HSS2012
N-Ch 20V Fast Switching MOSFETs
Description
Product Summary
The HSS2012 is the high cell density trenched Nch MOSFETs, which provides excellent RDSON
and efficiency for most of the small power switching
and load switch applications.
The HSS2012 meet the RoHS and Green Product
requirement with full function reliability approved.
VDS
V
RDS(ON),typ
10
mΩ
ID
6.8
A
SOT23 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±12
V
ID@TA=25℃
Continuous Drain Current, VGS @ 4.5V1
6.8
A
ID@TA=70℃
5.3
A
IDM
Pulsed Drain Current2
26
A
PD@TA=25℃
Total Power Dissipation3
1.25
W
PD@TA=70℃
0.76
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Max.
Unit
RθJA
Thermal Resistance Junction-ambient 1
100
℃/W
www.hs-semi.cn
Ver2.0
1
HSS2012
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
Reference to 25℃ , ID=1mA
0.018
V/℃
VGS=4.5V , ID=6A
10
14
VGS=2.5V , ID=5A
21
0.5
1.0
V
-3.1
mV/℃
VDS=16V , VGS=0V , TJ=25℃
1
VDS=16V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
m
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=4A
30
S
Qg
Total Gate Charge (4.5V)
13
Qgs
Gate-Source Charge
1.5
Qgd
Gate-Drain Charge
2.6
VDS=15V , VGS=4.5V , ID=4A
uA
nC
9
Rise Time
VDS=10V , VGS=4.5V , RG=3.3
28
Turn-Off Delay Time
ID=4A
33
Fall Time
36
Ciss
Input Capacitance
960
Coss
Output Capacitance
140
Crss
Reverse Transfer Capacitance
110
Min.
Typ.
Max.
Unit
6.8
A
26
A
1.2
V
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=10V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
IS
Continuous Source Current1,4
ISM
Pulsed Source Current2,4
VSD
Diode Forward Voltage2
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver2.0
2
HSS2012
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
Voltage
IS Source Current(A)
6
4
TJ=175℃
TJ=25℃
2
0.6
0.9
VSD , Source-to-Drain Voltage (V)
1.2
Fig.3 Forward Characteristics Of Reverse
Fig.4 Gate-Charge Characteristics
diode
Normalized On Resistance
1.8
Normalized VGS(th)
1.4
1
0.6
0.2
-50
100
150
TJ , Junction Temperature (℃)
TJ ,Junction Temperature (℃ )
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
Fig.6 Normalized RDSON vs. TJ
Ver2.0
3
HSS2012
1000
100.00
Ciss
100us
10ms
ID (A)
Capacitance (pF)
10.00
100
Coss
100ms
1.00
1s
Crss
0.10
DC
TA=25℃
Single Pulse
F=1.0MHz
10
1
4
7
10
13
16
19
0.01
22
0.1
VDS Drain to Source Voltage (V)
1
Fig.7 Capacitance
10
VDS (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (R θJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
0.01
PDM
0.001
TON
SINGLE PULSE
T
D = TON/T
TJpeak = TA + PDM x RθJA
0.0001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver2.0
4
HSS2012
Ordering Information
Part Number
HSS2012
www.hs-semi.cn
Package code
SOT-23L
Ver2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSS2012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27227
- 100+0.21525
- 300+0.18674
