HY3606B
HY3606B
    HUAYI(华羿微)
    TO-263(D²Pak)
    耐压:60V 电流:162A
HY3606B 数据手册
HY3606P/B N-Channel Enhancement Mode MOSFET Features • Pin Description 60V/162A RDS(ON) = 3.5 mΩ (typ.) @ VGS=10V • 100% avalanche tested • Reliable and Rugged • Lead Free and Green Devices Available G D S (RoHS Compliant) G D S TO-263-2L TO-220FB-3L Applications D • Switching application • Power Management for Inverter Systems. N-Channel MOSFET G S Ordering and Marking Information P HY3606 Package Code P : TO-220FB-3L B HY3606 Date Code YYXXX WW ÿ ÿ YYXXXJWW G YYXXXJWW G Note: B: TO-263-2L Assembly Material G : Lead Free Device HOOYI lead-free products contain molding compounds/die attach materials and 100% matte tin plate termination finish; which are fully compliant with RoHS. HOOYI lead-free products meet or exceed the lead-free requirements of IPC/JEDEC J-STD-020D for MSL classification at lead-free peak reflow temperature. HOOYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HOOYI reserves the right to make changes to improve reliability or manufacturability without notice, and advise customers to obtain the latest version of relevant information to verify before placing orders. 1 www.hooyi.cc 141225 HY3606P/B Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (TC=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage 60 VGSS Gate-Source Voltage ±25 Maximum Junction Temperature 175 °C -55 to 175 °C TC=25°C 162 A TC=25°C 583** A TC=25°C 162 TC=100°C 105 TC=25°C 214 TC=100°C 107 TJ TSTG IS Storage Temperature Range Diode Continuous Forward Current V Mounted on Large Heat Sink IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RθJC Thermal Resistance-Junction to Case 0.7 RθJA Thermal Resistance-Junction to Ambient 62.5 A W °C/W Avalanche Ratings EAS Avalanche Energy, Single Pulsed L=0.5mH mJ 1000*** Note: * Repetitive rating ; pulse width limiited by junction temperature ** Drain current is limited by junction temperature *** VD=48V Electrical Characteristics Symbol Parameter (TC = 25°C Unless Otherwise Noted) Test Conditions HY3606 Min. Typ. Max. 60 - - - - 1 - - 10 Unit Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Zero Gate Voltage Drain Current VGS(th) IGSS RDS(ON)* VGS=0V, IDS=250µA VDS=60V, VGS=0V TJ=85°C V µA Gate Threshold Voltage VDS=VGS, IDS=250µA 2.0 3.0 4.0 V Gate Leakage Current VGS=±25V, VDS=0V - - ±100 nA Drain-Source On-state Resistance VGS=10V, IDS=81A - 3.5 4.5 mΩ ISD=81 A, VGS=0V - 0.8 1.2 V - 30 - ns - 52 - nC Diode Characteristics VSD * Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge ISD=81A, dlSD/dt=100A/µs 2 www.hooyi.cc HY3606P/B Electrical Characteristics (Cont.) Symbol Parameter (TC = 25°C Unless Otherwise Noted) Test Conditions HY3606 Min. Typ. Max. - 0.7 - - 4376 - - 857 - - 334 - - 28 - - 18 - - 42 - - 54 - - 130 - - 24 - - 47 - Unit Dynamic Characteristics RG Gate Resistance Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance td(ON) Turn-on Delay Time Tr Turn-on Rise Time td(OFF) Turn-off Delay Time Tf VGS=0V,VDS=0V,F=1MHz VGS=0V, VDS=25V, Frequency=1.0MHz VDD=30V, R G=6 Ω, I DS =81A, V GS=10V, Turn-off Fall Time Ω pF ns Gate Charge Characteristics Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS=48V, VGS=10V, IDS=81A Note * : Pulse test ; pulse width ≤300µs, duty cycle≤2%. 3 www.hooyi.cc nC HY3606P/B Typical Operating Characteristics Power Dissipation Drain Current 275 187 175 ID - Drain Current (A) Ptot - Power (W) 250 200 150 100 limited by package 150 125 100 75 50 50 25 o TC=25 C 0 0 o 0 20 40 60 80 100 120 140 160 180 200 TC=25 C,VG=10V 0 20 40 60 80 100 120 140 160 180 200 TC -Case Temperature (°C) TC -Case Temperature (°C) Safe Operation Area Lim it 100 Rd s(o n) ID - Drain Current (A) 1000 100us 10ms 1ms 10 DC 1 0.1 10 1 100 400 VDS - Drain - Source Voltage (V) Thermal Transient Impedance Normalized Effective Transient 1 Duty = 0.5 0.2 0.1 0.1 0.05 0.01 0.02 0.01 0.001 Single Mounted on minimum pad o RθJA : 62.5 C/W 0.0001 0.0001 0.001 0.1 0.01 1 10 Square Wave Pulse Duration (sec) 4 www.hooyi.cc HY3606P/B Typical Operating Characteristics (Cont.) Drain-Source On Resistance Output Characteristics 5.5 400 VGS= 5.5,6,7,8,9,10V RDS(ON) - On - Resistance (mW) 350 ID - Drain Current (A) 300 5V 250 200 150 100 4.5V 50 0 0.0 4V 1.0 2.0 3.0 4.0 5.0 5.0 4.5 VGS=10V 4.0 3.5 3.0 2.5 2.0 6.0 0 40 80 120 Gate-Source On Resistance Gate Threshold Voltage 14 1.6 IDS =250mA IDS=81A 12 1.4 Normalized Threshold Voltage RDS(ON) - On - Resistance (mW) 200 ID - Drain Current (A) VDS - Drain - Source Voltage (V) 10 8 6 4 2 0 160 3 4 5 6 7 8 9 1.2 1.0 0.8 0.6 0.4 0.2 -50 -25 10 VGS - Gate - Source Voltage (V) 0 25 50 75 100 125 150 Tj - Junction Temperature (°C) 5 www.hooyi.cc HY3606P/B Typical Operating Characteristics (Cont.) Drain-Source On Resistance 2.0 200 VGS = 10V 100 IDS = 81A 1.8 1.6 o IS - Source Current (A) Normalized On Resistance Source-Drain Diode Forward 1.4 1.2 1.0 0.8 Tj=150 C 10 o Tj=25 C 1 0.6 o RON@Tj=25 C: 3.5mW 0.4 -50 -25 0 25 50 75 0.1 0.0 100 125 150 0.8 1.0 1.2 Capacitance Gate Charge VDS= 48V 9 VGS - Gate-source Voltage (V) 9000 7500 Ciss 6000 4500 3000 Coss 1500 16 IDS= 81A 8 7 6 5 4 3 2 1 Crss 8 1.4 10 10500 C - Capacitance (pF) 0.6 VSD - Source - Drain Voltage (V) Frequency=1MHz 0 0.4 Tj - Junction Temperature (°C) 12000 0 0.2 24 32 0 40 VDS - Drain - Source Voltage (V) 0 30 60 90 120 QG - Gate Charge (nC) 6 www.hooyi.cc 150 HY3606P/B Avalanche Test Circuit and Waveforms VDS L tp VDSX(SUS) DUT VDS IAS RG VDD VDD IL tp EAS 0.01Ω tAV Avalanche Test Circuit and Waveforms VDS RD V DS DUT RG 90% VGS VDD 10% VGS tp td(on) tr 7 td(off) tf www.hooyi.cc HY3606P/B Package Information TO-220FB-3L SYMBOL A A1 A2 b b2 c D D1 DEP E NOM MAX MIN NOM MAX 4.57 1.30 4.70 1.33 0.173 0.050 0.180 0.051 0.185 0.052 2.35 0.77 2.40 0.80 2.50 0.90 0.093 0.030 0.094 0.031 0.098 0.035 1.17 1.27 1.36 0.046 0.050 0.054 0.48 15.40 0.50 15.60 0.56 15.80 0.019 0.606 0.020 0.614 0.022 0.622 9.00 9.10 9.20 0.354 0.358 0.362 0.05 9.80 0.10 10.00 0.20 10.20 0.002 0.386 0.004 0.394 0.008 0.402 8.70 - 0.343 - E1 - E2 9.80 e e1 H1 L L1 L2 P P1 Q θ1 θ2 θ3 8 MIN 4.40 1.27 6.40 12.75 - 10.00 10.20 2.54 BSC 5.08 BSC 6.50 6.60 13.50 13.65 3.10 3.30 2.50 REF 0.386 0.394 0.402 0.100 BSC 0.252 0.200 BSC 0.256 0.260 0.502 0.531 - 0.537 0.122 0.130 0.098 REF 3.50 3.60 3.63 0.138 0.142 0.143 3.50 2.73 3.60 2.80 3.63 2.87 0.138 0.107 0.142 0.110 0.143 0.113 5° 7° 9° 5° 7° 9° 1° 1° 3° 3° 5° 5° 1° 1° 3° 3° 5° 5° www.hooyi.cc HY3606P/B TO-263-2L SYMBOL MM MIN NOM MAX MIN NOM MAX A 4.40 4.57 4.70 0.173 0.180 0.185 A1 1.22 1.27 1.32 0.048 0.050 0.052 A2 2.59 2.69 2.79 0.102 0.106 0.110 A3 0.00 0.10 0.20 0.000 0.004 0.008 b 0.77 0.813 0.90 0.030 0.032 0.035 b1 1.20 1.270 1.36 0.047 0.050 0.054 c 0.34 0.381 0.47 0.013 0.015 0.019 D1 8.60 8.70 8.80 0.339 0.343 0.346 E 10.00 10.16 10.26 0.394 0.400 0.404 E2 10.00 10.10 10.20 0.394 0.398 0.402 H 14.70 15.10 15.50 0.579 0.594 0.610 H2 1.17 1.27 1.40 0.046 0.050 0.055 L 2.00 2.30 2.60 0.079 0.091 0.102 L1 1.45 1.55 1.70 0.057 0.061 0.067 2.54 BSC e L2 0.100 BSC 2.50 REF L4 9 INCH 0.098 REF 0.25 BSC 0.010 BSC 0° 5° 8° 0° 5° 8° 1 5° 7° 9° 5° 7° 9° 2 1° 3° 5° 1° 3° 5° ΦP1 1.40 1.50 1.60 0.055 0.059 0.063 DEP 0.05 0.10 0.20 0.002 0.004 0.008 www.hooyi.cc HY3606P/B Devices Per Unit Package Type Unit Quantity TO-220FB-3L Tube 50 TO-263-2L Tube 50 Classification Profile 10 www.hooyi.cc HY3606P/B Classification Reflow Profiles Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 60-120 seconds 150 °C 200 °C 60-120 seconds 3 °C/second max. 3°C/second max. 183 °C 60-150 seconds 217 °C 60-150 seconds See Classification Temp in table 1 See Classification Temp in table 2 Time (tP)** within 5°C of the specified classification temperature (Tc) 20** seconds 30** seconds Average ramp-down rate (Tp to Tsmax) 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to TP) Liquidous temperature (TL) Time at liquidous (tL) Peak (Tp)* package body Temperature Time 25°C to peak temperature * Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Table 1. SnPb Eutectic Process – Classification Temperatures (Tc) 3 Package Volume mm Thickness
HY3606B 价格&库存
很抱歉,暂时无法提供与“HY3606B”相匹配的价格&库存,您可以联系我们找货
