HSU6115
P-Ch 60V Fast Switching MOSFETs
Product Summary
Description
The HSU6115 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications.
The HSU6115 meet the RoHS and Green
VDS
-60
V
RDS(ON),max
25
mΩ
ID
-35
A
Product requirement, 100% EAS guaranteed
with full function reliability approved.
TO252 Pin Configuration
l
l
l
l
l
Super Low Gate Charge
100% EAS Guaranteed
Green Device Available
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
±20
V
Continuous Drain Current, -VGS @ -10V
1
-35
A
1
-27
A
2
IDM
Pulsed Drain Current
EAS
Single Pulse Avalanche Energy
IAS
Avalanche Current
-70
A
113
mJ
47.6
A
52.1
W
3
4
PD@TC=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.hs-semi.cn
Thermal Resistance Junction-Case
Ver 2.0
1
Max.
Unit
62
℃/W
2.4
℃/W
1
HSU6115
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
2
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
Reference to 25℃ , ID=-1mA
-0.035
V/℃
VGS=-10V , ID=-18A
25
VGS=-4.5V , ID=-12A
33
-1.0
-2.5
V
4.28
mV/℃
VDS=-48V , VGS=0V , TJ=25℃
1
VDS=-48V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-10V , ID=-18A
23
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
7
Ω
Qg
Total Gate Charge (-4.5V)
25
Qgs
Gate-Source Charge
6.7
Qgd
Gate-Drain Charge
5.5
Td(on)
VDS=-20V , VGS=-4.5V , ID=-12A
nC
38
Rise Time
VDD=-15V , VGS=-10V , RG=3.3Ω,
23.6
Turn-Off Delay Time
ID=-1A
100
Fall Time
6.8
Ciss
Input Capacitance
3635
Coss
Output Capacitance
224
Crss
Reverse Transfer Capacitance
141
Min.
Typ.
Max.
Unit
-35
A
-70
A
-1
V
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
VSD
Parameter
Conditions
1,5
Continuous Source Current
Pulsed Source Current
2,5
Diode Forward Voltage
2
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Note :
2
1.The data tested by surface mounted on a 1 inch FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-25V,VGS=-10V,L=0.1mH,IAS=-47.6A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSU6115
Typical Characteristics
30
12
ID=-12A
28
VGS=-10V
8
RDSON (mΩ)
-ID Drain Current (A)
10
VGS=-7V
26
VGS=-5V
6
VGS=-4.5V
24
4
22
VGS=-3V
2
0.5
0.75
-VDS Drain-to-Source Voltage (V)
1
2
4
Fig.1 Typical Output Characteristics
6
8
-VGS (V)
10
Fig.2 On-Resistance v.s Gate-Source
10
12
VDS=-20V
-VGS Gate to Source Voltage (V)
-IS Source Current(A)
10
8
6
TJ=150℃
TJ=25℃
4
2
0.4
0.6
0.8
ID=-12A
8
6
4
2
Fig.3 Forward Characteristics Of Reverse
40
60
Fig.4 Gate-Charge Characteristics
2.0
Normalized On Resistance
1.5
Normalized -VGS(th)
QG , Total Gate Charge (nC)
-VSD , Source-to-Drain Voltage (V)
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature ( ℃)
-50
150
Fig.5 Normalized VGS(th) v.s TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized R DSON v.s TJ
Ver 2.0
3
HSU6115
10000
100.00
F=1.0MHz
100us
Capacitance (pF)
Ciss
10.00
1000
-ID (A)
1ms
100
10ms
1.00
Coss
Crss
100ms
DC
0.10
o
Tc=25 C
Single Pulse
0.01
10
1
5
9
13
17
-VDS Drain to Source Voltage(V)
21
0.1
25
1
Fig.7 Capacitance
10
-VDS (V)
100
1000
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.3
0.1
0.1
0.05
0.02
PDM
0.01
D = TON/T
SINGLE PULSE
0.01
0.00001
TON
0.0001
T
TJpeak = TC + PDM x RθJC
0.001
0.01
0.1
1
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Waveform
Ver 2.0
4
HSU6115
Ordering Information
Part Number
HSU6115
www.hs-semi.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSU6115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.67840
- 50+2.08440
- 150+1.83600
- 500+1.37160
- 2500+1.23120
- 5000+1.14480
- 国内价格
- 1+2.69280
- 10+2.65241
- 500+1.49490
- 1000+1.47248
- 2500+1.36620
