HSM0204
Dual N-Ch 100V Fast Switching MOSFETs
Product Summary
Description
The HSM0204 is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power
switching and load switch applications.
The HSM0204 meets the RoHS and Green
VDS
100
V
RDS(ON),max
112
mΩ
ID
2.5
A
Product requirement with full function reliability
approved.
l
l
l
l
Super Low Gate Charge
Green Device Available
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
SOP8 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
ID@TA=25℃
ID@TA=70℃
IDM
±20
V
Continuous Drain Current, VGS @ 10V
1
2.5
A
1
2
A
10
A
6.1
mJ
11
A
1.5
W
Pulsed Drain Current
2
EAS
Single Pulse Avalanche Energy
IAS
Avalanche Current
3
3
PD@TA=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.hs-semi.cn
Thermal Resistance Junction-Case
Ver 2.0
1
Max.
Unit
85
℃/W
36
℃/W
1
HSM0204
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
Typ.
Max.
Unit
100
V
Reference to 25℃ , ID=1mA
0.098
V/℃
VGS=10V , ID=2A
90
112
mΩ
VGS=4.5V , ID=1A
95
120
mΩ
1.0
1.5
2.5
V
mV/℃
VGS=0V , ID=250uA
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Min.
2
VGS=VDS , ID =250uA
-4.57
VDS=80V , VGS=0V , TJ=25℃
10
VDS=80V , VGS=0V , TJ=55℃
100
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=2A
12
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2
4
Ω
Qg
Total Gate Charge (10V)
19.5
Qgs
Gate-Source Charge
3.2
Qgd
Gate-Drain Charge
3.6
16.2
Td(on)
VDS=60V , VGS=10V , ID=2A
Turn-On Delay Time
uA
nC
Rise Time
VDD=50V , VGS=10V , RG=3.3Ω
3
Turn-Off Delay Time
ID=1A
44
Fall Time
2.6
Ciss
Input Capacitance
1535
Coss
Output Capacitance
60
Crss
Reverse Transfer Capacitance
37.4
Min.
Typ.
Max.
Unit
4
A
8
A
1.2
V
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Conditions
1,5
Continuous Source Current
Pulsed Source Current
2,5
Diode Forward Voltage
2
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=11A
4.The power dissipation is limited by 175℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSM0204
Typical Characteristics
96
15
ID=2A
VGS=10V
VGS=7V
94
VGS=5V
VGS=4.5V
RDSON (mΩ)
ID Drain Current (A)
12
9
92
VGS=3V
6
90
3
88
1
1.5
2
4
2.5
VDS , Drain-to-Source Voltage (V)
Fig.1 Typical Output Characteristics
6
VGS (V)
8
10
Fig.2 On-Resistance vs. Gate-Source
10
IS Source Current(A)
8
6
TJ=150℃
4
TJ=25℃
2
0.25
0.50
0.75
1.00
VSD , Source-to-Drain Voltage (V)
Fig.4 Gate-Charge Characteristics
Fig.3 Forward Characteristics Of Reverse
2.5
Normalized On Resistance
1.8
2.0
Normalized VGS(th)
1.4
1.5
1
1.0
0.6
0.2
0.5
-50
100
150
-50
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
TJ , Junction Temperature (℃)
150
Fig.6 Normalized R DSON vs. TJ
Ver 2.0
3
HSM0204
10000
10.00
F=1.0MHz
100us
1ms
1000
1.00
10ms
ID (A)
Capacitance (pF)
Ciss
100
100ms
0.10
Coss
o
Crss
TA=25 C
Single Pulse
10
1
5
9
13
17
21
0.01
0.01
25
VDS , Drain to Source Voltage (V)
DC
0.1
Fig.7 Capacitance
1
VDS (V)
10
100
1000
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.01
P DM
0.01
T ON
T
D = TON/T
SINGLE
TJpeak = TC+P DMXRθJC
0.001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
Td(on)
Tr
Ton
Td(off)
VDD
IAS
Tf
VGS
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
BVDSS
BVDSS-VDD
BVDSS
10%
VGS
1
L x IAS2 x
2
Fig.11 Unclamped Inductive Switching
Ver 2.0
4
HSM0204
Ordering Information
Part Number
HSM0204
www.hs-semi.cn
Package code
SOP-8
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSM0204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.05470
- 50+1.86873
- 150+1.78902
- 500+1.55661
- 2500+1.51233
- 5000+1.48565
