FBH1608-101Y
FBH1608-101Y
    LINEKEY(立凯电控)
    0603磁珠 阻抗100Ω@100MHZ
FBH1608-101Y 数据手册
www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series Feature     Wide range of frequency to suppress EMI. Wide range of impedance values for various applications. Internal silver printed layers and magnetic shielded structure. RoHS compliant.  Operating temperature range -55℃~125℃(Including self - temperature rise). Application  High frequency EMI prevention of computers, printers, VCRs TVs and portable telephone. Production identification FBH ① 1005 ② - 121 ③ Y ④ ① Series name: Ultra High Current Ferrite Bead ② Size:1.0×0.5×0.5mm ③ Impedance:120Ω ④ Tolerance:±25% Series Shape and Dimensions (Unit:mm) F . E G Series A B C D ETyp FTyp GTyp SPQ FBH1005 1.0±0.15 0.5±0.15 0.5±0.15 0.25±0.1 0.4 1.3 0.5 10000 FBH1608 1.6±0.15 0.8±0.15 0.8±0.15 0.3±0.2 0.7 1.8 0.8 4000 FBH2012 2.0±0.2 1.25±0.2 0.85±0.2 0.5±0.3 1.0 2.6 1.2 4000 FBH3216 3.2±0.2 1.6±0.2 1.1±0.2 0.5±0.3 2.0 4.2 1.6 3000 www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series FBH1005 Electrical Characteristics Part Number Impedance (Ω) Tolerance (±%) Test Freq. (MHz) DCR Max (Ω) Current Max (A) FBH1005-090Y 9 25 100 0.05 1.80 FBH1005-110Y 11 25 100 0.05 1.80 FBH1005-190Y 19 25 100 0.06 1.50 FBH1005-300Y 30 25 100 0.08 1.30 FBH1005-600Y 60 25 100 0.10 1.00 FBH1005-121Y 120 25 100 0.15 0.80 FBH1005-151Y 150 25 100 0.20 0.70 FBH1005-221Y 220 25 100 0.30 0.60 FBH1005-301Y 300 25 100 0.30 0.60 FBH1005-601Y 600 25 100 0.50 0.50 FBH1005-801Y 800 25 100 0.65 0.30 Typical Impedance vs. Frequency Curves FBH1005-090Y FBH1005-110Y FBH1005-190Y FBH1005-300Y FBH1005-600Y FBH1005-121Y FBH1005-151Y FBH1005-221Y FBH1005-301Y www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series Typical Impedance vs. Frequency Curves FBH1005-601Y FBH1005-801Y Notes: 1. Rated Current: Applied the current to chip bead, the temperature rise shall not be more than 30℃. 2. Measuring Equipment: Z: HP4291A RDC: HP4338B or CHEN HWA 502 www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series FBH1608 Electrical Characteristics Part Number Impedance (Ω) Tolerance (±%) Test Freq. (MHz) DCR Max (Ω) Current Max (A) FBH1608-090Y 9 25 100 0.02 6.00 FBH1608-110Y 11 25 100 0.03 5.00 FBH1608-300Y 30 25 100 0.03 4.00 FBH1608-600Y 60 25 100 0.04 3.00 FBH1608-101Y 100 25 100 0.06 2.50 FBH1608-121Y 120 25 100 0.07 2.00 FBH1608-181Y 180 25 100 0.09 1.50 FBH1608-221Y 220 25 100 0.12 1.50 FBH1608-301Y 300 25 100 0.18 1.50 FBH1608-501Y 500 25 100 0.18 1.20 FBH1608-601Y 600 25 100 0.18 1.20 Typical Impedance vs. Frequency Curves FBH1608-090Y FBH1608-110Y FBH1608-300Y FBH1608-600Y FBH1608-101Y FBH1608-121Y FBH1608-181Y FBH1608-221Y FBH1608-301Y www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series Typical Impedance vs. Frequency Curves FBH1608-501Y FBH1608-601Y Notes: 1. Rated Current: Applied the current to chip bead, the temperature rise shall not be more than 30℃. 2. Measuring Equipment: Z: HP4291A RDC: HP4338B or CHEN HWA 502 www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series FBH2012 Electrical Characteristics Part Number Impedance (Ω) Tolerance (±%) Test Freq. (MHz) DCR Max (Ω) Current Max (A) FBH2012-090Y 9 25 100 0.01 6.00 FBH2012-110Y 11 25 100 0.01 6.00 FBH2012-190Y 19 25 100 0.01 6.00 FBH2012-300Y 30 25 100 0.01 6.00 FBH2012-600Y 60 25 100 0.04 3.50 FBH2012-800Y 80 25 100 0.04 3.00 FBH2012-121Y 120 25 100 0.05 3.00 FBH2012-181Y 180 25 100 0.08 2.50 FBH2012-221Y 220 25 100 0.08 2.50 FBH2012-301Y 300 25 100 0.08 2.50 FBH2012-601Y 600 25 100 0.10 2.00 FBH2012-102Y 1000 25 100 0.12 1.50 Typical Impedance vs. Frequency Curves FBH2012-090Y FBH2012-110Y FBH2012-190Y FBH2012-300Y FBH2012-600Y FBH2012-800Y FBH2012-121Y FBH2012-181Y FBH2012-221Y www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series Typical Impedance vs. Frequency Curves FBH2012-301Y FBH2012-601Y FBH2012-102Y Notes: 1. Rated Current: Applied the current to chip bead, the temperature rise shall not be more than 30℃. 2. Measuring Equipment: Z: HP4291A RDC: HP4338B or CHEN HWA 502 www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series FBH3216 Electrical Characteristics Part Number Impedance (Ω) Tolerance (±%) Test Freq. (MHz) DCR Max (Ω) Current Max (A) FBH3216-090Y 9 25 100 0.015 6.00 FBH3216-110Y 11 25 100 0.015 6.00 FBH3216-190Y 19 25 100 0.015 6.00 FBH3216-300Y 30 25 100 0.015 6.00 FBH3216-600Y 60 25 100 0.025 4.00 FBH3216-800Y 80 25 100 0.035 4.00 FBH3216-121Y 120 25 100 0.035 4.00 FBH3216-151Y 150 25 100 0.045 3.00 FBH3216-221Y 220 25 100 0.055 3.00 FBH3216-301Y 300 25 100 0.065 2.50 FBH3216-501Y 500 25 100 0.085 2.50 FBH3216-601Y 600 25 100 0.10 2.00 FBH3216-801Y 800 25 100 0.11 2.00 FBH3216-102Y 1000 25 100 0.12 2.00 Typical Impedance vs. Frequency Curves FBH3216-090Y FBH3216-110Y FBH3216-190Y FBH3216-300Y FBH3216-600Y FBH3216-800Y FBH3216-121Y FBH3216-151Y FBH3216-221Y www.Linekey.cn Multilayer Chip Ferrite Beads---FBH Series Typical Impedance vs. Frequency Curves FBH3216-301Y FBH3216-501Y FBH3216-801Y FBH3216-102Y FBH3216-601Y Notes: 1. Rated Current: Applied the current to chip bead, the temperature rise shall not be more than 30℃. 2. Measuring Equipment: Z: HP4291A RDC: HP4338B or CHEN HWA 502
FBH1608-101Y 价格&库存
很抱歉,暂时无法提供与“FBH1608-101Y”相匹配的价格&库存,您可以联系我们找货
