HSBL020N08
N-Ch 80V Fast Switching MOSFETs
Description
Product Summary
The HSBL020N08 is the high cell density SGT Nch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous
rectification applications.
The HSBL020N08 meet the RoHS and HalogenFree compliant product requirement, 100% EAS
guaranteed with full function reliability approved.
VDS
80
V
RDS(ON),typ
1.4
mΩ
ID
240
A
TOLL Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
80
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1,6
240
A
ID@TC=100℃
100
A
IDM
Pulsed Drain Current2
730
A
2500
mJ
225
W
EAS
PD@TC=25℃
Single Pulse Avalanche
Total Power
Energy3
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Max.
Unit
RθJA
Thermal Resistance Junction-Ambient 1
60
℃/W
RθJC
Thermal Resistance Junction-Case1
0.54
℃/W
www.hs-semi.cn
Ver 2.0
Typ.
1
HSBL020N08
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
On-Resistance2
RDS(ON)
Static Drain-Source
VGS(th)
Gate Threshold Voltage
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
80
V
VGS=10V , ID=50A
1.4
2.0
m
VGS=VDS , ID =250uA
2
3
4
V
VDS=80V , VGS=0V , TJ=25℃
1
VDS=80V , VGS=0V , TJ=125℃
5
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2
204
54
Qg
Total Gate Charge (10V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
47
Td(on)
Turn-On Delay Time
39
Tr
Rise Time
VDD=40V , VGS=10V , RL=3,
136
Td(off)
Turn-Off Delay Time
ID=20A
121
VDS=40V , VGS=10V , ID=50A
nC
ns
Tf
Fall Time
156
Ciss
Input Capacitance
13650
Coss
Output Capacitance
20100
Crss
Reverse Transfer Capacitance
580
Min.
Typ.
Max.
Unit
VDS=45V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
Parameter
Conditions
VSD
Diode Forward Voltage2
VGS=0V , IS=50A , TJ=25℃
0.85
1.2
V
Trr
Body Diode Reverse Recovery Time
If=30A, DI/dt=500A/us
112
ns
Qrr
Body Diode Reverse Recovery charge
313
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
5.The maximum current rating is package limited.
www.hs-semi.cn
Ver 2.0
2
HSBL020N08
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSBL020N08
www.hs-semi.cn
Ver 2.0
4
HSBL020N08
www.hs-semi.cn
Ver 2.0
5
HSBL020N08
www.hs-semi.cn
Ver 2.0
6
很抱歉,暂时无法提供与“HSBL020N08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.67880
- 10+6.32880
- 30+5.59440
