HY029N10B6
HY029N10B6
    HUAYI(华羿微)
    TO-263-6
    N沟道,电流:280A,耐压:100V
HY029N10B6 数据手册
HY029N10B6 N-Channel Enhancement Mode MOSFET Feature  Pin Description 100V/280A RDS(ON)= 2.3 mΩ (typ.) @VGS = 10V  100% Avalanche Tested  Reliable and Rugged  Halogen- Free and Green Devices Available Pin7 (RoHS Compliant) Pin1 TO-263-6L Pin4 Applications  Brushless Motor Drive  Switching application  Electric Power Steering Pin1 Pin2,3,5,6,7 N-Channel MOSFET Ordering and Marking Information Package Code B6 B6:TO-263-6L HY029N10 Date Code XYMXXXXXX XYMXXXXXX Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hymexa.com 1 V1.2 HY029N10B6 Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (Tc=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage 100 V VGSS Gate-Source Voltage ±20 V Maximum Junction Temperature 175 °C -55 to 175 °C Tc=25°C 280 A Tc=25°C 760 A Tc=25°C 280 A Tc=100°C 198 A Tc=25°C 405 W Tc=100°C 203 W 0.37 °C/W 40 °C/W 926.8 mJ TJ TSTG IS Storage Temperature Range Source Current-Continuous(Body Diode) Mounted on Large Heat Sink Note: IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RJC Thermal Resistance-Junction to Case RJA Thermal Resistance-Junction to Ambient ** EAS SinglePulsed-Avalanche Energy *** * ** *** L=0.3mH Repetitive rating;pulse width limited by max.junction temperature. Surface Mounted on FR4 Board. Limited by TJmax , starting TJ=25°C, L = 0.3mH, VD= 80V, VGS =10V. Electrical Characteristics(Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HY029N10 Min Typ. Max Unit Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Drain-to-Source LeakageCurrent VGS(th) IGSS RDS(ON)* VGS=0V,IDS=250μA VDS=100,VGS=0V TJ=125°C 100 - - - 1 μA - - 50 μA 4 V Gate Threshold Voltage VDS=VGS, IDS=250μA 2 3 Gate-Source Leakage Current VGS=±20V,VDS=0V - - Drain-Source On-State Resistance VGS=10V,IDS=50A V ±100 nA 2.3 3.0 mΩ - 0.8 1.3 V - 86.2 - ns - 216 - nC Diode Characteristics VSD* Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge www.hymexa.com ISD=50A,VGS=0V ISD=50A,dISD/dt=100A/μs 2 V1.2 HY029N10B6 Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HY029N10 Min Typ. Max - 4.1 - - 10800 - Unit Dynamic Characteristics RG Gate Resistance Ciss Input Capacitance VGS=0V,VDS=0V,F=1 MHz VGS=0V, Coss Output Capacitance VDS=50V, - 1624 - Crss Reverse Transfer Capacitance Frequency=1.0MHz - 37 - td(ON) Turn-on Delay Time - 25.6 - Tr Turn-on Rise Time VDD=50V,RG=4Ω, - 119.5 - td(OFF) Turn-off Delay Time IDS=50A,VGS=10V - 122.5 - - 104.4 - - 150 - - 54 - - 25 - Tf Turn-off Fall Time Gate Charge Ω pF ns Characteristics Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS =50V, VGS=10V, ID=50A nC Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2% www.hymexa.com 3 V1.2 HY029N10B6 Typical Operating Characteristics Figure 2: Drain Current ID-Drain Current(A) Power Dissipation (w) Figure 1: Power Dissipation Tc-Case Temperature(℃) Tc-Case Temperature(℃) Thermal ZθjC ID-Drain Current(A) Impedance Figure 4: Thermal Transient Impedance Normalized Transient Figure 3: Safe Operation Area VDS-Drain-Source Voltage(V) Maximum Effective Transient Thermal Impedance, Junction-to-Case Figure 6: Drain-Source On Resistance ID-Drain Current(A) RDS(ON)-ON-Resistance(mΩ) Figure 5: Output Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com ID-Drain Current(A) 4 V1.2 HY029N10B6 Typical Operating Characteristics(Cont.) Figure 10: Source-Drain Diode Forward IS-Source Current (A) Normalized On-Resistance Figure 9: On-Resistance vs. Temperature Tj-Junction Temperature (℃) VSD-Source-Drain Voltage(V) Figure 12: Gate Charge Characteristics C-Capacitance(pF) VGS-Gate-Source Voltage Figure 11: Capacitance Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com QG-Gate Charge (nC) 5 V1.2 HY029N10B6 Avalanche Test Circuit and Waveforms Switching Time Test Circuit and Waveforms Gate Charge Test Circuit and Waveforms www.hymexa.com 6 V1.2 HY029N10B6 Device Per Unit Package Type TO-263-6L TO-263-6L Unit Quantity Tube Reel 50 800 Package Information TO-263-6L www.hymexa.com 7 V1.2 HY029N10B6 Classification Profile Classification Reflow Profiles Profile Feature Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmaxto TP) Liquidous temperature (TL) Time at liquidous (tL) Peak package body Temperature (Tp)* Time (tP)** within 5°C of the specified classification temperature (Tc) Average ramp-down rate (Tpto Tsmax) Time 25°C to peak temperature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 150 °C 200 °C 60-120 seconds 60-120 seconds 3 °C/second max. 3°C/second max. 183 °C 217 °C 60-150 seconds 60-150 seconds See Classification Temp in table 1 SeeClassification Tempin table 2 20** seconds 30** seconds 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. *Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.hymexa.com 8 V1.2 HY029N10B6 Table 1.SnPb Eutectic Process – Classification Temperatures (Tc) Package Volume mm³ Volume mm³ Thickness
HY029N10B6 价格&库存
很抱歉,暂时无法提供与“HY029N10B6”相匹配的价格&库存,您可以联系我们找货
