HSU100P03
P-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSU100P03 is the high cell density trenched
P-ch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous buck
converter applications.
The HSU100P03 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
VDS
-30
V
RDS(ON),typ
4
mΩ
ID
-100 A
TO252 Pin Configuration
Super Low Gate Charge
100% EAS Guaranteed
Green Device Available
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ -10V1,6
-100
A
ID@TC=100℃
-65
A
IDM
Pulsed Drain Current2
-400
A
EAS
Single Pulse Avalanche Energy3
210
mJ
IAS
Avalanche Current
-30
A
PD@TC=25℃
Total Power Dissipation4
105
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
-55 to 175
Thermal Data
Symbol
RθJA
RθJC
www.hs-semi.cn
Parameter
Thermal Resistance Junction-ambient 1(t≦10S)
Thermal Resistance Junction-ambient 1(Steady State)
Thermal Resistance Junction-case 1
Ver 2.0
Typ.
Max.
Unit
℃/W
50
℃/W
1.45
℃/W
1
HSU100P03
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
VGS=-10V , ID=-20A
4
5.3
m
VGS=-4.5V , ID=-15A
5.7
8.2
m
VGS=VDS , ID =-250uA
V
-1.0
-2.5
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=±20V , VDS=0V
±100
45
9
IGSS
Gate-Source Leakage Current
Qg
Total Gate Charge (-10V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
12
Turn-On Delay Time
17
Td(on)
Tr
Td(off)
VDS=-15V , VGS=-10V , ID=-30A
Rise Time
VDD=-15V , VGS=-10V , RG=3.3,
19
Turn-Off Delay Time
ID=-30A
68
uA
nA
nC
ns
Fall Time
23
Ciss
Input Capacitance
9300
Coss
Output Capacitance
989
Crss
Reverse Transfer Capacitance
700
Min.
Typ.
Max.
Unit
Tf
VDS=-15V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Conditions
Continuous Source Current1,5
VG=VD=0V , Force Current
-100
A
Diode Forward Voltage2
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-15V,VGS=-10V,L=0.5mH,Rg=25R,IAS=-30A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation
6.The maximum current rating is package limited.
www.hs-semi.cn
Ver 2.0
2
HSU100P03
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSU100P03
www.hs-semi.cn
Ver 2.0
4
HSU100P03
Ordering Information
Part Number
HSU100P03
www.hs-semi.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSU100P03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.32640
- 10+2.62440
- 30+2.32200
- 100+1.94400
- 500+1.77120
- 1000+1.67400
