HYG030N03LQ1D
HYG030N03LQ1D
    HUAYI(华羿微)
    TO-252(DPAK)
    1个N沟道 耐压:30V 电流:100A
HYG030N03LQ1D 数据手册
HYG030N03LQ1D Single N-Channel Enhancement Mode MOSFET Feature  Pin Description 30V/100A RDS(ON)= 2.5 mΩ(typ.) @VGS = 10V RDS(ON)= 3.5 mΩ(typ.) @VGS = 4.5V  100% Avalanche Tested  Reliable and Rugged  Halogen- Free Devices Available D S G Applications  Battery Protection  Motor drives Single N-Channel MOSFET Ordering and Marking Information Package Code D D: TO-252-2L G030N03 XYMXXXXXX Date Code XYMXXXXXX Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plate TermiNation finish;which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hymexa.com V1.02020 HYG030N03LQ1D Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (Tc=25℃ Unless Otherwise Noted) VDSS Drain-Source Voltage 30 V VGSS Gate-Source Voltage ±20 V TJ Junction Temperature Range -55 to 175 ℃ TSTG Storage Temperature Range -55 to 175 ℃ Tc=25℃ 100 A Tc=25℃ 390 A Tc=25℃ 100 A Tc=100℃ 71 A Tc=25℃ 57 W Tc=100℃ 28 W IS Source Current-Continuous(Body Diode) Mounted on Large Heat Sink Note: IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RθJC Thermal Resistance, Junction-to-Case 2.6 ℃/W RθJA Thermal Resistance, Junction-to-Ambient ** 110 ℃/W EAS SinglePulsed-Avalanche Energy *** 148 mJ L=0.3mH * Repetitive rating;pulse width limited by max.junction temperature. ** Surface mounted on FR-4 board. *** Limited by TJmax , starting TJ=25℃, L = 0.3mH, RG =25Ω., VGS =10V. Electrical Characteristics(Tc =25℃ Unless Otherwise Noted) Symbol Parameter Test Conditions HYG030N03LQ1 Unit Min Typ. Max 30 - - V - - 1 μA - - 50 μA Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Drain-to-Source Leakage Current VGS(th) IGSS RDS(ON) VGS=0V,IDS=250μA VDS=30V,VGS=0V TJ=125℃ Gate Threshold Voltage VDS=VGS, IDS=250μA 1 1.3 3 V Gate-Source Leakage Current VGS=+20V/-20V,VDS=0V - - ±100 nA VGS=10V,IDS=30A - 2.5 3 mΩ VGS=4.5V,IDS=30A - 3.5 4.2 mΩ ISD=30A,VGS=0V - 0.83 1.2 V - 14.0 - ns - 5.9 - nC Drain-Source On-State Resistance Diode Characteristics VSD* Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge www.hymexa.com ISD=30A,dISD/dt=100A/μs V1.02020 HYG030N03LQ1D Electrical Characteristics (Cont.) (Tc =25℃ Unless Otherwise Noted) Symbol Parameter Test Conditions HYG030N03LQ1 Min Typ. Max Unit Dynamic Characteristics RG Gate Resistance VGS=0V,VDS=0V,F=1MHz - 3.9 - Ciss Input Capacitance VGS=0V, - 1958 - Coss Output Capacitance VDS=25V, - 308 - Crss Reverse Transfer Capacitance Frequency=1.0MHz - 292 - td(ON) Turn-on Delay Time - 9.1 - Tr Turn-on Rise Time VDD=24V,RG=4Ω, - 70.2 - td(OFF) Turn-off Delay Time IDS=30A,VGS=10V - 42.8 - - 90.2 - - 54.8 - - 29.7 - - 6.6 - - 18.4 - Tf Turn-off Fall Time Ω pF ns Gate Charge Characteristics Qg Total Gate Charge(VGS=10V) Qg Total Gate Charge(VGS=4.5V) Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS =24V, ID=30A nC Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2% www.hymexa.com V1.02020 HYG030N03LQ1D Typical Operating Characteristics Figure 2: Drain Current ID-Drain Current(A) Power Dissipation (w) Figure 1: Power Dissipation Tc-Case Temperature(℃) Tc-Case Temperature(℃) Zθjc ID-Drain Current(A) Thermal Impedance Figure 4: Thermal Transient Impedance Normalized Transient Figure 3: Safe Operation Area Maximum Effective Transient Thermal Impedance, Junction-to-Case VDS-Drain-Source Voltage(V) Figure 6: Drain-Source On Resistance ID-Drain Current(A) RDS(ON)-ON-Resistance(mΩ) Figure 5: Output Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com ID-Drain Current(A) V1.02020 HYG030N03LQ1D Typical Operating Characteristics(Cont.) Figure 8: Source-Drain Diode Forward IS-Source Current (A) Normalized On-Resistance Figure 7: On-Resistance vs. Temperature Tj-Junction Temperature (℃) Figure 10: Gate Charge Characteristics C-Capacitance(pF) VGS-Gate-Source Voltage (V) Figure 9: Capacitance Characteristics VSD-Source-Drain Voltage(V) VDS-Drain-Source Voltage (V) www.hymexa.com QG-Gate Charge (nC) V1.02020 HYG030N03LQ1D Avalanche Test Circuit Switching Time Test Circuit Gate Charge Test Circuit www.hymexa.com V1.02020 HYG030N03LQ1D Device Per Unit Package Type Unit Quantity TO-252-2L TO-252-2L Tube Reel 75 2500 PackageInformation TO-252-2L COMMONDIMENSIONS mm SYMBOL MIN NOM MAX A 2.20 2.30 2.40 A1 0.00 - 0.20 A2 0.97 1.07 1.17 b 0.68 0.78 0.90 b3 5.20 5.33 5.50 c 0.43 0.53 0.63 D 5.98 6.10 6.22 D1 5.30REF E 6.40 6.60 6.80 E1 4.63 - - e www.hymexa.com 2.286BSC H 9.40 10.10 10.50 L 1.38 1.50 1.75 L1 2.90REF L2 0.51BSC L3 0.88 - 1.28 L4 - - 1.00 L5 1.65 1.80 1.95 θ 0° - 8° V1.02020 HYG030N03LQ1D Classification Profile Classification Reflow Profiles Profile Feature Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmaxto TP) Liquidous temperature (TL) Time at liquidous (tL) Peak package body Temperature (Tp)* Time (tP)** within 5℃ of the specified classification temperature (Tc) Average ramp-down rate (Tpto Tsmax) Time 25℃ to peak temperature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 ℃ 150 ℃ 150 ℃ 200 ℃ 60-120 seconds 60-120 seconds 3 ℃/second max. 3℃/second max. 183 ℃ 217 ℃ 60-150 seconds 60-150 seconds See Classification Temp in table 1 SeeClassification Tempin table 2 20** seconds 30** seconds 6 ℃/second max. 6 ℃/second max. 6 minutes max. 8 minutes max. *Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.hymexa.com V1.02020 HYG030N03LQ1D Table 1.SnPb Eutectic Process – Classification Temperatures (Tc) Package Volume mm³ Volume mm³ Thickness
HYG030N03LQ1D
PDF文档中包含以下信息:
1. 物料型号:型号为EFM8UB3型号的单片机。
2. 器件简介:EFM8UB3型号单片机是一款低功耗、高性能的微控制器,适用于各种工业和消费电子应用。
3. 引脚分配:该单片机有多个引脚,每个引脚具有不同的功能,包括I/O、电源、地等。
4. 参数特性:包括工作电压、工作频率、内存大小等关键参数。
5. 功能详解:详细介绍了单片机的各个功能模块,如ADC、定时器、通信接口等。
6. 应用信息:提供了单片机在不同应用场景下的使用示例和推荐配置。
7. 封装信息:描述了单片机的物理封装形式,如DIP、SOIC等。
HYG030N03LQ1D 价格&库存
很抱歉,暂时无法提供与“HYG030N03LQ1D”相匹配的价格&库存,您可以联系我们找货
