HSBB3105
Description
Product Summary
The HSBB3105 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSBB3105 meet the RoHS and Green Product
VDS
-30
V
RDS(ON),max
14
mΩ
ID
-42
A
requirement 100% EAS guaranteed with full
function reliability approved.
l
l
l
l
l
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
PRPAK3X3 Pin Configuration
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
ID@TA=25℃
ID@TA=70℃
10s
Steady State
Units
-30
V
±20
V
Continuous Drain Current, VGS @ -10V
1
-42
A
1
-27
A
1
-14.3
-9
A
1
-11.4
-7.2
A
2
IDM
Pulsed Drain Current
EAS
Single Pulse Avalanche Energy
IAS
Avalanche Current
-130
A
125
mJ
-50
A
37
W
3
Total Power Dissipation
4
PD@TA=25℃
4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
PD@TC=25℃
4.2
1.67
W
Thermal Data
Symbol
RθJA
RθJA
RθJC
www.hs-semi.cn
Parameter
Typ.
Thermal Resistance Junction-Ambient
1
1
Thermal Resistance Junction-Ambient (t ≤10s)
Thermal Resistance Junction-Case
Ver 2.0
1
Max.
Unit
75
℃/W
30
℃/W
3.36
℃/W
1
HSBB3105
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
Conditions
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
2
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
VGS=-10V , ID=-30A
11
14
VGS=-4.5V , ID=-15A
17
22
-1.0
-2.5
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
mΩ
V
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-30A
30
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
9
Ω
Qg
Total Gate Charge (-4.5V)
22
Qgs
Gate-Source Charge
8.7
Qgd
Gate-Drain Charge
7.2
Turn-On Delay Time
8
Td(on)
VDS=-15V , VGS=-4.5V , ID=-15A
uA
nC
Rise Time
VDD=-15V , VGS=-10V , RG=3.3Ω
73.7
Turn-Off Delay Time
ID=-15A
61.8
Fall Time
24.4
Ciss
Input Capacitance
2215
Coss
Output Capacitance
310
Crss
Reverse Transfer Capacitance
237
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-25
A
VGS=0V , IS=-1A , TJ=25℃
-1
V
IF=-15A , dI/dt=100A/µs ,
19
nS
TJ=25℃
9
nC
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
1,5
Continuous Source Current
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-25V,VGS=-10V,L=0.1mH,IAS=-50A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
Typical Characteristics
www.hs-semi.cn
Ver 2.0
2
HSBB3105
150
-ID Drain Current (A)
125
VGS=-10V
VGS=-7V
100
75
VGS=-5V
50
VGS=-4.5V
VGS=-3V
25
1
1.5
2
2.5
3
3.5
4
-VDS , Drain-to-Source Voltage (V)
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
12
10
-VGS Gate to Source Voltage (V)
-IS Source Current(A)
VDS=-15V
8
TJ=150℃
TJ=25℃
4
0.25
0.50
0.75
ID=-15A
8
6
4
2
-VSD , Source-to-Drain Voltage (V)
18
27
QG , Total Gate Charge (nC)
36
45
Fig.4 Gate-Charge Characteristics
Fig.3 Source Drain Forward Characteristics
2.0
Normalized On Resistance
1.5
Normalized VGS(th)
9
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature (℃ )
-50
150
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized R DSON vs. TJ
Ver 2.0
3
HSBB3105
1000.00
10000
F=1.0MHz
10us
Ciss
1000
100us
10.00
Coss
-ID (A)
Capacitance (pF)
100.00
10ms
100ms
1.00
Crss
100
1ms
DC
0.10
TC=25℃
Single Pulse
0.01
10
1
5
9
13
17
21
0.1
25
1
-VDS , Drain to Source Voltage (V)
Fig.7 Capacitance
10
-VDS (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
SINGLE PULSE
TON
T
D = TON/T
TJpeak = TC + PDM x RθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Switching
Ver 2.0
4
HSBB3105
Ordering Information
Part Number
HSBB3105
www.hs-semi.cn
Package code
PRPAK3*3
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSBB3105”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.33575
- 50+1.08875
- 150+0.98302
- 500+0.85094
- 3000+0.69282
- 6000+0.65751
- 国内价格
- 5+0.74880
- 20+0.73600
- 100+0.71040
