied with connector.)
58.7
53.7
47.65
42.4
19.2
POS.#99
(CN1)
19.2±0.05
0.8≈24=19.2
21.1
48.36
6-ø1.2±0.05(P.T.H.)
: PAD
➃
POS.#100
(CN1)
➀
0.3
0.8≈24=19.2
21.1
(4)
42.4±0.05
48.36±0.05
±0.05
POS.#51(CN2)
5.84
3.46
0.8±0.03
1.6±0.03
19.2±0.05
POS.#1(CN2)
POS.#2(CN2)
3.5
11.84
13±0.3
19.2
2.02
POS.#50(CN1)
t=1.6mm or 2.4mm
0.8
POS.#1
(CN1)
POS.#100
(CN2)
POS.#2(CN1)
POS.#50(CN2)
➈ ➁
POS.#1
(CN2)
POS.#2
(CN2)
2.02
0.3
5.3±0.15
1.15
1.2
1.15
A
B
5.2
➆
6.3MAX.
POS.#100(CN2)
Edge of PCB
POS.#100(CN1)
1.15
±0.05
1.2
±0.05
1.15
±0.05
2.25
➄
200-ø0.65±0.05
(P.T.H.)
POS.#1(CN1)
5.4
24.3
±0.03
1.6
±0.03
0.8
POS.#51(CN1)
±0.05
2.02
5.08±0.05
➉
➇
➂
52.7
1.15±0.05
1.2±0.05
1.15±0.05
➀
➁
➂
➃
➄
➅ ➆ ➇
➈
➀ Series name
➂ W: Double stacked connector
➃ Length of contacts or board lock pins ➆ Provided with shell connection
reinforcement
1: A-2.08 mm contacts
B-2.28 board lock pins
2: A-3.4 mm contacts
➈ Lock screws
B-3.6 mm board lock pins
Blank: None
➄ Type of contact
LFD: Right-angle through hole type, female SL : provided (Thickness of panel: 1.12 mm)
1.15
5.08
1.2
1.15
● Components
➁ Brackets
53.7±0.1
50.7±0.1
➂ Insulator A
➃ Board lock pin
R
➄ Square nuts
10.72±0.1
2.4±0.08
➀ Contacts
5.84±0.05
➅ Lock screws
➆ Shell
➇ Insulator B
➈ Shell connection
➉ Protection covers
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
Straight SMT type female connector for PCB
HDRA-E68FYT-( )+
Straight SMT
ANSI/SFF8441
HDRA- E 68 FY T- ( )+
➀
➁ ➂ ➃
➄
➀ Series name
➂ Type of contact
FY: Straight SMT type, female
mechanism
±0.03
±0.05
2.775
2.88
0.4
26.4
➀
3.25 ±0.05
30
➁
PAD 4-ø2.25±0.1
2-ø1.2
±0.05
(P.T.H.)
2.975±0.05
8.4±0.1
32.35
26.4±0.05
POS.#1
0.8 ±0.03 POS.#2
POS.#34
1±0.03
3.26 ±0.1
➄ Lock screw
Blank: None
SL : Provided
10.7
5.2
➂
➃
±0.05
1.175
0.4±0.03
➄
0.45±0.05
POS.#35
2-ø1.75±0.08
30±0.05
32.35±0.05
POS.#68
t=1.6mm
: PAD
42.7
37.7
31.65
POS.#2
28.3
0.8≈3.3=26.4
1
60
35
2.975
5
34
2.28
7.5
3.46
➅
POS.#1
0.8
25˚
3.7
±0.08
4.88±0.08
2.4±0.08
34.7
R
● Components
➀ Insulator
➁ Contacts
➂ Shell
37.7±0.08
➃ Square nuts
Through
hole
SMT
Press-in
IDC
Wire
Others
➄ Lock screw
➅ Hold down
For PCB
Right-angle SMT type female connector for PCB
Right-angle SMT
ANSI/SFF8441
HDRA- ED 68 LFZ G T ( )- ( )+
8.525±0.05
7.3
3.925
2.4
R
0.8
0.8≈33=26.4
37.7±0.1
4
HDRA-ED68FYG+
1
35
Taping packages are available for automatically mounting
board connectors on a PCB. The product part number of
the taping package is HDRA-ED68FYG-TP1+.
One reel provides 1000 board connectors.
The reel diameter is 380 mm. The tape width is 56 mm.
Mounting Method of Right-angle SMT type
Female Connector for PCB
Main body
(HDRA-ED68LFZGT-L+)
SMT Bord connector
(HDRA-ED68FYG+)
HDRA-ED68LFZGTA+
● Components
➄ Shell
➅ Lock screws
➂ Insulator B
➆ Hold downs
➃ Insulator C
panel thickness. For the application
without panel, use washers or special
7.3
34
68
ø0.8
≠0.2
4.05–0.15
LFD1T
Flange for EMI
➁ Insulator A
5.8±0.05
29.5
➀ Contacts
: PAD
4
8
–0
34.7≠0.1
t=1.6mm
0.7
➀
2.85
1.4
32.35
41.9
Edge of PCB
0.8
3.46
1
35
±0.08
4.88±0.08
0.8±0.03
0.8≈33=26.4±0.05
27.15±0.025
29.375±0.025
30.625±0.025
34.15±0.03
34.525±0.05
POS.#2
POS.#1
34
68
POS.#68
0.45±0.025
–0
2-ø1.95≠0.15
0.7
➅
42.7
37.7
31.65
28.3
0.8≈33=26.4
0.8
–0
2-ø0.9≠0.05
10MAX.
7.75±0.03
4.225±0.03
2.975±0.03
0.75±0.025
POS.#1
POS.#68 POS.#2
2.35±0.025
4.7±0.03
1.1±0.05
6.425±0.03
≠0.1
2-ø1.75–0
(P.T.H.)
➄
1.3±0.03
2-ø2.45±0.1(PAD)
4.6
10.85
➂➃
➆
➁
HDRA LFD
16.05
➀
➁
➂
➃ ➄ ➅
➆
➀ Series name
➅ Form of shell
Blank : Standard shell
➂ Type of contact
A
: Shell with flange for EMI
LFZ: Right-angle, female
➆ Lock screws
➃ Contact plating
L: Provided
G: 0.76 μm Gold plate
➄ Ground lock pins with hold downs
PCB
After board connectors are mounted on a PCB, mate them with
the main body, and solder hold downs and ground lock pins.
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
Right-angle SMT
ANSI/SFF8441
Ω Configuration of product Part No.
HDRA- ED 136 LFZ G T ( )- ( )+
➀
➁
➂
➃ ➄ ➅
➆
➀ Series name
➅ Form of shell
Blank: Standard shell
A: Shell with flange for EMI
➂ Type of contact
LFZ: Right-angle SMT type,
➆ Lock screws
L: Provided
female
(Panel thickness: t = 1.12 mm or less)
➃ Contact plating
68
35
CN2
9.4±0.03
2.35±0.025
4.7±0.025
2.1125±0.05
7.05±0.025
: PAD
0.8
0.8≈33=26.4
29.5
3.925
12.7
4
37.7±0.1
–0
34.7≠0.1
R
Recommended panel
cut-out dimensions
HDRA-ED68FYG+
ø0.8
board connectors on a PCB. The product part number of the
taping package is HDRA-ED68FYG-TP2.
One reel provides 1000 board connectors. (500 sets.
Two board connectors can be mounted at a time using a cap.)
Main body
(HDRA-ED136LFZGT( )-L+)
SMT type board connectors
12.84
5.84±0.05
≠0.1
10.72–0
2.4±0.08
0.8
32.35
41.9
t=1.6mm
≠0.2
4.05–0.15
POS.#68
(CN2)
Edge of PCB
4
1
1
CN1
POS.#2(CN2)
POS.#1(CN2)
0.45±0.025 0.8±0.03
0.8≈33=26.4±0.05
27.15±0.025
29.375±0.025
30.625±0.025
34.15±0.03
34.525±0.05
4.6
35
34
34
POS.#2
(CN2)
POS.#1
(CN2)
2.85
68
3.46
POS.#68
(CN1)
1.4
POS.#1
(CN1)
12.84
4.5 5.84
POS.#2
(CN1)
≠0.15
2-ø1.95–0
º
42.7
37.7
31.65
28.3
0.8≈33=26.4
2.35±0.025
4.7±0.03
5.825±0.05
0.7
43.37
0.7
ª
2-ø2.45±0.1
(PAD)
≠0.1
2-ø1.75–0
(P.T.H.)
1.3±0.03
26.45
21.25
8.985±0.05
7.75±0.03
POS.#68(CN2)
±0.03
4.225
POS.#1(CN1)
2.975±0.03
≠0.05
4-ø0.9–0
0.75±0.025
POS.#2(CN1) POS.#68(CN1)
10MAX.
6.425±0.03
lock screw (P/N: HDRAE68LFD-7C).
(HDRA-ED68FYG+)
PCB
Flange for EMI
After board connectors are mounted on a PCB, mate them with the main
68
Ω Components
34
¡ Contacts
∞ Insulator D
ª Shell
1
™ Insulator A
§ Insulator E
º Lock screws
£ Insulator B
¶ Insulator F
⁄ Hold downs
¢ Insulator C
• Shell connection hardware
35
1
34
68
35
HDRA-ED136LFZGTA+
Through
hole
SMT
Press-in
IDC
Wire
Others
For PCB
Straddle SMT type female connector for PCB
HDRA-E68FT+
Straddle SMT
ANSI/SFF8441
HDRA- E 68 FT+
➀
➁ ➂
➀ Series name
➂ Type of contact
FT: Straddle SMT type, female
4-R 0.5MAX.
FT
±0.03
13.2
Edge of
PCB
5.25±0.08
ø1±0.1
2±0.05
2±0.1
2±0.05
2±0.1
POS.#34 POS.#1
0.8±0.03
5.2
POS.#35 POS.#68
1.25±0.15
3±0.1
3.5±0.1
➄
JAPAN
➃
14.65
HONDA
➀
0.8
13.2
2±0.08
POS.#1
0.8≈33=26.4
1±0.1
1±0.1
1.7REF.
30.2±0.05
37.7±0.15
➅
0.45±0.05
Edge of
PCB
0.8±0.03
30˚
13±0.03
42.7
t=1mm
POS.#2
37.7
0.8≈33=26.4
: PAD
POS.#1
34
1
68
35
25˚
➁
4.88±0.08
31.65
34.7
2.4±0.08
POS.#68
3.46
4.3
0.8
R
37.7
POS.#68
0.8
POS.#35
13
0.8≈33=26.4
● Components
➂
➀ Insulator A
➁ Shell
➂ Contacts
➃ Insulator B
➄ Square nuts
➅ Lock screw
Others
Wire
IDC
Press-in
SMT
Through
hole
For PCB
HDRA-E68FT2-( )+
Straddle SMT
ANSI/SFF8441
HDRA- E 68 FT 2- ( )+
5.2
➁
0.7REF.
(POS.#1, #34)
➄
(POS.#1, #34)
±0.1
≈33=26.4
30.4±0.1
34.4±0.1
37.7±0.15
0.5
Edge of PCB
4±0.1
(POS.#2–33)
ø1±0.05
POS.#35
0.45±0.05
POS.#68
(POS.#36–#67)
0.225±0.05
0.5REF.
(POS.#35)
(POS.#35)
1±0.1
1.8REF.
30˚
Edge of PCB
0.8±0.05
0.225±0.05
(POS.#68)
0.9REF.
(POS.#68)
13±0.1
0.8±0.05≈33=26.4±0.1
42.7
37.7
0.8≈33=26.4
4.3REF.
0.45±0.05
0.8±0.05
0.225±0.05
0.8
3.4
➅
POS.#1
±0.05
±0.15
2.6REF.
3±0.15
2-R1
POS.#34
1.25±0.1
4±0.1
JAPAN
HONDA
➀
➃
➂
FT2
14.65
POS.#1
2.6REF.
0.8≈33=26.4
13.2
0.8
POS.#34
5.75±0.08
➀
➁
➂ ➃
➄
➀ Series name
➂ Type of contact
➃ PCB thickness: 0.5 mm
➄ Lock screws
Blank: None
SL : provided
t=0.5mm
POS.#2
POS.#1
: PAD
0.8
34
1
68
35
POS.#68
POS.#68
31.65
● Components
POS.#35
0.8
13
➀ Contacts
➁ Insulator A
0.8≈33=26.4
➂ Insulator B
➃ Square nuts
➄ Lock screws
➅ Shell
Through
hole
SMT
Press-in
IDC
Wire
Others
For PCB
HDRA-E68FT2-OM06+
Straddle SMT
ANSI/SFF8441
HDRA- E 68 FT 2- OM06+
➀
➁ ➂ ➃
➄
➀ Series name
➂ Type of contact
POS.#1
0.8≈33=26.4
➀
➃
➄
41
3.5±0.15
➅
42.7
POS.#2
POS.#1
37.7
0.8≈33=26.4
4-R0.5MAX.
POS.#34
POS.#1
0.45±0.05
0.8±0.03 Edge of PCB
0.8≈33=26.4±0.05
30.2±0.05
34.2±0.05
4.3
1
68
35
POS.#68
POS.#35
0.45±0.05
30
1±0.1
1.9REF.
POS.#68
Edge of PCB
0.8±0.03
0.8≈33=26.4±0.05
: PAD
t=0.5mm
0.8
34
0.5
2±0.05
2±0.05
➁
5.25±0.08
➂
2±0.05
2±0.05
JAPAN
HONDA
2.05
5.2
FT
14.65
0.8
3±0.15
POS.#34
31.65
POS.#68
POS.#35
● Components
34
30.7
➀ Contacts
➁ Insulator A
➂ Insulator B
➃ Square nuts
➄ Lock screws
➅ Shell
Others
Wire
IDC
Press-in
SMT
Through
hole
Vertical housing
EMI-shielded vertical plastic housing for standard cable
HDRA-E68LGKP( )
EMI shielded
ANSI/SFF8441
HDRA- E 68 LGKP ( )
➀
➁
➂
➀ Series name
➂ A: Vertical cable holding type
C: Vertical ultrasonic welding type
E: Vertical ultrasonic welding type
F: Vertical ultrasonic welding type
Outside diameter of cable is shown in the dimension table.
HDRA-E68LGKPA
Thumb screw with
plastic cap should be
tightened by hand. For
screw driver assembly
use the product (P/N:
HDRA-E68LGKPE3)
with metal thumb
screws attached.
ø10MAX
13≈9.5
➅ ➄
➃
➂
5.8
18.3
28.4
12
12
➇
● Components
➆
4
42.7
➁
➀ Cover
➀
➂ Inner shell B
➁ Inner shell A
➃ Cable clamp
11.5
➄ Screw
2-M2≈0.4
8
➅ Bushing
➆ Thumb screw
37.7
➇ Cap (plastic)
HDRA-E68LGKPC,LGKPE,LGKPF
B
The following figure shows HDRA-E68LGKPF.
C
5.81
➃
JAPAN
A
37.7
➄
● Components
➀ Cover A
➁ Cover B
2.68
42.7
2-M2≈0.4
7.35
➂
➁
HONDA
1.81
➀
JAPAN
33.69
36.44
➅
B
C
➂ Shell A
HDRA-E68LGKPC
A
11.5
9.5
10.5≈9.5
➃ Shell B
HDRA-E68LGKPE
9.5
7.5
HDRA-E68LGKPF
9
7.2
Part No.
10.5
➄ Thumb screw
➅ Cap (plastic)
For use with connectors : HDR series IDC type cable connector : -LGKPA for MA, -LGKPC/-LGKPE for MA1, and -LGKPF for MC1
Required tools (for LGKPC, LGKPE and LGKPF): Clamp caulking tools: FLPT-0017B (Refer to page Tool-10)
Ultrasonic welder, Housing holding jig, Sonic welder
Others
Wire
IDC
Press-in
SMT
Through
hole
Housing
EMI-filtered vertical metallic housing
HDRA-E100LPA
Vertical
EMI filtered
HDRA- E 100 LP A
10.8
10.1
➀
➁
➂ ➃
➀ Series name
➂ Type of housing: Vertical type
➃ Compatible cable
A: Outside diameter of cable is 9.8 mm
➀
➁
24.44
54.44
46.44
➂
HONDA JAPAN
58.7
2.78
7.45
12.1
● Components
53.7
➀ Housing A
➁ Housing B
➂ Lock screws
For use with connectors: HDRA-E100M( )1+
Through
hole
SMT
Press-in
IDC
Wire
Others
Housing
HDRA-E100LPW( )
Vertical
EMI filtered
HDRA- E 100 LP W ( )
➀
➁
➂
➃
➀ Series name
➃ Compatible cable and form of through hole
B : Two holes are available for two cables. Outside diameters of cable are 6.9 mm
C : One hole is available for one cable. Outside diameter of cable is 9.6 mm
12
7.6
HDRA-E100LPWC
8.3
7.6
HDRA-E100LPWB
10.3
54.44
46.44
➂
➀
24.44
➁
HONDA JAPAN
58.7
2.78
7.45
9
● Components
53.7
¡ Housing A
™ Housing B
£ Lock screws
Others
Wire
IDC
Press-in
SMT
Through
hole
Vertical housing
HDRA-E36LPTH
EMI shielded
ANSI/SFF8441
HDRA- E 36 LPTH
➀
➁
➂
➀ Series name
ø6.5
10
31
35
1.1
–0.15
31≠0.3
➄
9.5
14MAX.
➅
➀
➃
➀ Case A
➁ Case B
➂
➂ Inner shell A
➃ Inner shell B
➁
➄ Lock spring A
For use with connectors: HDRA-E36M( )+
Mating connectors: HDRA -EA36LFDT+ + Lock screw (HDR-E14LMY-SL-02C) panel:0.5-0.8mm thick
-EA36FT-NS+ + Lock screw (HDR-E14LMY-SL-02C) panel:0.5-0.8mm thick
Required tools: Clamp caulking tools: FLPT-0024A (Refer to page Tool-10) Ultrasonic welder, Housing holding jig, Sonic welder
Through
hole
SMT
Press-in
IDC
Wire
Others
● Components
➅ Lock spring B
Accessories
Dust-proof cap
HDRA-E68( )-CP
Cap
HDRA- E 68 ( )- CP
➀
➁
➂
➀ Series name
➂ M : For male connector
F : For female connector
➃ Cap
HDRA-E68M-CP
➃
HDRA-E68F-CP
7
6.4
5.4
34.4
6.54
34.74
For use with housings: HDRA-E68LGKPC~F
Others
Wire
IDC
Press-in
SMT
Through
hole
Straight DIP type female connector for PCBs
HDRA-EC68FDT-( )+
For PCBs
Straight DIP
EMI-filtered countermeasures
HDRA- EC 68 FD T- ( )+
➀
➂
➁
➃
➄
➀ Series name
➂ Form of contact
FD: Straight, DIP type, female
➃ With ground lock pin
➄ Lock screw
SLD: Provided
Blank: None
32.35
30
26.4
0.3
0.8
5.5
05Z
5.2
42.7
37.7
31.65
Pos.#1
2.28
68
35
7.4
1
5
34
7.5
0.8
Pos.#68
2.3
2.975
Pos.#2
0.3
28.3
0.8≈33=26.4
1.55
3.46
M2≈0.4
R
Pos.#34
Pos.#33
3.26
2.88
37.7
26.4±0.1
2.975±0.05
1.6±0.03
Pos.#1
Ø1±0.05
(Pad)
68-Ø0.65±0.05
0.8±0.03
Pos.#35
➀ Insulator
➁ Contact
Pos.#68
Ø2.25±0.1
(Pad)
1.175±0.05
30±0.1
➂ Shell
➃ Sqr.nut
32.35±0.1
1.96±0.05
● Components
1.15±0.05
2.975±0.05
8.4
1.15±0.05
4.88
2.4
34.7
Ø1.2±0.05
(P.T.H)
Ø1.75±0.05 (T.H)
➄ Hold down
Mating connector: HDRA series male connectors
Dip
SMT
Press-in
IDC
Wire
Others
HDRA series
HDRA-EC100FDT-( )+
For PCBs
Straight DIP
HDRA- EC 100 FD T- ( )+
➀
➁
➂
➃
➄
➀ Series name
➂ Form of contact
➄ Lock screw
SLD: Provided
Blank: None
48.35
46
42.4
4
1.6
0.3
0.8
5.5
5.2
58.7
53.7
47.65
42.4
0.8 (48Plc.)
2.28
M2≈0.4
Pos.#100
2.3
Pos.#51
2.975
51
4
0.3
100
1.55
1
5
50
7.5
Pos.#1
7.4
3.46
Pos.#50
R1.2 Ref.
4.88±0.08
2.4
±0.08
50.7±0.1
53.7±0.1
1.15±0.05
Pos.#51
Ø1±0.05
(Pad)
Pos.#1
Pos.#25
● Components
➀ Insulator
➁ Contact
2.975±0.05
8.4
1.15±0.05
Pos.#50
1.96±0.05
Pos.#26
100-Ø0.65±0.05
3.26
2.88
Pos.#100
0.8±0.03
(96 Plc.)
1.6±0.03
(48 Plc.)
Ø2.25±0.1
(Pad)
4±0.03
Ø1.2±0.05 (P.T.H)
Ø1.75±0.05 (T.H)
42.4±0.1
➂ Shell
➃ Sqr.nut
46±0.1
48.35±0.1
➄ Hold down
Mating connector: HDRA series, male connector
HDRA series
Others
Wire
IDC
Press-in
SMT
Dip
