HSBA20N15S
N-Ch 150V Fast Switching MOSFETs
Description
Product Summary
The HSBA20N15S is the highest performance
trench N-ch MOSFETs with extreme high cell
density, which provide excellent RDSON and gate
charge for most of the synchronous buck
converter applications.
The HSBA20N15S meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
VDS
150
V
RDS(ON),max
56
mΩ
ID
23
A
PRPAK5*6 Pin Configuration
Super Low Gate Charge
Green Device Available
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
150
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
23
A
ID@TC=100℃
16
A
IDM
Pulsed Drain Current2
60
A
EAS
Single Pulse Avalanche Energy3
53
mJ
IAS
Avalanche Current
18
A
PD@TC=25℃
Total Power Dissipation3
72.6
W
PD@TA=25℃
2.1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient 1
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
Typ.
Max.
Unit
60
℃/W
1.72
℃/W
1
HSBA20N15S
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
RDS(ON)
VGS(th)
IDSS
Parameter
Conditions
Min.
Typ.
Max.
Unit
Drain-Source Breakdown Voltage
VGS=0V , ID=250uA
150
V
Static Drain-Source On-Resistance2
VGS=10V , ID=10A
56
m
VGS=4.5V , ID=10A
68
m
Gate Threshold Voltage
VGS=VDS , ID =250uA
1.2
2.5
V
VDS=120V , VGS=0V , TJ=25℃
1
VDS=120V , VGS=0V , TJ=55℃
5
Drain-Source Leakage Current
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=10A
33
S
Qg
Total Gate Charge
19
Qgs
Gate-Source Charge
4.5
Qgd
Gate-Drain Charge
2.6
VDS=75V , VGS=4.5V , ID=10A
nC
13
Rise Time
VDD=75V , VGS=10V , RG=3.3
8.2
Turn-Off Delay Time
ID=10A
25
Fall Time
11
Ciss
Input Capacitance
1090
Coss
Output Capacitance
93
Crss
Reverse Transfer Capacitance
6
Min.
Typ.
Max.
Unit
23
A
60
A
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=75V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
IS
Continuous Source Current1,5
ISM
Pulsed Source Current2,5
VSD
Diode Forward Voltage2
VGS=0V , IS=1A , TJ=25℃
1.2
V
trr
Reverse Recovery Time
IF=10A , dI/dt=100A/µs ,
37
nS
Qrr
Reverse Recovery Charge
TJ=25℃
263
nC
VG=VD=0V , Force Current
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.3mH,IAS=18A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSBA20N15S
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source Voltage
10
IS Source Current(A)
8
6
TJ=150℃
4
TJ=25℃
2
0.25
0.50
0.75
1.00
VSD , Source-to-Drain Voltage (V)
Fig.4 Gate-Charge Characteristics
Fig.3 Forward Characteristics of Reverse
2.5
Normalized On Resistance
Normalized VGS(th) (V)
1.8
2.0
1.4
1.5
1
0.6
1.0
0.2
0.5
-50
100
150
-50
50
100
150
Fig.6 Normalized RDSON vs. TJ
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
TJ , Junction Temperature (℃)
TJ ,Junction Temperature (℃ )
Ver 2.0
3
HSBA20N15S
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
P DM
0.01
T ON
T
SINGLE
D = TON/T
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
BVDSS
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching
Waveform
www.hs-semi.cn
Ver 2.0
4
HSBA20N15S
Ordering Information
Part Number
HSBA20N15S
www.hs-semi.cn
Package code
PRPAK5*6
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSBA20N15S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.73680
- 10+2.91600
- 30+2.55960
- 100+2.11680
- 500+1.77120
- 1000+1.65240
- 国内价格
- 1+1.76400
- 10+1.69400
- 100+1.48400
- 500+1.44200
