HSL10P06
P-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSL10P06 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSL10P06 meet the RoHS and Green Product
requirement,100% EAS guaranteed with full
function reliability approved.
VDS
-60
V
RDS(ON),max
70
mΩ
ID
-10
A
SOT223 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=70℃
IDM
IAS
PD@TA=25℃
±20
V
Continuous Drain Current, VGS @
-10V1
-10
A
-10V1
-3
A
-28
A
-26
A
1.5
W
Pulsed Drain
Current2
Avalanche Current
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
70
℃/W
36
℃/W
1
HSL10P06
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
Reference to 25℃ , ID=-1mA
-0.03
V/℃
VGS=-10V , ID=-5A
55
70
VGS=-4.5V , ID=-3A
64
105
-1.0
-2.5
V
4.08
mV/℃
VDS=-48V , VGS=0V , TJ=25℃
1
VDS=-48V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-10V , ID=-2A
15
S
Qg
Total Gate Charge (-4.5V)
9.6
Qgs
Gate-Source Charge
3.4
Qgd
Gate-Drain Charge
2.62
Td(on)
Turn-On Delay Time
VDS=-48V , VGS=-4.5V , ID=-10A
nC
27.4
Rise Time
VDS=-15V , VGS=-10V , RG=3.3,
19.4
Turn-Off Delay Time
ID=-1A
60.2
Fall Time
7.4
Ciss
Input Capacitance
1431
Coss
Output Capacitance
99
Crss
Reverse Transfer Capacitance
78
Min.
Typ.
Max.
Unit
-10
A
-28
A
-1.2
V
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Continuous Source
Current1,5
Pulsed Source
Current2,5
Diode Forward
Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-25V,VGS=-10V,L=0.1mH,IAS=-26A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSL10P06
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSL10P06
www.hs-semi.cn
Ver 2.0
4
HSL10P06
Ordering Information
Part Number
HSL10P06
www.hs-semi.cn
Package code
SOT-223
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSL10P06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.00354
- 50+0.87632
- 150+0.82188
- 500+0.75384
- 3000+0.72360
- 6000+0.70546
