HSBA6074
N-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSBA6074 is the high cell density SGT N-ch
MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSBA6074 meet the RoHS and Green Product
requirement, 100% EAS guaranteed with full
function reliability approved.
VDS
60
V
RDS(ON),typ
1.7
mΩ
ID
100
A
PRPAK5X6 Pin Configuration
Motor Control
100% EAS Guaranteed
DC/DC Converter.
Excellent CdV/dt effect decline
Synchronous rectifier applications.
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
60
V
VGS
Gate-Source Voltage
±20
V
100
A
ID@TC=25℃
ID@TC=100℃
Continuous Drain
Current1,6
Continuous Drain
Current1,6
66
A
IDM
Pulsed Drain Current2
400
A
EAS
Single Pulse Avalanche Energy3
306
mJ
IAS
Avalanche Current
35
A
83
W
PD@TC=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
Typ.
1
Max.
Unit
55
℃/W
1.1
℃/W
1
HSBA6074
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
60
V
VGS=10V , ID=20A
1.7
2.1
m
VGS=4.5V , ID=20A
2.3
3.2
m
VGS=VDS , ID =250uA
1.2
2.3
V
VDS=52V , VGS=0V , TJ=25℃
1
VDS=52V , VGS=0V , TJ=55℃
5
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=20A
60
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.6
Qg
Total Gate Charge (10V)
102
Qgs
Gate-Source Charge
16
Qgd
Gate-Drain Charge
28
VDS=30V , VGS=10V , ID=20A
nC
15
Rise Time
VDD=30V , VGS=10V , RG=3,
12
Turn-Off Delay Time
ID=20A
60
Fall Time
19
Ciss
Input Capacitance
5480
Coss
Output Capacitance
1822
Crss
Reverse Transfer Capacitance
88
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
100
A
VGS=0V , IS=1A , TJ=25℃
1.2
V
50
nS
72
nC
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=30V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,5
Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
IF=20A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=50V,VGS=10V,L=0.5mH,IAS=35A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
6.The maximum current rating is package limited.
www.hs-semi.cn
Ver 2.0
2
HSBA6074
Typical Characteristics
Fig.2 On-Resistance vs G-S Voltage
Fig.1 Typical Output Characteristics
Fig.4 Gate-Charge Characteristics
Fig.3 Diode Forward Voltage vs. Current
Fig.5 Normalized VGS(th) vs TJ
www.hs-semi.cn
Fig.6 Normalized RDSON vs TJ
Ver 2.0
3
HSBA6074
Fig.8 Safe Operating Area
Fig.7 Capacltance
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
BVDSS
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
Fig.11 Unclamped Inductive Switching
Waveform
www.hs-semi.cn
Ver 2.0
4
HSBA6074
Ordering Information
Part Number
HSBA6074
www.hs-semi.cn
Package code
PRPAK5*6
Ver 2.0
Packaging
3000/Tape&Reel
5
很抱歉,暂时无法提供与“HSBA6074”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.22720
- 10+4.69800
- 30+4.41720
- 100+4.08240
- 500+3.94200
- 1000+3.87720
