HP06-2/13-240
HP06-2/13-240
    DBKGROUP
HP06-2/13-240 数据手册
HP Series of PTC Heaters Safe Self regulating temperature output Ac/Dc working (100 - 240v or 12 - 24v) Choice of operating temperature (40°C - 290°C) www.ptcheaters.com DIMENSIONS APPLICATIONS Electrical Switchgear Cabinets HP03 CCTV Camera Housing Telecommunication Cabins 35 8.5 HP04 60 Refrigeration Drip Tray Heating Street Cabinets Laboratory Equipment 35 SPECIFICATION 8.5 HP05 UL, CSA, VDE 40 0.5mm2 black silicon VDE approved wire 100-240vac/dc, 10-30vac/dc, 30-60vac/dc 35 IP54 on request 8.3 HP06 40 Protection class II Custom models considered 35 MODELS MAXIMUM MODELS MAXIMUM 8.3 HP01 75 70 9.5 L *VARIABLE The DBK HP range of Positive Temperature Coefficient (PTC) self regulating heaters have been designed to offer a wide choice of power outputs within a compact series of aluminium profiles. These elements can be operated without the aid of a thermostat or thermal cut-out. Operating voltages available are 100-240vac/dc or 10-30vac/dc (univoltage input). 600mm wire tail versions are available on request. DESIGN NOTES K: A: T: Power = KxAx T Heat transmission factor, sheet steel 5.5W/m2 Kelvin (contact OEM for non steel values). Complete surface area of heat losing enclosure (m2). Temperature difference between the ambient air temperature and the specified air temperature of the enclosure. When considering cabinet heating, place the elements within the lowest part of the enclosure to aid natural convection of the thermal energy. Assisted forced air convection enhances the power output, thus decreasing the temperature of the element. HP03-1/04-24 HP03-1/05-240 HP03-1/07-240 HP03-1/08-24 HP03-1/09-240 HP03-1/11-240 HP04-1/04-24 HP04-1/05-240 HP04-1/07-240 HP04-1/08-24 HP04-1/09-240 HP04-1/11-240 HP04-1/13-240 HP04-1/18-240 HP05-1/04-24 HP05-1/05-24 HP05-1/05-240 HP05-1/07-240 HP05-1/09-240 HP05-1/10-24 HP05-1/11-240 OUTPUT 15W 15W 20W 30W 25W 30W 10W 10W 15W 15W 18W 20W 22W 32W 20W 22W 20W 25W 30W 50W 35W OUTPUT HP05-1/12-24 HP05-1/13-24 HP05-1/14-24 HP05-1/14-48 HP05-1/15-240 HP05-1/20-240 HP05-1/22-24 HP06-2/04-24 HP06-2/05-24 HP06-2/05-240 HP06-2/05-48 HP06-2/07-240 HP06-2/09-240 HP06-2/10-24 HP06-2/11-240 HP06-2/13-240 HP06-2/15-240 HP06-2/18-240 HP06-2/20-240 HP06-2/22-24 HP06-2/24-240 55W 58W 60W 60W 58W 60W 70W 18W 20W 20W 20W 50W 70W 80W 110W 145W 160W 180W 200W 200W 225W * HP01-2/15-240R1 (250mm Length, L) 140W * HP01-2/15-240R2 (400mm Length, L) 160W * HP01-2/15-240R3 (70mm Length, L) 100W * HP01-4/15-240R1 (250mm Length, L) 280W * HP01-4/15-240R2 (400mm Length, L) 320W Note: -24 represents 12-30v operating voltage -48 represents 30-60v operating voltage -240 represents 100-240v operating voltage STANDARD LEAD LENGTH 100mm PO Box 6744 Leicester LE2 6WS, United Kingdom Tel: +44 (0)116 292 1501 Fax: +44 (0)116 292 1503 info@etdyn.com www.etdyn.com Business registration 4345086 VAT registration 787 3265 86
HP06-2/13-240 价格&库存
很抱歉,暂时无法提供与“HP06-2/13-240”相匹配的价格&库存,您可以联系我们找货
HP06-2/13-240
  • 1+198.71502
  • 5+194.75211
  • 10+190.77734
库存:67
