6A10
6A10
    GW(台湾唯圣)
    R-6
    6A10
6A10 数据手册
6A05 THRU 6A10 6.0 AMP SILICON RECTIFIERS VOLTAGE RANGE 50 TO 1000 Volts CURRENT 6.0 Amperes FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability R-6 .360(9.1) .340(8.6) DIA. 1.0(25.4) MIN. MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Axial leads, solderable per MIL-STD-202, method 208 guranteed * Polarity: Color band denotes cathode end * Mounting position: Any .360(9.1) .340(8.6) 1.0(25.4) MIN. .052(1.3) .048(1.2) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER 6A05 6A1 6A2 6A4 6A6 6A8 6A10 UNITS 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current .375"(9.5mm) Lead Length at Ta=60 C Peak Forward Surge Current, 8.3 ms single half sine-wave 6.0 A superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 6.0A Maximum DC Reverse Current Ta=25 C 300 1.0 10.0 A V A at Rated DC Blocking Voltage Ta=100 C Typical Junction Capacitance (Note 1) Typical Thermal Resistance R JA (Note 2) Operating and Storage Temperature Range TJ, TSTG 400 100 10 A pF C/W C -65 NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance from Junction to Ambient .375" (9.5mm) lead length. 224 +150 RATING AND CHARACTERISTIC CURVES (6A05 THRU 6A10) FIG.1-TYPICAL FORWARD FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 100 40 10 6 Single Phase Half Wave 60Hz Resistive Or Inductive Load 5 Ground Plane 4 1" X 1" Copper surface area 3 PC BOARD PC BOARD Recommended 2 PC Board Standard PC Board Mounting Mounting 1 0 0 20 40 60 80 100 120 140 160 180 200 Tj=25 C AMBIENT TEMPERATURE,( C) Pulse Width 300us 1% Duty Cycle 1 .6 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT .8 1.0 1.2 1.4 1.6 1.8 2.0 FORWARD VOLTAGE,(V) FIG.3 - TYPICAL REVERSE CHARACTERISTICS PEAK FORWARD SURGE CURRENT,(A) INSTANTANEOUS FORWARD CURRENT,(A) 500 500 400 300 8.3ms Single Half Tj=25 C Sine Wave 200 JEDEC method 100 0 1 100 5 50 10 100 10 Tj=100 C FIG.5 - TYPICAL THERMAL RESISTANCE VS. LEAD LENGTH 1.0 Tj=25 C .1 .01 0 THERMAL RESISTANCE, ( C/W) REVERSE LEAKAGE CURRENT, ( A) NUMBER OF CYCLES AT 60Hz 20 40 60 80 100 120 140 25 20 15 10 5 0 .1 .2 .3 .4 .5 .6 .7 .8 .9 EQUAL LEAD LENGTH TO HEAT SINK, INCHES PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) 225 1.0
很抱歉,暂时无法提供与“6A10”相匹配的价格&库存,您可以联系我们找货
