HY4008P
HY4008P
    HUAYI(华羿微)
    TO-220-3
    1个N沟道 耐压:80V 电流:200A
HY4008P 数据手册
HY4008P/M/B/PS/PM N-Channel Enhancement Mode MOSFET Pin Description Features • 80V/200A RDS(ON) = 2.9 mΩ (typ.) @ VGS=10V • 100% avalanche tested • Reliable and Rugged • Lead Free and Green Devices Available G G D D S G D S S TO-220FB-3M TO-220FB-3L TO-263-2L (RoHS Compliant) G Applications G D Switching application • Power Management for Inverter Systems. S S TO-3PS-3L • D TO-3PS-3M D N-Channel MOSFET G S Ordering and Marking Information P HY4008 ÿ YYXXXJWW G ÿ YYXXXJWW G PS HY4008 PM HY4008 ÿ YYXXXJWW G Note: Package Code M HY4008 B HY4008 P : TO-220FB-3L B: TO-263-2L PM: TO-3PS-3M ÿ YYXXXJWW G Date Code YYXXX WW ÿ YYXXXJWW G M : TO-220FB-3M PS: TO-3PS-3L Assembly Material G : Lead Free Device HOOYI lead-free products contain molding compounds/die attach materials and 100% matte tin plate termination finish; which are fully compliant with RoHS. HOOYI lead-free products meet or exceed the lead-free requirements of IPC/JEDEC J-STD-020D for MSL classification at lead-free peak reflow temperature. HOOYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HOOYI reserves the right to make changes to improve reliability or manufacturability without notice, and advise customers to obtain the latest version of relevant information to verify before placing orders. 1 www.hooyi.cc 141225 HY4008P/M/B/PS/PM Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (TC=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage 80 VGSS Gate-Source Voltage ±25 Maximum Junction Temperature 175 °C -55 to 175 °C TC=25°C 200 A TC=25°C 790** A TC=25°C 200 TC=100°C 144 TC=25°C 345 TC=100°C 173 TJ TSTG IS Storage Temperature Range Diode Continuous Forward Current V Mounted on Large Heat Sink IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RθJC Thermal Resistance-Junction to Case 0.43 RθJA Thermal Resistance-Junction to Ambient 62.5 A W °C/W Avalanche Ratings EAS Avalanche Energy, Single Pulsed L=0.5mH mJ 1496*** Note: * Repetitive rating ; pulse width limiited by junction temperature ** Drain current is limited by junction temperature *** VD=64V Electrical Characteristics Symbol Parameter (TC = 25°C Unless Otherwise Noted) Test Conditions HY4008 Min. Typ. Max. 80 - - - - 1 - - 10 Unit Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Zero Gate Voltage Drain Current VGS(th) IGSS RDS(ON)* VGS=0V, IDS=250µA VDS=80V, VGS=0V TJ=85°C V µA Gate Threshold Voltage VDS=VGS, IDS=250µA 2.0 3.0 4.0 V Gate Leakage Current VGS=±25V, VDS=0V - - ±100 nA Drain-Source On-state Resistance VGS=10V, IDS=100A - 2.9 3.5 mΩ ISD=100A, VGS=0V - 0.8 1.2 V - 30 - ns - 52 - nC Diode Characteristics VSD * Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge ISD=100A, dlSD/dt=100A/µs 2 www.hooyi.cc HY4008P/M/B/PS/PM Electrical Characteristics (Cont.) Symbol Parameter (TC = 25°C Unless Otherwise Noted) Test Conditions HY4008 Min. Typ. Max. - 3.2 - - 8154 - - 1029 - - 650 - - 28 - - 18 - - 42 - - 54 - - 197 - - 31 - - 75 - Unit Dynamic Characteristics RG Gate Resistance Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance td(ON) Turn-on Delay Time Tr Turn-on Rise Time td(OFF) Turn-off Delay Time Tf VGS=0V,VDS=0V,F=1MHz VGS=0V, VDS=25V, Frequency=1.0MHz VDD=40V, R G=6 Ω, I DS =100A, VGS=10V, Turn-off Fall Time Ω pF ns Gate Charge Characteristics Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS=64V, VGS=10V, IDS=100A Note * : Pulse test ; pulse width ≤300µs, duty cycle≤2%. 3 www.hooyi.cc nC HY4008P/M/B/PS/PM Typical Operating Characteristics Power Dissipation Drain Current 350 225 200 ID - Drain Current (A) 250 200 150 100 limited by package 175 150 125 100 75 50 25 50 o TC=25 C,VG=10V o TC=25 C 0 0 20 40 0 60 80 100 120 140 160 180 200 0 20 Tc - Case Temperature (°C) 40 60 80 100 120 140 160 180 200 Tc - Case Temperature (°C) Safe Operation Area im it 100us ds ( on )L 100 1ms R ID - Drain Current (A) 1000 10ms 10 DC 1 o TC=25 C 0.1 0.01 0.1 1 10 100 300 VDS - Drain - Source Voltage (V) Thermal Transient Impedance 1 Normalized Effective Transient Ptot - Power (W) 300 Duty = 0.5 0.1 0.2 0.1 0.05 0.01 0.02 0.01 0.001 Single Mounted on minimum pad o RθJA : 62.5 C/W 0.0001 0.0001 0.001 0.1 0.01 1 10 Square Wave Pulse Duration (sec) 4 www.hooyi.cc HY4008P/M/B/PS/PM Typical Operating Characteristics (Cont.) Drain-Source On Resistance Output Characteristics 5.0 320 VGS= 5.5,6,7,8,9,10V RDS(ON) - On - Resistance (mW) 280 ID - Drain Current (A) 240 5V 200 160 4.5V 120 4V 80 40 0 0.0 1.0 2.0 3.0 4.0 5.0 4.5 4.0 VGS=10V 3.5 3.0 2.5 2.0 1.5 0 6.0 50 100 150 200 250 ID - Drain Current (A) VDS - Drain - Source Voltage (V) Gate-Source On Resistance Gate Threshold Voltage 14 IDS=100A 1.6 IDS =250µA Normalized Threshold Voltage RDS(ON) - On - Resistance (mW) 12 10 8 6 4 2 0 1.4 1.2 1.0 0.8 0.6 0.4 3 4 5 6 7 8 9 0.2 -50 -25 10 VGS - Gate - Source Voltage (V) 0 25 50 75 100 125 150 175 Tj - Junction Temperature (°C) 5 www.hooyi.cc HY4008P/M/B/PS/PM Typical Operating Characteristics (Cont.) Drain-Source On Resistance Source-Drain Diode Forward 2.4 2.2 200 VGS = 10V 100 IDS = 100A Normalized On Resistance 2.0 1.8 IS - Source Current (A) o 1.6 1.4 1.2 1.0 0.8 0.6 0.4 o Tj=25 C 1 RON@Tj=25 C: 2.9mΩ 0 25 50 75 100 125 150 175 0.1 0.0 0.6 0.8 1.0 1.2 Capacitance Gate Charge VGS - Gate-source Voltage (V) 10500 9000 1.4 10 VDS= 64V 9 Ciss 7500 6000 4500 3000 Coss IDS= 100A 8 7 6 5 4 3 2 1 Crss 0 0.4 VSD - Source - Drain Voltage (V) Frequency=1MHz 1500 0.2 Tj - Junction Temperature (°C) 12000 C - Capacitance (pF) 10 o 0.2 -50 -25 0 Tj=175 C 8 16 24 32 0 40 VDS - Drain - Source Voltage (V) 0 40 80 120 160 QG - Gate Charge (nC) 6 www.hooyi.cc 200 HY4008P/M/B/PS/PM Avalanche Test Circuit and Waveforms VDS L tp VDSX(SUS) DUT VDS IAS RG VDD VDD IL tp EAS 0.01Ω tAV Avalanche Test Circuit and Waveforms VDS RD V DS DUT RG 90% VGS VDD 10% VGS tp td(on) tr 7 td(off) tf www.hooyi.cc HY4008P/M/B/PS/PM Package Information TO-220FB-3L SYMBOL A A1 A2 b b2 c D D1 DEP E NOM MAX MIN NOM MAX 4.57 1.30 4.70 1.33 0.173 0.050 0.180 0.051 0.185 0.052 2.35 0.77 2.40 0.80 2.50 0.90 0.093 0.030 0.094 0.031 0.098 0.035 1.17 1.27 1.36 0.046 0.050 0.054 0.48 15.40 0.50 15.60 0.56 15.80 0.019 0.606 0.020 0.614 0.022 0.622 9.00 9.10 9.20 0.354 0.358 0.362 0.05 9.80 0.10 10.00 0.20 10.20 0.002 0.386 0.004 0.394 0.008 0.402 8.70 - 0.343 - E1 - E2 9.80 e e1 H1 L L1 L2 P P1 Q θ1 θ2 θ3 8 MIN 4.40 1.27 6.40 12.75 - 10.00 10.20 2.54 BSC 5.08 BSC 6.50 6.60 13.50 13.65 3.10 3.30 2.50 REF 0.386 0.394 0.402 0.100 BSC 0.252 0.200 BSC 0.256 0.260 0.502 0.531 - 0.537 0.122 0.130 0.098 REF 3.50 3.60 3.63 0.138 0.142 0.143 3.50 2.73 3.60 2.80 3.63 2.87 0.138 0.107 0.142 0.110 0.143 0.113 5° 7° 9° 5° 7° 9° 1° 1° 3° 3° 5° 5° 1° 1° 3° 3° 5° 5° www.hooyi.cc HY4008P/M/B/PS/PM TO-220FB-3M SYMBOL A A1 A2 b b2 c D D1 DEP E NOM MAX MIN NOM MAX 4.57 1.30 4.70 1.33 0.173 0.050 0.180 0.051 0.185 0.052 2.35 0.77 2.40 0.80 2.50 0.90 0.093 0.030 0.094 0.031 0.098 0.035 1.17 1.27 1.36 0.046 0.050 0.054 0.48 15.40 0.50 15.60 0.56 15.80 0.019 0.606 0.020 0.614 0.022 0.622 9.00 9.10 9.20 0.354 0.358 0.362 0.05 9.80 0.10 10.00 0.20 10.20 0.002 0.386 0.004 0.394 0.008 0.402 8.70 - 0.343 - E1 - E2 9.80 e e1 H1 L L1 L2 P P1 Q θ1 θ2 9 MIN 4.40 1.27 6.40 7.25 - 10.00 10.20 2.54 BSC 5.08 BSC 6.50 6.60 7.40 7.55 3.10 3.30 2.50 REF 0.386 0.252 0.285 - 0.394 0.402 0.100 BSC 0.200 BSC 0.256 0.260 0.291 0.297 0.122 0.130 0.098 REF 3.50 3.60 3.63 0.138 0.142 0.143 3.50 2.73 3.60 2.80 3.63 2.87 0.138 0.107 0.142 0.110 0.143 0.113 5° 7° 9° 5° 7° 9° 1° 3° 5° 1° 3° 5° www.hooyi.cc HY4008P/M/B/PS/PM TO-263-2L SYMBOL MM MIN NOM MAX MIN NOM MAX A 4.40 4.57 4.70 0.173 0.180 0.185 A1 1.22 1.27 1.32 0.048 0.050 0.052 A2 2.59 2.69 2.79 0.102 0.106 0.110 A3 0.00 0.10 0.20 0.000 0.004 0.008 b 0.77 0.813 0.90 0.030 0.032 0.035 b1 1.20 1.270 1.36 0.047 0.050 0.054 c 0.34 0.381 0.47 0.013 0.015 0.019 D1 8.60 8.70 8.80 0.339 0.343 0.346 E 10.00 10.16 10.26 0.394 0.400 0.404 E2 10.00 10.10 10.20 0.394 0.398 0.402 H 14.70 15.10 15.50 0.579 0.594 0.610 H2 1.17 1.27 1.40 0.046 0.050 0.055 L 2.00 2.30 2.60 0.079 0.091 0.102 L1 1.45 1.55 1.70 0.057 0.061 0.067 2.54 BSC e L2 0.100 BSC 2.50 REF L4 10 INCH 0.098 REF 0.25 BSC 0.010 BSC 0° 5° 8° 0° 5° 8° 1 5° 7° 9° 5° 7° 9° 2 1° 3° 5° 1° 3° 5° ΦP1 1.40 1.50 1.60 0.055 0.059 0.063 DEP 0.05 0.10 0.20 0.002 0.004 0.008 www.hooyi.cc HY4008P/M/B/PS/PM TO-3PS-3L SYMBOL A A1 A2 b b2 c D D1 D2 DEP E E1 E2 E3 e e1 L L1 P P1 P2 P3 Q Q1 Q2 U θ1 θ2 θ3 11 MIN NOM 3. 36 3. 56 3. 76 1. 27 1. 49 0. 77 1. 17 1. 30 1. 54 0. 80 1. 27 1. 37 1. 64 0. 90 1. 36 0. 48 1 5. 50 9. 10 0. 05 9. 88 7. 80 6. 90 9. 90 1 3. 25 - 1. 40 3. 93 1. 60 6. 80 4. 00 3° 5° 1° MAX 0. 50 1 5. 70 0. 56 1 5. 90 9. 20 0. 30 0. 10 1 0. 00 8. 00 7. 10 1 0. 00 2. 54 5. 08 1 3. 40 3 .0 0 6. 00 3. 20 3. 57 1. 50 4. 00 1. 70 7. 00 4. 20 5° 7° 3° 9. 30 RE F 0. 20 1 0. 20 8. 20 7. 30 1 0. 10 BS C BS C 1 3. 55 3 .3 0 RE F RE F RE F 1. 60 4. 07 1. 80 7. 20 4. 40 7° 9° 5° www.hooyi.cc HY4008P/M/B/PS/PM TO-3PS-3M SYMBOL A A1 A2 b b2 c D D1 D2 DEP E E1 E2 E3 e e1 L L1 P P1 P2 P3 Q Q1 Q2 U θ1 θ2 θ3 12 MIN NOM 3. 36 3. 56 3. 76 1. 27 1. 49 0. 77 1. 17 1. 30 1. 54 0. 80 1. 27 1. 37 1. 64 0. 90 1. 36 0. 48 1 5. 50 9. 10 0. 05 9. 88 7. 80 6. 90 9. 90 7.25 - 1. 40 3. 93 1. 60 6. 80 4. 00 3° 5° 1° MAX 0. 50 1 5. 70 0. 56 1 5. 90 9. 20 0. 30 0. 10 1 0. 00 8. 00 7. 10 1 0. 00 2. 54 5. 08 7.40 3 .0 0 6. 00 3. 20 3. 57 1. 50 4. 00 1. 70 7. 00 4. 20 5° 7° 3° 9. 30 RE F 0. 20 1 0. 20 8. 20 7. 30 1 0. 10 BS C BS C 7.55 3 .3 0 RE F RE F RE F 1. 60 4. 07 1. 80 7. 20 4. 40 7° 9° 5° www.hooyi.cc HY4008P/M/B/PS/PM Devices Per Unit Package Type Unit Quantity TO-220FB-3L Tube 50 TO-220FB-3M Tube 50 TO-263-2L Tube 50 TO-3PS-3L Tube 50 TO-3PS-3M Tube 50 Classification Profile 13 www.hooyi.cc HY4008P/M/B/PS/PM Classification Reflow Profiles Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 60-120 seconds 150 °C 200 °C 60-120 seconds 3 °C/second max. 3°C/second max. 183 °C 60-150 seconds 217 °C 60-150 seconds See Classification Temp in table 1 See Classification Temp in table 2 Time (tP)** within 5°C of the specified classification temperature (Tc) 20** seconds 30** seconds Average ramp-down rate (Tp to Tsmax) 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to TP) Liquidous temperature (TL) Time at liquidous (tL) Peak (Tp)* package body Temperature Time 25°C to peak temperature * Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Table 1. SnPb Eutectic Process – Classification Temperatures (Tc) 3 Package Volume mm Thickness
HY4008P 价格&库存
很抱歉,暂时无法提供与“HY4008P”相匹配的价格&库存,您可以联系我们找货
HY4008P
    • 1000+3.41600
    库存:9000
