HSM24P03
P-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSM24P03 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and
gate charge for most of the synchronous buck
converter applications.
The HSM24P03 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
Super Low Gate Charge
100% EAS Guaranteed
Green Device Available
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
VDS
-30
V
RDS(ON),typ
3.8
mΩ
ID
-24
A
SOP8 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ -10V1
-24
A
ID@TC=100℃
A
IDM
Pulsed Drain Current2
-96
A
2.1
W
4
PD@TA=25℃
Total Power Dissipation
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
RθJA
RθJC
www.hs-semi.cn
Parameter
Thermal Resistance Junction-ambient 1(t≦10S)
Thermal Resistance Junction-ambient 1(Steady State)
Thermal Resistance Junction-case 1
Ver 2.0
Typ.
Max.
Unit
℃/W
60
℃/W
24
℃/W
1
HSM24P03
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
VGS=-10V , ID=-17A
3.8
4.8
m
VGS=-4.5V , ID=-10A
5.8
7.8
m
VGS=VDS , ID =-250uA
V
-1.2
-1.6
-2.2
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-10
VGS=±20V , VDS=0V
±100
110
15
IGSS
Gate-Source Leakage Current
Qg
Total Gate Charge (-10V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
18
Turn-On Delay Time
28
Td(on)
Tr
Td(off)
VDS=-15V , VGS=-10V , ID=-10A
Rise Time
VDD=-15V , VGS=-10V , RG=6,
17
Turn-Off Delay Time
ID=-1A
180
uA
nA
nC
ns
Fall Time
73
Ciss
Input Capacitance
6240
Coss
Output Capacitance
780
Crss
Reverse Transfer Capacitance
410
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-24
A
VGS=0V , IS=-1A , TJ=25℃
-1
V
Tf
VDS=-25V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source
Diode Forward
Current1,5
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The power dissipation is limited by 150℃ junction temperature
4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSM24P03
Typical Characteristics
Fig.2 Normalized RDSON vs. TJ
Fig.1 Continuous Drain Current vs. TC
Fig.3 Normalized Vth vs. Tj
Fig.4 Gate Charge Waveform
Fig.5 Normalized Transient Impedance
www.hs-semi.cn
Fig.6 Maximum Safe Operation Area
Ver 2.0
3
HSM24P03
Fig.8 Unclamped Inductive Switching Waveform
Fig.7 Switching Time Waveform
www.hs-semi.cn
Ver 2.0
4
HSM24P03
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSM24P03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.73680
- 10+3.03480
- 30+2.73240
- 100+2.35440
- 500+1.99800
- 1000+1.90080
