HSU100P04
P-Ch 40V Fast Switching MOSFETs
Description
Product Summary
The HSU100P04 is the high cell density trenched
P-ch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous buck
converter applications.
The HSU100P04 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
VDS
-40
V
RDS(ON),max
5.8
mΩ
ID
-100 A
TO252 Pin Configuration
Super Low Gate Charge
100% EAS Guaranteed
Excellent CdV/dt effect decline
Green Device Available
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-40
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ -10V1
-100
A
ID@TC=100℃
-64
A
IDM
Pulsed Drain Current2
-295
A
380
mJ
EAS
IAS
PD@TC=25℃
PD@TA=25℃
Single Pulse Avalanche
Energy3
Avalanche Current
-50
A
Total Power
Dissipation4
52.1
W
Total Power
Dissipation4
2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
62
℃/W
1.8
℃/W
1
HSU100P04
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-40
V
Reference to 25℃ , ID=-1mA
-0.023
V/℃
VGS=-10V , ID=-20A
4.6
5.8
VGS=-4.5V , ID=-10A
6
9.1
-1.2
-1.8
-2.5
V
4.74
mV/℃
VDS=-32V , VGS=0V , TJ=25℃
1
VDS=-32V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =-250uA
m
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-15V , ID=-18A
50
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
7
14
Qg
Total Gate Charge
115
24
VDS=-20V , VGS=-10V , ID=-12A
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
26
Td(on)
Turn-On Delay Time
19
nC
Rise Time
VDD=-20V , VGS=-10V , RG=3,
12
Turn-Off Delay Time
ID=-12A
80
Fall Time
18
Ciss
Input Capacitance
7090
Coss
Output Capacitance
930
Crss
Reverse Transfer Capacitance
722
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-100
A
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
Tr
Td(off)
Tf
VDS=-20V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,5
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-32V,VGS=-10V,L=0.1mH,IAS=-50A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSU100P04
Typical Characteristics
www.hs-semi.cn
Ver 2.0
3
HSU100P04
www.hs-semi.cn
Ver 2.0
4
HSU100P04
Ordering Information
Part Number
HSU100P04
www.hs-semi.cn
Package code
TO252-2
Ver 2.0
Packaging
2500/Tape&Reel
5
很抱歉,暂时无法提供与“HSU100P04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.13440
- 10+5.02200
- 30+4.47120
- 100+3.92040
- 500+3.40200
- 1000+3.22920
