HLXS-386A2RW6S
HLXS-386A2RW6S
    HONGLITRONIC(鸿利光电)
    SMD,1x3.8mm
    发光二极管/LED 白色 SMD,1x3.8mm 3140mcd
HLXS-386A2RW6S 数据手册
广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 SPECIFICATION FOR APPROVAL 产品规格承认书 HONGLI P/N 产品型号 HLXS-386A2RW6S □R&D ■ Sample Product 样 品 Supplier 供应商 Approved By 核准 严冰波 Checked By 初审 郭勇 Prepared By 编制 冯正斌 第 1 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 Contents 目录 1. Description 产品介绍..................................................................................................................................................................... 3 1.1 General Description 产品描述................................................................................................................................................... 3 1.2 Part number code description 型号代码描述.......................................................................................................................... 3 1.3 Features 产品特征....................................................................................................................................................................... 4 1.4 Application 产品应用................................................................................................................................................................... 4 1.5 Package Dimension 封装尺寸................................................................................................................................................... 5 1.6 Product Parameters 产品参数................................................................................................................................................... 6 1.7 Product Binning 产品分 BIN....................................................................................................................................................... 7 1.8 Typical Optical Characteristics Curves 典型光学特性曲线............................................................................................... 11 2. Packaging 产品包装.................................................................................................................................................................... 15 2.1 Packaging Specification 包装规格......................................................................................................................................... 15 2.1.1 Carrier Tape Dimension 载带尺寸...................................................................................................................................... 15 2.1.2 Reel Dimension 卷盘尺寸.................................................................................................................................................... 15 2.2 Moisture Resistant Packing 防潮包装................................................................................................................................... 15 2.3 Reliability Test Items And Conditions 信赖性测试项目及条件.......................................................................................... 17 2.4 Criteria For Judging Damage 失效判定标准........................................................................................................................18 3. SMT Reflow Soldering Instructions SMT 回流焊说明........................................................................................................... 19 3.1 SMT Reflow Soldering Instructions SMT 回流焊说明.........................................................................................................19 4. Handling Precautions 产品使用注意事项................................................................................................................................ 20 4.1 Handling Precautions 产品使用注意事项.............................................................................................................................. 20 第 2 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd 1. A/0 Description 产品介绍 1.1 General Description 产品描述 The White LED, which is formed by blue chip exciting phosphor. Product Package:3.8mmX1.0mmX0.6mm. 该产品为白光LED,是由蓝光芯片激发荧光粉而形成,产品尺寸:3.8mmX1.0mmX0.6mm。 1.2 Part number code description 型号代码描述 X1X2X3X4-X5X6X7X8X9X10X11X12X13 Part number code (型号代码) Description (说明) X1~X4 Company(公司) X5~X7 X8 X9 X10X11 X12 X13 Part number (型号) Value (属性) HLXS 鸿利显示 Product Size(产品尺寸) 386 3806系列 Voltage classification and characteristics (电 压分类与特性) A 单晶常规电压 Drive current(驱 动电流) 2 20mA RW 暖色 6 常规色域65%-72% S 非专利 Emitting Color (发光颜色) Color Gamut(色 域范围) Patent(专利) 2.9-3.3V 第 3 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 1.3 Features 产品特征 ► Side view white LED 侧发光白光 LED ► White SMD Package 白光 SMD 封装 ► Lead frame package with individual 2 pins 由两个引脚组成的封装器件 ► Suitable for all SMT assembly and solder process.适用于所有的 SMT 组装和焊接工艺 ► Extremely wide viewing angle 大发光角度 ► Available on tape and reel. 适用于载带及卷轴 ► RoHS compliant. 满足 RoHS 要求 1.4 Application 产品应用 ► Mobile Phones 手机 ► Notebook 笔记本 ► Industrial display 工业显示 ► Backlight for LCD, switch and symbol, display.LCD 背光、转换器,开关和标志,显示器等 ►General use.其他应用 第 4 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd 1.5 Package Dimension 封装尺寸 A/0 Fig. 1-1 Package Dimension 封装尺寸 Note 备注: 1. All dimensions tolerances are 0.2mm unless otherwise noted.除特别标注外,所有尺寸公差为±0.2 毫米 2. All are in units of mm. 所有尺寸标注单位为毫米 第 5 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 1.6 Product Parameters 产品参数 Table 1-1 Electrical / Optical Characteristics at Ts=25°C 电性与光学特性 Parameter(参数) Symbol (符号) Luminous Intensity (光通量) Min. (最小值) Typ. Max. Unit (典型值) (最大值) (单位) Condition (条件) IV --- 3140 --- mcd IF=20mA 2θ1/2 --- 120 --- deg IF=20mA Forward Voltage (正向电压) VF --- 3.03 --- V IF=20mA Reverse Current (反向电流) IR --- 0.05 --- μA VR=5V Viewing Angle (发光角度) Table 1-2 Absolute Maximum Ratings at Ts=25°C 绝对最大值 Parameter(参数) Symbol (符号) Rating(值) Unit(单位) Reverse Voltage(反向电压) VR 7 V IF 30 mA IFP 100 mA ESD 2000 V LED Junction Temperature (结温) Tj 105 ℃ Operating Temperature (操作温度) Topr -30 ~ +85 ℃ Storage Temperature (储存温度) Tstg -40 ~ +100 ℃ Soldering Temperature (焊接温度) Tsol Forward Current(正向电流) Pulse Forward Current (Duty 1/10 @1KHz) (脉冲电流) Electrostatic Discharge(HBM)*1 (静电) Reflow Soldering: 260℃ for 10sec. 第 6 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 1.7 Product Binning 产品分 BIN Table 1-3 Forward Voltage 电压:( Tolerance: ±0.03V@ IF= 20mA @ Ta=25℃) BIN CODE Min. Max. V28 2.8 2.9 V29 2.9 3.0 W30 3.0 3.1 Unit Condition V IF=20mA Table 1-4 Luminous Intensity流明: ( Tolerance: ±3% @ IF = 20mA @ Ta=25℃) BIN CODE IF=20mA Test Min(mcd) Max(mcd) Min(lm) Max(lm) 30 2350 2450 6.50 6.75 31 2450 2550 6.75 7.00 32 2550 2650 7.00 7.25 33 2650 2750 7.25 7.50 34 2750 2850 7.50 7.75 35 2850 2950 7.75 8.00 36 2950 3050 8.00 8.25 37 3050 3150 8.25 8.50 38 3150 3250 8.50 8.75 39 3250 3350 8.75 9.00 40 3350 3450 9.00 9.25 41 3450 3550 9.25 9.50 42 3550 3650 9.50 9.75 43 3650 3750 9.75 10.00 44 3750 3850 10.00 10.25 45 3850 3950 10.25 10.50 46 3950 4050 10.50 10.75 47 4050 4150 10.75 11.00 48 4150 4250 11.00 11.25 49 4250 4350 11.25 11.50 第 7 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 The C.I.E Chromaticity Diagram CIE色度图 P3 P2 P1 Fig. 1-2 The C.I.E Chromaticity Diagram CIE色度图 Table 1-5 P1 0.5228 0.5072 0.5161 0.5317 0.4336 0.418 0.4091 0.4247 P2 0.5384 0.5228 0.5317 0.5473 0.4491 0.4336 0.4247 0.4402 P3 0.5539 0.5384 0.5473 0.5628 0.4647 0.4491 0.4402 0.4558 [Remarks]: 1 Measurement uncertainty of the color coordinates:±0.003.坐标测量误差 ±0.003. 2 All measurements were made under the standardized environment of Our. 所有测试都是基于我司现有的标 准测试平台。 第 10 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 1.8 Typical Optical Characteristics Curves 典型光学特性曲线 Fig. 1-2 Forward Voltage Vs Forward Current伏安特性曲线 Fig. 1-3 Forward current vs Relative luminous intensity正向电流与相对光强特性曲线 第 11 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 Fig. 1-4 Forward current vs Ambient temperature 管脚温度与正向电流特性曲线 Fig. 1-5 Ambient Temperature vs Chromaticity Coordinate色坐标与管脚温度特性曲线 第 12 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 Fig. 1-6 Forward Current vs Chromaticity Coordinate(λD)色度坐标与正向电流曲线 Fig. 1-7 Directivity(Angle:120°)角度与相对光强度曲线 第 13 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 Fig. 1-8 Spectrum Distribution光谱分布特性曲线 第 14 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 2. Packaging 产品包装 2.1 Packaging Specification 包装规格 Package:4000pcs/reel.包装每卷 4000pcs。 2.1.1 Carrier Tape Dimension 载带尺寸 Fig.2-1 Carrier Tape Dimension 载带尺寸 2.1.2 Reel Dimension 卷盘尺寸 15.2±0.5mm B 178.0±1mm C 60.0±0.5mm D 12.8±0.5mm B A D C Table 2-1 Title 表名 Label 标签 A Fig.2-2 Reel Dimension 卷盘尺寸 Notes 备注: The tolerances unless mentioned ±0.1mm. Unit : mm注:未注公差为±0.1毫米,尺寸单位:毫米。 第 15 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 2.2Moisture Resistant Packing 防潮包装 Lable Desiccants Reel Seal Moisture-Proof Bag HL RoHS Lable Fig.2-3 Moisture Resistant Packing 防潮包装 第 16 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 2.3Reliability Test Items And Conditions 信赖性测试项目及条件 TestItems Ref.Standard Test Condition Time Quantity Ac/Re 项目 参考标准 测试条件 时间 数量 接收/拒收 ---- 20pcs. 0/1 100 cycle 20pcs. 0/1 Reflow 回流焊 Thermal Shock 冷热冲击 High TemperatureStorage 高温保存 Low TemperatureStorage 低温保存 Life Test 常温测试 B T=10 sec -40℃ 20min A ↑↓10s 100℃ 20min A Temp:100℃ 1000hrs. 20pcs. 0/1 A Temp:-40℃ 1000hrs. 20pcs. 0/1 1000hrs. 10pcs. 0/1 10pcs. 0/1 20pcs. 0/1 A High Temperature High Humidity LifeTest Temp:260℃max A Ta=25℃ 60℃/ 90%RH 500hrs. 高温高湿测试 Temperature Humidity Storage 高温高湿储存 A TA=85℃ RH=85% 500hrs. 第 17 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 2.4 Criteria For Judging Damage 失效判定标准 Test Items Symbol Test Condition 项目 符号 测试条件 Forward Voltage 正向电压 Reverse Current 反向电流 Luminous Flux 光通量 Criteria For Judgement 判定标准 Min. 最小 Max. 最大 VF IF=20mA - U.S.L*)x1.2 IR VR = 7V - U.S.L*)x2.0 Ф IF=20mA L.S.L*)x0.7 - Notes 备注: 1.U.S.L: Upper standard level 规格上限 L.S.L: Lower standard level 规格下限 2. The above reliability tests is based on the verification of a single/strip LED of existing experimental platform,the reliability experiment was taken under good heat dissipation conditions. when customers applies the LED to the series and parallel circuit, should take consideration of all the factors suchasthecurrent, voltage distribution, heat dissipation and others.以上可靠性测试是基于现有实验平台单颗/条LED 在良好散热条件 验证下的结果。客户端将 LED 应用于串、并联线路时,需自行评估电流、电压分配、散热等问题。 3. The technical information shown in the data sheets is limited to the typical characteristics and circuit examples of the referenced products. It does not constitute the warranting of industrial property nor the granting of any license. 以上技术数据仅为产品的典型值,只作为参考,不作为任何应用条件及应用方式的保证。 第 18 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 3. SMT Reflow Soldering Instructions SMT 回流焊说明 3.1 SMT Reflow Soldering Instructions SMT 回流焊说明 30Sec.Max 245℃ Max 4℃ /Sec.Max 160~180℃ 6℃ /Sec.Max 5℃ /Sec.Max. 2min,Max 3.1.1 Soldering Iron 烙铁焊接 (1) When do soldering by hand, keep the temperature of iron below less 300℃ less than 3 seconds.当手工焊接时,烙铁的温度必须小于300℃,时间不可超过3秒。 Soldering by hand should be done only one time.手工焊接只可焊接一次。 3.1.2 Repairing 修补 Repairing should not be done after the LEDs have been soldered. When repairing is unavoidable,a double-head soldering iron should be used (as below figure). It should be confirmed in advance whether the characteristics of LEDs will or not be damaged by repairing. LED回流焊后不应该修复,当必须修复时,必须使用双头烙铁,而且事先应确认此种方式会不会 损坏LED本身的特性。 Fig 3-2 Repairing 修补 第 19 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 3.1.3 Cautions 注意事项 (1) The encapsulated material of the LEDs is silicone. Therefore the LEDs have a soft surface on the top of package. The pressure to the top surface will be impacted on the reliability of the LEDs. Precautions should be taken to avoid the strong pressure on the encapsulated part. So when usethe picking up nozzle, the pressure on the silicone resin should be proper. LED封装胶为硅胶, 表面较软, 用力按压胶体表面会影响LED可靠性,因此应有预防措施避免在按压器件,当使用吸嘴 时,胶体表面的压力应是恰当的。 (2) Components should not be mounted on warped (non coplanar) portion of PCB. After soldering, do not warp the circuit board.LED 灯珠不要焊接在弯曲的 PCB 板上,焊接之后,也不要弯折线路 板。 (3) Do not apply mechanical force or excess vibration during the cooling process to normal temperature after soldering. Do not rapidly cool device after soldering.回流焊之后冷却过程中,不 要对材料实加外力,也不要有震动,回流焊后,不要采用激剧冷却的方式。 4. Handling Precautions 产品使用注意事项 4.1 Handling Precautions 产品使用注意事项 (1) LED operating environment and sulfur element composition cannot be over 100PPM in the LEDmating usage material. This is provided for informational purposes only and is not a warranty or endorsement.LED 工作环境及与 LED 适配的材料中硫元素及化合物成份不可超过 100PPM.这只是一 个建议,不作任何品质担保。 (2) In order to prevent ex-ternal material from getting into the inside of LED, which may cause the malfunction of LED, the single content of Bromine element is required to be less than 900PPM,the single content of Chlorine elementis required to be less than 900PPM,the total content of Bromine element and Chlorine element in the external materials of the application products is required to be less than 1500PPM. This is provided for informational purposes only and is not a warranty or endorsement.为了防止外界物质进入 LED 内部以造成 LED 的损伤,所处环 境及所用套件等等,单一的溴元素含量要求小于 900PPM,单一氯元素含量要求小于 900PPM,溴元素 与氯元素总含量必须小于 1500PPM. 这只是一个建议,不作任何品质担保。 第 20 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 (3) Handle the component along the side surface by using forceps or appropriate tools;do not directlytouch or Handle the silicone lens surface, it may damage the internal circuitry.通过使用 适当的工具从材料侧面夹取,不可直接用手或尖锐金属压胶体表面,它可能会损坏内部电路。 Fig 4-1 Handling Precautions 产品使用注意事项 (4) In designing a circuit,the current through each LED must exceed the absolute maximum rating specified for each LED.In the meanwhile,resistors for protection should be applied,otherwise slight voltage shift will cause big current change,burn out may happen. The driving circuit must be designed to allow forward voltage only when it is ON or OFF.If the reverse voltage is applied to LED, migration can be generated resulting in LED damage. 设计电路时,通过 LED 的电流不能超过 规定的最大值,同时,还需使用保护电阻,否则,微小的电压变化将会引起较大电流变化,可能 导致产品损毁。电路设计必须保证只有在开启或者关闭的时候出现正向电压的变化,不要施加反 压,否则会损坏 LED。 (5) Thermal Design is paramount importance because heat generation may result in the Characteristics decline,such as brightness decreased,Color change and so on.Please consider the heat generation of the LEDs when making the system design.LED 容易因为自身的发热和环境 的温度改变而改变,温度升高会降低 LED 发光效率,影响发光颜色,所以在设计时应充分考虑散热问 题。 (6) Compared to standard encapsulants, silicone is generally softer, and the surface is more likely to attract dust,requiring special care during processing. In cases where a minimal level of dirt and dust particles cannot be guaranteed, a suitable cleaning solution must be applied to the surface after the soldering of components. Refond suggests using isopropyl alcohol for cleaning. In case other solvents are used, it must be assured that these solvents do not dissolve the package or resin. Ultrasonic cleaning is not recommended. Ultrasonic cleaning may cause damage to the LED. 与其他封装胶相比,硅胶通常较软,表面易吸附脏物,应用时应特别注意,当 对产品洁净度要求较高时,回流焊以后需要采用恰当的清洗方式,我们推荐用异丙醇作清洗剂,如 第 21 页 共 22 页 广州市鸿利显示电子有限公司 Guangzhou Hongli Display Electronics Co.,Ltd A/0 需要用到其他清洗剂,必须保证不会破坏封装体,超声清洗可能会对 LED 带来损害,不推荐 这种清洗方式。 (7) If the moisture absorbent material(silica gel)has faded away or the LEDs have exceeded the storage time, baking conditions are as follows: the coil is baked at 65±5℃ for 4 hours, the bulk material is baked at 130±5℃ for 3 hours..如果干燥剂或包装失效,或者产品不符合以上有效 储存条件,需拆包后进行烘烤,烘烤条件:卷料 65±5℃,4 小时,散料 130±5℃,3 小时。 If the package is flatulence or damaged,please notify the sales staff to assist.如果包装胀气或者破 损,请通知销售人员协助处理。 (9)Similar to most Solid state devices; LEDs are sensitive to Electro-Static Discharge (ESD) and Electrical Over Stress (EOS). 像其他的半导体电子器件一样,LED 对静电过流击穿非常敏感,需要 做好防护。 Conditions Temperature Humidity Time 种类 温度 湿度 时间 Before Opening Aluminum Bag 1 Year ≤30℃ Storage 储存 ≤75% 拆包前 一年内 After Opening Aluminum Bag 24hours ≤30℃ ≤60% 7days 拆包后 Baking 卷料:65±5℃ 烘烤 散料:130±5℃ 4 hours ------ 3 hours Table 4-1Storage 储存 第 22 页 共 22 页
HLXS-386A2RW6S 价格&库存
很抱歉,暂时无法提供与“HLXS-386A2RW6S”相匹配的价格&库存,您可以联系我们找货
