HY1904C2
HY1904C2
    HUAYI(华羿微)
    PPAK8_6X5MM
    40V/65A RDSON = 5.1 mΩ(典型值)@ VGS = 10V;RDSON = 6.2 mΩ(典型值)@ VGS = 4.5V;经过100%雪崩测试;可靠耐用;提供无卤器件
HY1904C2 数据手册
HY1904C2 Single N-Channel Enhancement Mode MOSFET Feature Description  Pin Description 40V/65A RDS(ON)= 5.1mΩ(typ.)@VGS = 10V D D D D D D D D RDS(ON)= 6.2mΩ(typ.)@VGS = 4.5V  100% Avalanche Tested  Reliable and Rugged  Halogen- Free Devices Available S S S G G S S S Pin1 PPAK5*6-8L Applications  High Frequency Point-of-Load Synchronous Buck Converter  Power Tool Application  Networking DC-DC Power System Single N-Channel MOSFET Ordering and Marking Information Package Code C2 C2: PDFN5x6-8L HY1904 Date Code YYXXX WW YYXXXJWW G Assembly Material G:Halogen Free Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plate TermiNation finish;which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hymexa.com V1.0 1 HY1904C2 Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (Tc=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage 40 V VGSS Gate-Source Voltage ±20 V Maximum Junction Temperature 150 °C -55 to 150 °C Tc=25°C 65 A Tc=25°C 260 A Tc=25°C 65 A Tc=100°C 41 A Tc=25°C 48 W Tc=100°C 19 W TJ TSTG IS Storage Temperature Range Source Current-Continuous(Body Diode) Mounted on Large Heat Sink Note: IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RθJC Thermal Resistance, Junction-to-Case 2.6 °C/W RθJA Thermal Resistance, Junction-to-Ambient ** 35 °C/W EAS SinglePulsed-Avalanche Energy *** 145 mJ L=0.1mH * Repetitive rating;pulse width limited by max.junction temperature. ** Surface mounted on 1in2 FR-4 board. *** Limited by TJmax , starting TJ=25°C, L = 0.1mH, RG= 25Ω, VGS =10V. Electrical Characteristics(Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HY1904 Unit Min Typ. Max 40 - - V - - 1 μA - - 5 μA 3 V Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Drain-to-Source Leakage Current VGS(th) IGSS RDS(ON)* VGS=0V,IDS=250μA VDS=40V,VGS=0V TJ=55°C Gate Threshold Voltage VDS=VGS, IDS=250μA 1 1.7 Gate-Source Leakage Current VGS=±20V,VDS=0V - - VGS=10V,IDS=20A - 5.1 6 VGS=4.5V,IDS=20A - 6.2 7 ISD=20A,VGS=0V - 0.8 1.2 V - 23 - ns - 58 - nC Drain-Source On-State Resistance ±100 nA mΩ Diode Characteristics VSD* Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge ISD=20A,dISD/dt=100A/μs www.hymexa.com V1.0 2 HY1904C2 Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HY1904 Min Typ. Max Unit Dynamic Characteristics RG Gate Resistance VGS=0V,VDS=0V,F=1MHz - 1.5 - Ciss Input Capacitance VGS=0V, - 2391 - Coss Output Capacitance VDS=25V, - 359 - Crss Reverse Transfer Capacitance Frequency=1.0MHz - 195 - td(ON) Turn-on Delay Time - 13 - Tr Turn-on Rise Time VDD=20V,RG=3.3Ω, - 11 - td(OFF) Turn-off Delay Time IDS=20A,VGS=10V - 41 - - 14 - - 56.5 - - 5.1 - - 13.5 - Tf Turn-off Fall Time Gate Charge Ω pF ns Characteristics Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS =32V, VGS=10V, ID=20A nC Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2% www.hymexa.com V1.0 3 HY1904C2 Typical Operating Characteristics Figure 2: Drain Current ID-Drain Current(A) Power Dissipation (w) Figure 1: Power Dissipation Tc-Case Temperature(℃) Tc-Case Temperature(℃) Thermal Zθjc ID-Drain Current(A) Impedance Figure 4: Thermal Transient Impedance Normalized Transient Figure 3: Safe Operation Area Maximum Effective Transient Thermal Impedance, Junction-to-Case VDS-Drain-Source Voltage(V) Figure 6: Drain-Source On Resistance ID-Drain Current(A) RDS(ON)-ON-Resistance(mΩ) Figure 5: Output Characteristics VDS-Drain-Source Voltage (V) ID-Drain Current(A) www.hymexa.com V1.0 4 HY1904C2 Typical Operating Characteristics(Cont.) Figure 8: Source-Drain Diode Forward IS-Source Current (A) Normalized On-Resistance Figure 7: On-Resistance vs. Temperature Tj-Junction Temperature (℃) VSD-Source-Drain Voltage(V) Figure 10: Gate Charge Characteristics C-Capacitance(pF) VGS-Gate-Source Voltage (V) Figure 9: Capacitance Characteristics VDS-Drain-Source Voltage (V) QG-Gate Charge (nC) www.hymexa.com V1.0 5 HY1904C2 Avalanche Test Circuit and Waveforms Switching Time Test Circuit and Waveforms Gate Charge Test Circuit and Waveforms www.hymexa.com V1.0 6 HY1904C2 Device Per Unit Package Type Unit Quantity PDFN5x6-8L Reel 5000 Package Information PDFN5x6-8L www.hymexa.com V1.0 7 HY1904C2 Classification Profile Classification Reflow Profiles Profile Feature Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmaxto TP) Liquidous temperature (TL) Time at liquidous (tL) Peak package body Temperature (Tp)* Time (tP)** within 5°C of the specified classification temperature (Tc) Average ramp-down rate (Tpto Tsmax) Time 25°C to peak temperature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 150 °C 200 °C 60-120 seconds 60-120 seconds 3 °C/second max. 3°C/second max. 183 °C 217 °C 60-150 seconds 60-150 seconds See Classification Temp in table 1 SeeClassification Tempin table 2 20** seconds 30** seconds 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. *Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.hymexa.com V1.0 8 HY1904C2 Table 1.SnPb Eutectic Process – Classification Temperatures (Tc) Package Volume mm³ Volume mm³ Thickness
HY1904C2 价格&库存
很抱歉,暂时无法提供与“HY1904C2”相匹配的价格&库存,您可以联系我们找货
