HER108
HER108
    GW(台湾唯圣)
    DO-41(DO-204AL)
    特性:低正向压降。 高电流能力。 高可靠性。 高浪涌电流能力。 高速开关
HER108 数据手册
HER101 THRU HER108 1.0 AMP HIGH EFFICIENCY RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 1.0 Ampere FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability * High speed switching DO-41 .107(2.7) .080(2.0) DIA. 1.0(25.4) MIN. MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Axial leads, solderable per MIL-STD-202, method 208 guranteed * Polarity: Color band denotes cathode end * Mounting position: Any .205(5.2) .166(4.2) 1.0(25.4) MIN. .034(.9) .028(.7) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER HER101 HER102 HER103 HER104 HER105 HER106 HER107 HER108 50 35 50 Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 100 70 100 200 140 200 300 210 300 .375"(9.5mm) Lead Length at Ta=55 C Peak Forward Surge Current, 8.3 ms single half sine-wave 400 280 400 600 420 600 800 560 800 30 1.3 5.0 1.0 1.85 100 at Rated DC Blocking Voltage Ta=100 C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 50 20 75 15 -65 -65 NOTES: 1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 132 +150 +150 UNITS V V V A 1.0 superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 1.0A Maximum DC Reverse Current Ta=25 C 1000 700 1000 A V A A nS pF C C RATING AND CHARACTERISTIC CURVES (HER101 THRU HER108) FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE FIG.1-TYPICAL FORWARD CHARACTERISTICS AVERAGE FORWARD CURRENT,(A) 10 8 05 ER 04 10 6~ H ER ~H ER 1 ~H 01 R1 H HE R1 1.0 HE .1 1.2 1.0 0.8 0.6 Single Phase Half Wave 60Hz 0.4 Resistive Or Inductive Load 0.375"(9.5mm) Lead Length 0.2 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE ( C) Tj=25 C Pulse Width 300us 1% Duty Cycle .01 .6 .8 1.0 1.2 1.4 1.6 1.8 FORWARD VOLTAGE,(V) FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTICS 50W NONINDUCTIVE 10W NONINDUCTIVE ( ) (+) D.U.T. 25Vdc (approx.) PEAK FORWARD SURGE CURRENT,(A) .001 .4 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PULSE GENERATOR (NOTE 2) ( ) 30 24 18 Sine Wave 12 JEDEC method 6 1 5 (+) 1W NONINDUCTIVE 8.3ms Single Half Tj=25 C 0 50 10 100 NUMBER OF CYCLES AT 60Hz OSCILLISCOPE (NOTE 1) NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 2. Rise Time= 10ns max., Source Impedance= 50 ohms. FIG.5-TYPICAL JUNCTION CAPACITANCE 70 trr JUNCTION CAPACITANCE,(pF) INSTANTANEOUS FORWARD CURRENT,(A) ER 10 3 10 | | | | | | | | +0.5A 0 -0.25A -1.0A 60 50 40 HER 101~ 30 20 HER1 HER 105 06~H ER10 8 10 1cm SET TIME BASE FOR 50 / 10ns / cm 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 133 5 10 50 100
HER108 价格&库存
很抱歉,暂时无法提供与“HER108”相匹配的价格&库存,您可以联系我们找货
HER108
  • 10+0.30208
  • 100+0.24117
  • 300+0.21060
  • 1000+0.18782
库存:2544
