HSH90P06
P-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSH90P06 is the high cell density trenched
P-ch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications.
The HSH90P06 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
VDS
-60
V
RDS(ON),typ
7.5
mΩ
ID
-85
A
TO263 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
IDM
EAS
PD@TC=25℃
±20
V
Continuous Drain
Current1
-85
A
Continuous Drain
Current1
-60
A
-310
A
360
mJ
210
W
Pulsed Drain
Current2
Single Pulse Avalanche
Total Power
Energy3
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
62
℃/W
0.71
℃/W
1
HSH90P06
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
VGS=-10V , ID=-40A
7.5
9
VGS=-4.5V , ID=-30A
9
11
VGS=VDS , ID =-250uA
-1.0
-1.4
-3.0
VDS=-48V , VGS=0V , TJ=25℃
1
VDS=-48V , VGS=0V , TJ=55℃
50
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
3.4
Qg
Total Gate Charge (-4.5V)
170
Qgs
Gate-Source Charge
29
Qgd
Gate-Drain Charge
35
Td(on)
Turn-On Delay Time
VDS=-48V , VGS=-10V , ID=-40A
nC
15
Rise Time
VDD=-30V , VGS=-10V , RG=4,
88
Turn-Off Delay Time
ID=-40A
150
Fall Time
101
Ciss
Input Capacitance
9188
Coss
Output Capacitance
501
Crss
Reverse Transfer Capacitance
234
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-85
A
VGS=0V , IS=-40A , TJ=25℃
-1.3
V
21
ns
17
nC
Tr
Td(off)
Tf
VDS=-25V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Continuous Source Current1,5
Voltage2
VSD
Diode Forward
Trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
Isd=-40A,dI/dt=100A/us
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-48V,VGS=-10V,L=0.3mH
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSH90P06
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSH90P06
Switching Time Waveform
www.hs-semi.cn
Unclamped Inductive Waveform
Ver 2.0
4
HSH90P06
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSH90P06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.18300
- 10+6.92860
- 30+6.23280
- 100+5.45860
- 国内价格
- 1+9.01800
- 10+7.63560
- 30+6.86880
- 100+6.01560
- 500+4.98960
- 800+4.81680
