HYG035N06LS1D
HYG035N06LS1D
    HUAYI(华羿微)
    TO-252(DPAK)
    单N沟道,电流:150A,耐压:65V
HYG035N06LS1D 数据手册
HYG035N06LS1D Single N-Channel Enhancement Mode MOSFET Feature  Pin Description 65V/150A RDS(ON)= 3.5 mΩ(typ.) @VGS = 10V RDS(ON)= 5.3 mΩ(typ.) @VGS = 4.5V  100% Avalanche Tested  Reliable and Rugged  G Halogen- Free Devices Available D S Applications  Load Switch  Motor drive for electric tools Single N-Channel MOSFET Ordering and Marking Information Package Code D D: TO-252-2L G035N06 Date Code XYMXXXXXX XYMXXXXXX Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plate TermiNation finish;which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hymexa.com 1 V1.0 2019 HYG035N06LS1D Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (Tc=25℃ Unless Otherwise Noted) VDSS Drain-Source Voltage 65 V VGSS Gate-Source Voltage +20/-12 V TJ Junction Temperature Range -55 to 175 ℃ TSTG Storage Temperature Range -55 to 175 ℃ Tc=25℃ 150 A Tc=25℃ 410 A Tc=25℃ 150 A Tc=100℃ 107 A Tc=25℃ 183 W Tc=100℃ 91.5 W IS Source Current-Continuous(Body Diode) Mounted on Large Heat Sink Note: IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RJC Thermal Resistance, Junction-to-Case 0.82 ℃/W RJA Thermal Resistance, Junction-to-Ambient ** 60.0 ℃/W EAS Single Pulsed-Avalanche Energy *** 209 mJ L=0.3mH * Repetitive rating;pulse width limited by max.junction temperature. ** Surface mounted on FR-4 board. *** Limited by TJmax , starting TJ=25℃, L = 0.3mH, RG =25Ω., VGS =10V. Electrical Characteristics(Tc =25℃ Unless Otherwise Noted) Symbol Parameter Test Conditions HYG035N06LS1 Unit Min Typ. Max 65 - - V - - 1 μA - - 50 μA Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Drain-to-Source Leakage Current VGS(th) IGSS RDS(ON) VGS=0V,IDS=250μA VDS=65V,VGS=0V TJ=125℃ Gate Threshold Voltage VDS=VGS, IDS=250μA 1 1.5 3 V Gate-Source Leakage Current VGS=+20V/-12V,VDS=0V - - ±100 nA VGS=10V,IDS=20A - 3.5 4.0 mΩ VGS=4.5V,IDS=20A - 5.3 6.0 mΩ ISD=20A,VGS=0V - 0.8 1.2 V - 42 - ns - 35 - nC Drain-Source On-State Resistance Diode Characteristics VSD* Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge www.hymexa.com ISD=10A,dISD/dt=100A/μs 2 V1.0 2019 HYG035N06LS1D Electrical Characteristics (Cont.) (Tc =25℃ Unless Otherwise Noted) Symbol Parameter Test Conditions HYG035N06LS1 Min Typ. Max Unit Dynamic Characteristics RG Gate Resistance VGS=0V,VDS=0V,F=1MHz - 1.8 - Ciss Input Capacitance VGS=0V, - 3687 - Coss Output Capacitance VDS=25V, - 1610 - Crss Reverse Transfer Capacitance Frequency=1.0MHz - 112 - td(ON) Turn-on Delay Time - 15 - Tr Turn-on Rise Time VDD=30V,RG=6Ω, - 29 - td(OFF) Turn-off Delay Time IDS=10A,VGS=10V - 92 - - 95 - - 76.3 - Tf Turn-off Fall Time Gate Charge Ω pF ns Characteristics Qg Total Gate Charge(VGS=10V) Qg Total Gate Charge(VGS=4.5V) VDS =48V, VGS=10V, - 41.7 - Qgs Gate-Source Charge ID=20A - 11.0 - Qgd Gate-Drain Charge - 23.0 - nC Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2% www.hymexa.com 3 V1.0 2019 HYG035N06LS1D Typical Operating Characteristics Figure 2: Drain Current ID-Drain Current(A) Power Dissipation (w) Figure 1: Power Dissipation Tc-Case Temperature(℃) Tc-Case Temperature(℃) Thermal Zθjc ID-Drain Current(A) Impedance Figure 4: Thermal Transient Impedance Normalized Transient Figure 3: Safe Operation Area Maximum Effective Transient Thermal Impedance, Junction-to-Case VDS-Drain-Source Voltage(V) Figure 6: Drain-Source On Resistance ID-Drain Current(A) RDS(ON)-ON-Resistance(mΩ) Figure 5: Output Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com ID-Drain Current(A) 4 V1.0 2019 HYG035N06LS1D Typical Operating Characteristics(Cont.) Figure 8: Source-Drain Diode Forward IS-Source Current (A) Normalized On-Resistance Figure 7: On-Resistance vs. Temperature Tj-Junction Temperature (℃) VSD-Source-Drain Voltage(V) Figure 10: Gate Charge Characteristics C-Capacitance(pF) VGS-Gate-Source Voltage (V) Figure 9: Capacitance Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com QG-Gate Charge (nC) 5 V1.0 2019 HYG035N06LS1D Avalanche Test Circuit Switching Time Test Circuit Gate Charge Test Circuit www.hymexa.com 6 V1.0 2019 HYG035N06LS1D Device Per Unit Package Type Unit Quantity TO-252-2L Tube 75 Package Information TO-252-2L COMMON DIMENSIONS mm SYMBOL MIN NOM MAX A 2.20 2.30 2.40 A1 0.00 - 0.20 A2 0.97 1.07 1.17 b 0.68 0.78 0.90 b3 5.20 5.33 5.50 c 0.43 0.53 0.63 D 5.98 6.10 6.22 D1 5.30REF E 6.40 6.60 6.80 E1 4.63 - - e www.hymexa.com 7 2.286BSC H 9.40 10.10 10.50 L 1.38 1.50 1.75 L1 2.90REF L2 0.51BSC L3 0.88 - 1.28 L4 - - 1.00 L5 1.65 1.80 1.95 θ 0° - 8° V1.0 2019 HYG035N06LS1D Classification Profile Classification Reflow Profiles Profile Feature Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmaxto TP) Liquidous temperature (TL) Time at liquidous (tL) Peak package body Temperature (Tp)* Time (tP)** within 5℃ of the specified classification temperature (Tc) Average ramp-down rate (Tpto Tsmax) Time 25℃ to peak temperature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 ℃ 150 ℃ 150 ℃ 200 ℃ 60-120 seconds 60-120 seconds 3 ℃/second max. 3℃/second max. 183 ℃ 217 ℃ 60-150 seconds 60-150 seconds See Classification Temp in table 1 SeeClassification Tempin table 2 20** seconds 30** seconds 6 ℃/second max. 6 ℃/second max. 6 minutes max. 8 minutes max. *Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.hymexa.com 8 V1.0 2019 HYG035N06LS1D Table 1.SnPb Eutectic Process – Classification Temperatures (Tc) Package Volume mm³ Volume mm³ Thickness
HYG035N06LS1D 价格&库存
很抱歉,暂时无法提供与“HYG035N06LS1D”相匹配的价格&库存,您可以联系我们找货
