HY3704B
HY3704B
    HUAYI(华羿微)
    TO-263(D²Pak)
    HY3704B
HY3704B 数据手册
HY3704P/B N-Channel Enhancement Mode MOSFET Features • Pin Description 40V/176A RDS(ON) = 3.0 m(typ.) @ VGS=10V • 100% avalanche tested • Reliable and Rugged • Lead Free and Green Devices Available S GD (RoHS Compliant) GD S TO-220FB-3L TO-263-2L Applications • Switching application • Power Management for DC/DC N-Channel MOSFET Ordering and Marking Information P HY3704 Package Code P : TO-220FB-3L B HY3704 Date Code YYXXX WW YYXXXJWW G YYXXXJWW G B: TO-263-2L Assembly Material G : Lead Free Device Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hymexa.com 1 V1.0 HY3704P/B Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (TC=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage 40 VGSS Gate-Source Voltage ±20 Maximum Junction Temperature 175 °C -55 to 175 °C 176 A 648** A TJ TSTG IS Storage Temperature Range Diode Continuous Forward Current TC=25°C V Mounted on Large Heat Sink IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation = TC 25°C = TC 25°C 176 TC 100°C = A 120 = TC 25°C 192 W 96 TC=100°C RJC Thermal Resistance-Junction to Case 0.78 RJA Thermal Resistance-Junction to Ambient 62.5 °C/W Avalanche Ratings EAS Avalanche Energy, Single Pulsed L=0.5mH J 1.09*** Note: * Repetitive rating ; pulse width limiited by junction temperature ** Drain current is limited by junction temperature *** VD=32V Electrical Characteristics Symbol Parameter (TC = 25C Unless Otherwise Noted) Test Conditions HY3704 Min. Typ. Max. 40 - - - - 1 - - 10 Unit Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Zero Gate Voltage Drain Current VGS(th) IGSS RDS(ON)* VGS=0V, IDS=250A VDS= =40V, VGS 0V TJ 85°C = V A Gate Threshold Voltage VDS=VGS, IDS=250A 2.0 3.0 4.0 V Gate Leakage Current VGS=±20V, = VDS 0V - - ±100 nA Drain-Source On-state Resistance VGS= =10V, IDS 88A - 3.0 3.6 m ISD=88 A, VGS=0V - 0.8 1.2 V - 28 - ns - 51 - nC Diode Characteristics VSD * Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge www.hymexa.com ISD= 88A, dlSD/dt=100A/s 2 V1.0 HY3704P/B Electrical Characteristics (Cont.) Symbol Parameter (TC = 25C Unless Otherwise Noted) Test Conditions HY3704 Min. Typ. Max. - 1.1 - - 4427 - - 1028 - - 538 - - 28 - - 18 - - 42 - - 54 - - 122 - - 29 - - 35 - Unit Dynamic Characteristics RG Gate Resistance Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance td(ON) Turn-on Delay Time Tr Turn-on Rise Time td(OFF) Turn-off Delay Time Tf VGS=0V,V= = 1MHz DS 0V,F VGS=0V, VDS=25V, Frequency=1.0MHz VDD=20V, R G=6 , I DS =88A, V GS=10V, Turn-off Fall Time  pF ns Gate Charge Characteristics Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS=32V, VGS=10V, IDS=88A Note * : Pulse test ; pulse width 300s, duty cycle2%. www.hymexa.com 3 V1.0 nC HY3704P/B Typical Operating Characteristics Power Dissipation Drain Current 275 187 175 ID - Drain Current (A) Ptot - Power (W) 250 200 150 100 limited by package 150 125 100 75 50 50 25 o 0 TC=25 C 0 o 0 20 40 60 80 100 120 140 160 180 200 TC=25 C,VG=10V 0 20 40 60 80 100 120 140 160 180 200 Tc - Case Temperature (°C) Tc - Case Temperature (°C) Safe Operation Area Lim it 100 100us Rd s(o n) ID - Drain Current (A) 1000 10ms 1ms 10 DC 1 0.1 10 1 100 400 VDS - Drain - Source Voltage (V) Thermal Transient Impedance 1 Normalized Effective Transient Duty = 0.5 0.2 0.1 0.1 0.05 0.01 0.02 0.01 0.001 Single Mounted on minimum pad o RJA : 62.5 C/W 0.0001 0.0001 0.001 0.1 0.01 1 10 Square Wave Pulse Duration (sec) www.hymexa.com 4 V1.0 HY3704P/B Typical Operating Characteristics (Cont.) Drain-Source On Resistance Output Characteristics 400 3.9 VGS= 5.5,6,7,8,9,10V RDS(ON) - On - Resistance (mΩ) 350 ID - Drain Current (A) 300 5V 250 200 150 100 4.5V 3.5 VGS=10V 3.0 50 4V 0 0.0 1.0 2.0 3.0 4.0 5.0 2.5 6.0 0 40 VDS - Drain - Source Voltage (V) Normalized Threshold Vlotage RDS(ON) - On - Resistance (m) 1.6 IDS=88A 6 5 4 3 4 5 6 7 8 9 200 IDS =250A 1.4 1.2 1.0 0.8 0.6 0.4 0.2 -50 -25 10 VGS - Gate - Source Voltage (V) www.hymexa.com 160 Gate Threshold Voltage 7 2 120 ID - Drain Current (A) Drain-Source On Resistance 8 80 0 25 50 75 100 125 150 175 Tj - Junction Temperature (°C) 5 V1.0 HY3704P/B Typical Operating Characteristics (Cont.) Drain-Source On Resistance 2.4 2.2 Normalized On Resistance 2.0 Source-Drain Diode Forward 175 VGS = 10V 100 IDS = 88A IS - Source Current (A) 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 o Tj=175 C 10 o Tj=25 C 1 o 0.2 -50 -25 RON@Tj=25 C: 3.0m 0 25 50 0.1 0.0 75 100 125 150 175 Tj - Junction Temperature (°C) 0.2 VGS - Gate-source Voltage (V) 10500 C - Capacitance (pF) 9000 7500 Ciss 4500 3000 Coss 0 8 16 24 32 1.4 VDS= 32V IDS= 88A 8 7 6 5 4 3 2 0 40 VDS - Drain - Source Voltage (V) www.hymexa.com 1.2 1 Crss 0 1.0 10 9 1500 0.8 Gate Charge Frequency=1MHz 6000 0.6 VSD - Source-Drain Voltage (V) Capacitance 12000 0.4 0 25 50 75 100 125 QG - Gate Charge (nC) 6 V1.0 HY3704P/B Avalanche Test Circuit VDS L tp VDSX(SUS) DUT VDS IAS RG VDD VDD IL tp EAS 0.01Ω tAV Avalanche Test Circuit VDS RD V DS DUT RG 90% VGS VDD 10% VGS tp td(on) tr www.hymexa.com 7 td(off) tf V1.0 HY3704P/B Package Information TO-220FB-3L COMMON DIMENSIONS SYMBOL www.hymexa.com mm MIN MIN N MAX A 4.37 4.57 4.77 A1 1.25 1.30 1.45 A2 2.20 2.40 2.60 b 0.70 0.80 0.95 b2 1.17 1.27 1.47 c 0.40 0.50 0.65 D 15.10 15.60 16.10 D1 8.80 9.10 9.40 D2 5.50 - - E 9.70 10.00 10.30 E3 7.00 - - e 2.54 BSC e1 5.08 BSC H1 6.25 6.50 6.85 L 12.75 13.50 13.80 L1 - 3.10 3.40 ĭ3 3.40 3.60 3.80 Q 2.60 2.80 3.00 8 V1.0 HY3704P/B TO-263-2L COMMON DIMENSIONS SYMBOL mm MIN MIN N MAX A 4.37 4.57 4.77 A1 1.22 1.27 1.42 A2 2.49 2.69 2.89 A3 0 0.13 0.25 b 0.7 0.81 0.96 b1 1.17 1.27 1.47 c 0.3 0.38 0.53 D1 8.5 8.7 8.9 D4 6.6 - - E 9.86 10.16 10.36 E5 7.06 - - e 2.54 BSC H 14.7 15.1 15.5 H2 1.07 1.27 1.47 L 2 2.3 2.6 L1 1.4 1.55 1.7 L4 ș www.hymexa.com 0.25 BSC 0° 9 5° 9° V1.0 HY3704P/B Devices Per Unit Package Type Unit Quantity TO-220FB-3L Tube 50 TO-263-2L Tube 50 Classification Profile www.hymexa.com 10 V1.0 HY3704P/B Classification Reflow Profiles Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 C 150 C 60-120 seconds 150 C 200 C 60-120 seconds 3 C/second max. 3C/second max. 183 C 60-150 seconds 217 C 60-150 seconds See Classification Temp in table 1 See Classification Temp in table 2 Time (tP)** within 5C of the specified classification temperature (Tc) 20** seconds 30** seconds Average ramp-down rate (Tp to Tsmax) 6 C/second max. 6 C/second max. 6 minutes max. 8 minutes max. Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to TP) Liquidous temperature (TL) Time at liquidous (tL) Peak (Tp)* package body Temperature Time 25C to peak temperature * Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Table 1. SnPb Eutectic Process – Classification Temperatures (Tc) 3 Package Volume mm Thickness
HY3704B 价格&库存
很抱歉,暂时无法提供与“HY3704B”相匹配的价格&库存,您可以联系我们找货
