HP4054S5-42
HP4054S5-42
    HYPWR(瀚昕微)
    SOT23-5
    HP4054S5-42
HP4054S5-42 数据手册
HP4054 500mA, Single Li-ion Battery Charger GENERAL DESCRIPTION FEATURES The HP4054 is a complete constant-current/ constant voltage linear charger for single cell Lithium-Ion batteries. No external sense resistor is needed, and no blocking diode is required due to the internal MOSFET architecture. The charge voltage is fixed at 4.2V or 4.35V, and the charge current can be programmed externally with a single resistor. ⚫ ⚫ ⚫ Programmable Charge Current Up to 500mA Under Voltage Lockout Protection 150mV(Typ.) Automatic Recharge Threshold ⚫ ⚫ ⚫ Charge Status Output Pin 2.9V Trickle Charge Threshold Soft-Start Limits Inrush Current The HP4054 automatically terminates the charge cycle when the charge current drops to 1/10 the programmed value after the final float voltage is reached. ⚫ ⚫ ⚫ ⚫ ⚫ When the input supply (wall adapter or USB supply) is removed, the HP4054 automatically enters a low current state, dropping the battery drain current to less than 0.1uA. MARKING DESCRIPTION APPLICATIONS Feature Phone MP3/MP4 Players Electric Toy Bluetooth, wireless handsets Others portable electronic device NXYWV The HP4054 is available in a small package with SOT23-5L. Standard product is Pb-Free. “N”: Product code,here use “M” stand for “HP4054” “X”: Internal Control Code “Y”: Internal Control Code “W”: The week of manufacturing. “A”stands for week 1,“Z”stands for week 26, “a”stands for week 27,“z” stands for week 52. “V”: Product version. TYPICAL APPLICATION CIRCUIT VCHG VIO 10K 1K 1 BAT 2 2K VCC 3 4 10uF HP4054 Datasheet, 2019 V1.0 Hypower Microelectronics(Shanghai)Co., Ltd. Li-ion Battery PROG CHGb GND BAT 5 2K HP4054 3 Li-ion Battery GND 1 μP 5 HP4054 2 PROG CHGb VCHG VCC 4 10uF Page 1 sales@hypwr.com HP4054 500mA, Single Li-ion Battery Charger ORDERING INFORMATION Part No. VFLOAT Package Temperature Tape & Reel HP4054S5-42 4.2V SOT23-5L -40 ~ 85℃ 3000/Reel HP4054S5-435 4.35V SOT23-5L -40 ~ 85℃ 3000/Reel PART NUMBER RULES PIN ASSIGNMENT HP4054□ 1 -□ 2 Code Description 1 □ Package: S5: SOT23-5L 2 □ Voltage version: 42: 435: 4.2V 4.35V SOT23-5L 1 GND 2 BAT 3 5 PROG 4 VCC NXYWV CHGb HP4054 (Top view) PIN DESCRIPTION: Pin Number Pin Name I/O 1 CHGb O Function Open-Drain Charge Status Output. When the battery is charging, the CHGb pin is pulled low. When the charge cycle is completed or VCC is removed, the CHGb is forced high impedance. 2 GND Ground 3 BAT O Power ground Charge Current Output. Provides charge current to the battery and regulates the final float voltage to 4.2V or 4.35V. 4 VCC Power Power Supply Charge current setting, charge current monitor and shut down pin. The 5 PROG O charging current is given by IBAT= 1000/RPROG(A). Please choose 1% precision resistor for RPROG. The chip will be shutdown when PROG pin floating. HP4054 Datasheet, 2019 V1.0 Hypower Microelectronics(Shanghai)Co., Ltd. Page 2 sales@hypwr.com HP4054 500mA, Single Li-ion Battery Charger ABSOLUTE MAXIMUM RATINGS (Note) SYMBOL ITEMS VALUE UNIT VCC Input Voltage -0.3 ~ 8 V VPROG PROG Voltage -0.3 ~ VCC+0.3 V VBAT BAT Voltage -0.3 ~ 7 V VCHGb CHGb Voltage -0.3 ~ 10 V PD_MAX Power Dissipation 0.8 W SOT23-5L TJ Junction Temperature -40 ~ 125 ℃ TSTG Storage Temperature -55 ~ 150 ℃ TSOLDER Package Lead Soldering Temperature 260℃, 10s Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability. RECOMMENDED OPERATING CONDITION MIN NOM MAX UNIT VCC Input operating voltage range 4 5 6 V IBAT Battery charge current range 100 250 500 mA TJ Junction temperature 0 125 ℃ RPROG CC mode charge current programming resistor 2 10 KΩ 4 SIMPLIFIED BLOCK DIAGRAM VCC 165oC - TDIE + 1X TA 5uA 1000X + BAT - MA R1 + VA CA - R2 + - REF 1.2V C1 SHDNb + 1V R1 R2 + C2 CHGb To BAT 2.9V - R3 3uA + - 0.1V C3 VCC PROG GND HP4054 Datasheet, 2019 V1.0 Hypower Microelectronics(Shanghai)Co., Ltd. Page 3 sales@hypwr.com HP4054 500mA, Single Li-ion Battery Charger ELECTRICAL CHARACTERISTICS The following specifications apply for VCC=5V, TA=25℃, unless specified otherwise. SYMBOL ITEMS CONDITIONS MIN TYP MAX UNIT VCC Supply Voltage 4 5 6 V ISPLYCHRG Charge Mode GND Current IBATCHRG Charge Mode Battery Current VPROGCHRG PROG Pin Voltage ISPLYSTBY Standby Mode Supply Current Charge Terminated 130 µA IBATSTBY Standby Mode Battery Current Charge Terminated 3 µA ISPLYASD Shutdown Mode Supply Current VCC
HP4054S5-42 价格&库存
很抱歉,暂时无法提供与“HP4054S5-42”相匹配的价格&库存,您可以联系我们找货
