HP4056E8-42
HP4056E8-42
    HYPWR(瀚昕微)
    SOP8_EP
    停产
HP4056E8-42 数据手册
HP4056 1A, Single Li-ion Battery Charger GENERAL DESCRIPTION FEATURES The HP4056 is a complete constant-current/ constant voltage linear charger for single cell Lithium-Ion batteries. No external sense resistor is needed, and no blocking diode is required due to the internal MOSFET architecture. The charge voltage is fixed at 4.2V or 4.35V, and the charge current can be programmed externally with a single resistor.    Programmable Charge Current Up to 1A Under Voltage Lockout Protection 150mV(Typ.) Automatic Recharge Threshold    Charge Status Output Pin 2.9V Trickle Charge Threshold Soft-Start Limits Inrush Current APPLICATIONS Feature Phone MP3/MP4 Players Electric Toy Bluetooth, wireless handsets Others portable electronic device The HP4056 automatically terminates the charge cycle when the charge current drops to 1/10 the programmed value after the final float voltage is reached.      When the input supply (wall adapter or USB supply) is removed, the HP4056 automatically enters a low current state, dropping the battery drain current to less than 0.1uA. MARKING DESCRIPTION “XXXX”: Part number 5 7 6 8 “A”: Internal Control Code “Y”: Year code “M”: Month code XXXX AYMBBC The HP4056 is available in ESOP-8 package. Standard product is Pb-Free & Halogen-Free. “BB”: Order serial number 1 2 3 “C”: Version number 4 ORDERING INFORMATION Device V FLOAT Package Temperature Tape&Reel HP4056E8-42 4.2V ESOP-8 -40 ~ +85℃ 4000/Reel HP4056E8-435 4.35V ESOP-8 -40 ~ +85℃ 4000/Reel TYPICAL APPLICATION CIRCUIT VCHG Green Red R1 TEMP CE 1K PROG 1K CHGb HP4056 R2 1K GND STDb VCC BAT Battery Packet NTC 10uF HP4056 Datasheet, 2020 version 0.2 Hypower Microelectronics(Shanghai)Co., Ltd. Page 1 sales@hypwr.com HP4056 1A, Single Li-ion Battery Charger PIN ASSIGNMENT ESOP-8 1 TEMP CE 8 2 PROG CHGb 7 3 GND STDb 6 4 VCC BAT 5 HP4056 (Top view) PIN DESCRIPTION: Pin Number Pin Name Function 1 TEMP Battery temperature detection and protection input pin. The higher threshold is 0.8*VCC and lower threshold is 0.45*VCC. If it is useless, please pull it low to ground. 2 PROG Charge current setting, charge current monitor and shut down pin. The charging current is given by I BAT = 1000/R PROG (A). Please choose 1% precision resistor for R PROG . 3 GND Ground 4 VCC Power Supply 5 BAT Charge Current Output. Provides charge current to the battery and regulates the final float voltage to 4.2V or 4.35V. 6 STDb 7 CHGb 8 CE Charge termination indicated pin. When charge is terminated, it is pulled low, otherwise it is high impedance. Open-Drain Charge Status Output. When the battery is charging, the CHGb pin is pulled low. When the charge cycle is completed or VCC is removed, the CHGb is forced high impedance. Charge enable pin. High is enable, low is disable. ABSOLUTE MAXIMUM RATINGS (Note) SYMBOL ITEMS VALUE UNIT V CC Input Voltage -0.3~8 V V PROG PROG Voltage -0.3~V CC +0.3 V V BAT BAT Voltage -0.3~7 V Input Voltage -0.3~10 V 1 W All other pins P D_MAX Power Dissipation ESOP-8 TJ Junction Temperature -40~125 ℃ T STG Storage Temperature -55 to 150 ℃ Package Lead Soldering Temperature 260℃, 10s T SOLDER Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability. HP4056 Datasheet, 2020 version 0.2 Hypower Microelectronics(Shanghai)Co., Ltd. Page 2 sales@hypwr.com HP4056 1A, Single Li-ion Battery Charger RECOMMENDED OPERATING CONDITION MIN NOM MAX UNIT V CC Input operating voltage range 4.5 5 5.5 V I BAT Battery charge current range 250 500 1000 mA TJ Junction temperature 0 125 ℃ R PROG CC mode charge current programming resistor 1 4 KΩ 2 SIMPLIFIED BLOCK DIAGRAM HP4056 Datasheet, 2020 version 0.2 Hypower Microelectronics(Shanghai)Co., Ltd. Page 3 sales@hypwr.com HP4056 1A, Single Li-ion Battery Charger ELECTRICAL CHARACTERISTICS The following specifications apply for V CC =5V T A =25℃, unless specified otherwise. SYMBOL ITEMS CONDITIONS MIN TYP MAX UNIT V CC Supply Voltage 4 5 8 V I SPLYCHRG Charge Mode GND Current I BATCHRG Charge Mode Battery Current V PROGCHRG PROG Pin Voltage I SPLYSTBY Standby Mode Supply Current Charge Terminated 130 µA I BATSTBY Standby Mode Battery Current Charge Terminated 3 µA I SPLYASD Shutdown Mode Supply Current 2V
HP4056E8-42 价格&库存
很抱歉,暂时无法提供与“HP4056E8-42”相匹配的价格&库存,您可以联系我们找货
