HL-304PT1C-T
HL-304PT1C-T
    HONGLITRONIC(鸿利光电)
    插件,D=3mm
    3MM 红外接收管 940NM
HL-304PT1C-T 数据手册
HL-304PT1C-T HL-304PT1C-T Features •Mechanically and spectrally matchend to the infrared emitting LED LAMP. • Color Transparent Lens. •Rohs compliant. Description Package Dimensions Made with NPN silicon phototransistor chips. 1: ANODE 2: CATHODE 3.85 5.3 29.0 SPEC NO: 1 2 1.5 0.7 1 Tolerance Grade 2.54 0.5 2.94 1.5MAX 1 2 1 3 2 Dimension Tolerance (UNIT:mm) 0.5~3 3~6 6~30 30~120 ±0.1 ±0.2 ±0.3 ±0.5 REV NO:A/2 DATE: Mar/07/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 ÿwww.fineprint.com.cn PAGE:1/3 HL-304PT1C-T Electrical / Optical Characteristics at TA=25°C Symbol Parameter Min Typ Max Units Test Conditions VBR CEO Collector-Emitter Breakdown Voltage 30 - 100 V Ic=100uA Ee=0mW/cm 2 VBR ECO Emitter-to–Collector Breakdown Voltage 6.5 - - V Ie=100uA Ee=0mW/cm 2 VCE (SAT) Collector-to-Emitter Saturation Voltage - - 0.2 V Ic=100uA Ee=20mW/cm 2 Collector Dark Current - - 100 nA VCE=100uA Ee=0mW/cm 2 TR Rise Time (10% to 90%) - 15 - us TF Fall Time (90% to 10%) - 15 - us 0.1 0.5 - mA ICEO I(ON) On State Collector Current VCE=5V IC=1mA RL=1000Ω VCE=5V Ee=1mW/cm 2 λ=940nm Absolute Maximum ratings at Ta=25℃ Parameter Max Ratings Collector-to-Emitter Breakdown Voltage 30V Emitter-to-Collector Breakdown Voltage 6.5V Power Dissipation at (or below) 25℃ Free Air Temperature 100mW Operating Temperature Range -30℃~80℃ Storage Temperature Range -30℃~80℃ Lead Soldering Temperature (>3mm for 5sec) SPEC NO: REV NO:A/2 260℃ DATE: Mar/07/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 www.fineprint.com.cn PAGE:2/3 HL-304PT1C-T Soldering: 1. Manual Of Soldering The temperature of the iron tip should not be higher than 300℃and Soldering within 3 seconds per solder-land is to be observed. 2. DIP soldering (Wave Soldering): Preheating:120℃~150℃,within 120~180 sec. Operation heating:245℃±5℃ within 5 sec.260℃(Max) Gradual Cooling (Avoid quenching). SPEC NO: REV NO:A/2 DATE: Mar/07/2011 PDF 文件使用 "pdfFactory Pro" 试用版本创建 ÿwww.fineprint.com.cn PAGE:3/3
HL-304PT1C-T 价格&库存
很抱歉,暂时无法提供与“HL-304PT1C-T”相匹配的价格&库存,您可以联系我们找货
HL-304PT1C-T
  • 10+0.46916
  • 100+0.37584
  • 300+0.32919
  • 1000+0.26558
  • 5000+0.23760
  • 10000+0.22367
库存:18486
