HSCA2030
Dual N-Ch Fast Switching MOSFETs
General Description
Product Summary
The HSCA2030 is the highest performance trench
N-ch MOSFETs with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the small power switching and load
switch applications.
The HSCA2030 meet the RoHS and Green Product
requirement with full function reliability approved.
VDS
V
RDS(ON),max
5.8
mΩ
ID
56
A
DFN3x3 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Pin1
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±8
V
ID@TC=25℃
Continuous Drain Current, VGS @ 4.5V1
56
A
ID@TC=100℃
35.6
A
ID@TA=25℃
19
A
ID@TA=70℃
15
A
IDM
Pulsed Drain Current2
100
A
PD@TC=25℃
Total Power Dissipation1
31
W
PD@TA=25℃
3.6
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
Max.
Unit
RθJA
Thermal Resistance Junction-Ambient 1
35
℃/W
RθJC
Thermal Resistance Junction-Case1
4
℃/W
www.hs-semi.cn
Ver 2.0
1
HSCA2030
N-Channel Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
RDS(ON)
VGS(th)
Parameter
Drain-Source Breakdown Voltage
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
VGS=4.5V , ID=3A
4.3
5.8
VGS=3.9V , ID=3A
4.5
6.5
VGS=2.5V , ID=3A
5
7
VGS=1.8V , ID=3A
7
11
VGS=VDS , ID =250uA
0.4
1.0
VDS=16V , VGS=0V , TJ=25℃
1
VDS=16V , VGS=0V , TJ=55℃
5
m
V
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±8V , VDS=0V
±10
uA
gfs
Forward Transconductance
VDS=5V , ID=3A
42
S
38
33
4.5
12
Qg
Total Gate Charge (4.5V)
Total Gate Charge (3.9V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=10V , ID=3A
uA
nC
22
Rise Time
VDD=16V , VGS=4.5V , RG=6
41
Turn-Off Delay Time
ID=3A
77
Fall Time
21
Ciss
Input Capacitance
3165
Coss
Output Capacitance
380
Crss
Reverse Transfer Capacitance
325
Min.
Typ.
Max.
Unit
30
A
100
A
1.2
V
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=10V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
IS
Continuous Source Current1
ISM
Pulsed Source Current2
VSD
Diode Forward Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=3A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper, t ≤10s.
2.The data tested by pulsed , pulse width ≦ 10us , duty cycle ≦ 1%
www.hs-semi.cn
Ver 2.0
2
HSCA2030
Typical Characteristics
ID Drain Current (A)
ID=3A
RDSON (mΩ)
VGS=4
VGS=3.
VGS=2.
VGS=1.
VGS=1
VDS , Drain-to-Source Voltage
(V)
VGS (V)
Fig.1 Typical Output Characteristics
VGS Gate to Source
Voltage (V)
Fig.2 On-Resistance vs. Gate-Source
VDS=10
VID=3A
Voltage
QG , Total Gate Charge (nC)
Fig.3 Forward Characteristics Of Reverse
Fig.4 Gate-Charge Characteristics
diode
Fig.5 VGS(th) vs. TJ
www.hs-semi.cn
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSCA2030
Ciss
Capacitance (pF)
ID (A)
100us
1m
10m
100
D
TA=25oC
Cos
Crs
F=1.0MHz
-VDS , Drain to Source Voltage (V)
VDS (V)
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
P DM
0.01
T ON
T
SINGLE
D = TON/T
TJpeak = TA+P DMXRθJA
0.001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
HSCA2030
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSCA2030”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.98267
- 50+1.62346
- 150+1.46945
- 500+1.27743
- 3000+1.04879
- 6000+0.99738
