HPR100-2205-Z10
HPR100-2205-Z10
    NEXTEK
    NEXTEK - HPR100-2205-Z10 - Power Line Filter, Chassis, General Purpose, 100 VDC, 100 A, Single Phase...
HPR100-2205-Z10 数据手册
Product Specification  HPR100  High Current DC Feedthrough Filter  100 Amp   Excellent EMI filtering    Compact and lightweight   “C” Type Filter   Bolt‐in style   High Shock & Vibration   CDR and JAN Reliability levels available  Voltage & Capacitance    100A      50  100  Vdc  200  500  Rated  Voltage    Capacitance µF  .01  .015  .022  .033  .047  .068 .1  .15 .22 .33 .47 .68 1.0 1.5 2.2  3.3  4.7  6.8     22 Capacitance in μF 70 60 Insertion Loss dB       15 Standard Values Insertion Loss      80       10 50 40 30 20   10 0 0.001    www.nexteklightning.com   0.01 0.1 1 Frequency in MHz 10   This specification is for reference only and is subject to change without notice  100 1000 ©NexTek, Inc.  439 Littleton Road  Westford, MA 01886  (978) 486‐0582  Product Specification  HPR100  Specifications (Units to MIL‐C‐49467, MIL‐C‐55681, MIL‐C‐123 or customer SCD available in E‐Series)  Parameter  Value  Current  Insertion Loss  RF Current  Insulation Resistance  Dielectric Withstand Voltage  Dissipation Factor  Voltage Drop  Operating Temp  Temperature Rise  Heat Rise Constant  Storage Temperature  Fungus  Corrosion (metal finish)  Humidity  Shock  Terminal Strength  Reliability(MTBF)  100 Amperes  See Performance Curve on page 1  10Arms  100F (100M Maximum) at 25oC  250% Rated Voltage (50mA 5s)  3% Maximum   20mV  ‐55oC to +125oC  22oC Typical at 100A  6.1 to 12  ‐55oC to +105oC  Non‐Nutrient  5% NaCl / 35oC / 48 hrs  98%RH 25oC‐65oC  30g – 11ms  Pull: 75lbs (34kg) Torque: 75”lbs (8.5Nm)  500,000 hrs  Description / Specification / Method  50, 55, 140, 175, 250, & 400 Amps available  Per Capacitor Value    MIL‐STD‐202 Method 302  MIL‐STD‐202 Method 301  MIL‐STD‐202 Method 306  Wire to Wire  5A@125oC to 100A@90oC    C1 in formula ΔT=C1 x W0.85    MIL‐HDBK‐454A  MIL‐STD‐202 Method 101D / Cond B  MIL‐STD‐202 Method 106E  MIL‐STD‐202 Method 213B / Cond A  MIL‐STD‐202 Method 211A / Cond A & E  MIL‐HDBK‐217F  Cond ‐ N2  A(IF) 70oC 50%V      Mechanical Specifications                                Component  Metal Parts  Insulator         www.nexteklightning.com   Material  Copper Alloy  FR4 or Nylon  Finish  Nickel  ‐      This specification is for reference only and is subject to change without notice  ©NexTek, Inc.  439 Littleton Road  Westford, MA 01886  (978) 486‐0582  Product Specification  HPR100  Mounting                  a. b. c. d. e. Mounting Panel  Lug / Wire  Mounting Nut  Lock Washer  Electrode Lug Nut      Mounting & Electrode Torque: 75”lbs (8.5Nm) Part Number      Device  HPR  Current  100  Capacitance  XXXX Tolerance  X Device    HPR High Current Feedthrough Filter  Current    Current rating in amperes  Voltage  XX Series  X Capacitance    in picofarads, first two digits are significant, last two digits are number of zeros    e.g. 2203 = 22,000pF / 4704 = .47µF  Tolerance    Capacitor Code: Z= +80%/‐20% (Standard), M= +/‐20%, K= +/‐10%, J=+/‐5%  Voltage    Rating Code: 05=50V, 10=100V, 20=200V, 50=500V   Series  Optional series designator  Example:   HPR1001004Z10 = Feedthrough Filter / 100A / 0.10uF / +80%/‐20% / 100Vdc  Safety Tips   The filter should be mounted in a grounded shielding panel   Tighten the electrode nuts to the torque specified with the two wrench method   Cover exposed electrode nuts   Observe temperature, current, & voltage limits         www.nexteklightning.com     This specification is for reference only and is subject to change without notice  ©NexTek, Inc.  439 Littleton Road  Westford, MA 01886  (978) 486‐0582
HPR100-2205-Z10 价格&库存
很抱歉,暂时无法提供与“HPR100-2205-Z10”相匹配的价格&库存,您可以联系我们找货
