HRG3216P-1210-D-T1
HRG3216P-1210-D-T1
    SUSUMU
    贴片电阻 1206 121Ω ±0.5% 1W ±25ppm/℃
HRG3216P-1210-D-T1 数据手册
High power thin film chip resistors (short side terminal) ■HRG series AEC-Q200 Compliant Features ・ Wider bottom terminal enabling higher power capability (short side terminal) ・ Significantly larger power handling capability than existing same size resistors Thin film surface mount resistors Size: 3216, Power rating: 1.0W, Resistance range: 10 ~ 100KΩ ・ Precision resistance tolerance: ±0.1%, very small TCR: ±25ppm/°C ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Power source related devices ・ DC motors, inverters HRG series ・ Robotics, Industrial control system ◆Part numbering system HRG 3216 P - 1001 - B - T5 Packaging quantity: T1(1,000pcs), T5(5,000pcs) Series code Size: HRG3216 Resistance tolerance Temperature coefficient of resistance Nominal resistance value (E-24, E-96: all 4 digit) ◆Electrical Specification Temperature coefficient of resistance Power ratings Type Resistance range(Ω) Resistance tolerance (ppm/°C) ±0.1% (B) ±25(P) Resistance value series Operating temperature 200V E-24, E-96 -55℃ ~ 155℃ 47≦R≦100k ±50(Q) Packaging quantity ±0.5% (D) 1.0W HRG3216 Maximum voltage 47≦R≦100k 10≦R≦100k T1 T5 ◆Dimensions L a a Type W t b 29 b HRG3216 Size (inch) 1206 L W a b t 3.20±0.20 1.60±0.20 0.50±0.25 1.10±0.20 0.45±0.10 (unit:mm) ◆Reliability specification Standard ≦47Ω ≧47Ω Test items Condition (test methods (JIS C5201-1) Life (biased) 70℃, rated voltage,* 1 90min on 30min off, 1000hours High temperature high humidity 85℃, 85%RH, 1/10 of rated power, 90min on 30min off, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Temperature shock -55℃ (30min) ∼ 125℃ (30min) 1000cycles ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) High temperature exposure 155℃, no bias, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Resistance to soldering heat 260±5℃, 10 seconds (reflow) ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Rated voltage is given by E= R x P E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. ◆Reliability test data ○High temperature high humidity (biased) 0.12 0.08 0.06 0.12 0.10 Load Life @ 70℃ at Rated Power 1.0W n = 4 0.04 0.02 0.00 -0.02 -0.04 -0.06 HRG3216:10kΩ -0.08 Resistance drift(%) Resistance drift(%) 0.10 -0.10 -0.12 0.08 0.06 0.02 0.00 -0.02 -0.04 -0.06 Test duration(h) 0.12 0.10 Thermal Shock -55℃ - +125℃ n = 25 0.02 0.00 -0.02 -0.04 -0.06 HRG3216:10kΩ -0.08 Resistance drift(%) Resistance drift(%) 10           100          1000       10000 ○High temperature exposure 0.04 0.08 0.06 High Temperature Exposure at 155℃ with no power n = 25 0.04 0.02 0.00 -0.02 -0.04 -0.06 HRG3216:10kΩ -0.08 -0.10 -0.10 -0.12 HRG3216:10kΩ -0.08 -0.12 10           100          1000       10000 0.12 0.06 0.1W n = 25 -0.10 ○Temperature shock 0.08 Temperature Humidity Bias 0.04 Test duration(h) 0.10 HRG series ○Biased life test 10           100          1000       10000 Test duration(h) -0.12 10           100          1000       10000 Test duration(h) Ratio to rated power (%) ◆Derating Curve 100 50 0 -55     Thin film surface mount resistors *1 ±(0.5%+0.05Ω) ±(0.25%+0.01Ω) 0     50 70  100     155 Ambient temperature (℃) 30
HRG3216P-1210-D-T1
物料型号:HRG系列薄膜表面贴装电阻器。
器件简介:HRG系列是高功率薄膜芯片电阻器,符合AEC-Q200标准,具有更宽的底部终端,提供更高的功率承载能力,尺寸为3216,功率等级为1.0W,电阻范围为10至100KΩ。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:具有±0.1%的精确电阻公差和非常小的温度系数±25ppm/°C。薄膜结构使其具有低噪声和抗硫特性。
功能详解:适用于电源相关设备、直流电机、逆变器、机器人、工业控制系统等。
应用信息:HRG系列电阻器适用于高功率应用,如电源设备、直流电机、逆变器、机器人和工业控制系统。
封装信息:尺寸为1206,具体尺寸数据以毫米为单位提供,包括长度、宽度和高度。
HRG3216P-1210-D-T1 价格&库存
很抱歉,暂时无法提供与“HRG3216P-1210-D-T1”相匹配的价格&库存,您可以联系我们找货
HRG3216P-1210-D-T1
  • 1+5.559121+0.72267
  • 10+4.5966810+0.59756
  • 50+4.0271150+0.52351
  • 100+3.81008100+0.49530
  • 500+3.37557500+0.43882
库存:578
HRG3216P-1210-D-T1
  • 1000+3.494171000+0.45423
  • 3000+3.260613000+0.42387
库存:578
HRG3216P-1210-D-T1
    HRG3216P-1210-D-T1
    • 1+5.376001+0.68470
    • 10+3.9066010+0.49760
    • 100+3.62680100+0.46190
    • 250+3.56840250+0.45450
    • 500+3.32360500+0.42330
    • 1000+3.218601000+0.40990
    • 5000+3.125305000+0.39800
    • 25000+2.8804025000+0.36690
    库存:2412
