HSM1564
Dual N-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSM1564 is the high cell density trenched Nch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSM1564 meet the RoHS and Green Product
VDS
60
V
RDS(ON),TYP
13.5
mΩ
ID
8
A
requirement, 100% EAS guaranteed with full
function reliability approved.
Dual SOP8 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
60
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @
10V1
8
A
ID@TA=70℃
Continuous Drain Current, VGS @ 10V1
6
A
IDM
Pulsed Drain Current2
32
A
EAS
Single Pulse Avalanche Energy3
150
mJ
2
W
PD@TA=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.hs-semi.cn
Thermal Resistance Junction-Case
Ver 2.0
1
Max.
Unit
75
℃/W
24
℃/W
1
HSM1564
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
60
V
VGS=10V , ID=8A
13.5
17
VGS=4.5V , ID=6A
15.5
m
1.2
2
3
V
-5.24
mV/℃
VDS=48V , VGS=0V , TJ=25℃
1
VDS=48V , VGS=0V , TJ=55℃
5
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=8A
18
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
3.2
Qg
Total Gate Charge (4.5V)
53
Qgs
Gate-Source Charge
7.5
Qgd
Gate-Drain Charge
12
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Td(on)
VGS=VDS , ID =250uA
VDS=30V , VGS=10V , ID=6A
nC
8
Rise Time
VDD=30V , VGS=10V , RG=3,
5.5
Turn-Off Delay Time
ID=4A
29
Fall Time
4.6
Ciss
Input Capacitance
2600
Coss
Output Capacitance
180
Crss
Reverse Transfer Capacitance
123
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
8
A
VGS=0V , IS=1A , TJ=25℃
1.2
V
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=30V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,5
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSM1564
Typical Characteristics
Fig.1 On-Region Characteristics
Fig.2 Transfer Characteristics
Fig.3 On-Resistance vs. Drain Curent and
Fig.4 On-Resistance vs.Junction
Gate Voltage
Temperature
Fig.5 On-Resistance vs. Gate-Source
Fig.6 Body-Diode Characteristics
Voltage
www.hs-semi.cn
Ver 2.0
3
HSM1564
Ordering Information
Part Number
HSM1564
www.hs-semi.cn
Package code
SOP-8
Ver 2.0
Packaging
4000/Tape&Reel
4
很抱歉,暂时无法提供与“HSM1564”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.49472
- 50+1.16813
- 150+1.02816
- 500+0.81465
- 2500+0.73689
- 4000+0.69012
