HYG110P04LQ2C2
Single P-Channel Enhancement Mode MOSFET
Feature Description
Pin Description
-40V/-55A
D D D D
D D D D
RDS(ON)= 9.0 mΩ (typ.) @VGS = - 10V
RDS(ON)= 13.0 mΩ (typ.) @VGS = - 4.5V
100% Avalanche Tested
Reliable and Rugged
Halogen- Free Devices Available
S S S G
Pin1
G S S S
PDFN5*6-8L
Applications
Switching Application
Power Management for DC/DC
Battery Protection
Single P-Channel MOSFET
Ordering and Marking Information
Package Code
C2
C2: PDFN5*6-8L
G110P04
Date Code
XYMXXXXXX
XYMXXXXXX
Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plate TermiNation finish;which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
V1.0
1
HYG110P04LQ2C2
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
-40
V
VGSS
Gate-Source Voltage
±20
V
Maximum Junction Temperature
-55 to 175
°C
Storage Temperature Range
-55 to 175
°C
Tc=25°C
-55
A
Tc=25°C
-200
A
Tc=25°C
-55
A
Tc=100°C
-38.8
A
Tc=25°C
62.5
W
Tc=100°C
31.2
W
TJ
TSTG
IS
Source Current-Continuous(Body Diode)
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance, Junction-to-Case
2.4
°C/W
RJA
Thermal Resistance, Junction-to-Ambient **
45
°C/W
EAS
SinglePulsed-Avalanche Energy ***
174***
mJ
L=0.3mH
* Repetitive rating;pulse width limited by max.junction temperature.
** Surface mounted on FR-4 board.
*** Limited by TJmax , starting TJ=25°C, L = 0.3mH, RG= 25Ω, VGS = - 10V.
Electrical Characteristics(Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HYG110P04LQ2
Unit
Min
Typ.
Max
-40
V
-1
μA
-50
μA
-1.0
-1.6
-3.0
V
±100
nA
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
VGS(th)
IGSS
RDS(ON)*
VGS=0V,IDS=-250μA
VDS=-40V,VGS=0V
TJ=125°C
Gate Threshold Voltage
VDS=VGS, IDS=-250μA
Gate-Source Leakage Current
VGS=±20V,VDS=0V
VGS=-10V,IDS=-20A
9.0
11.5
VGS=-4.5V,IDS=-20A
13.0
17.5
ISD=-10A,VGS=0V
-0.83
-1.2
V
18.4
ns
13.5
nC
Drain-Source On-State Resistance
mΩ
Diode Characteristics
VSD*
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=-20A,dISD/dt=100A/μs
www.hymexa.com
V1.0
2
HYG110P04LQ2C2
Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HYG110P04LQ2
Min
Typ.
Max
4.5
4468
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
VGS=0V,VDS=0V,
Frequency=1.0MHz
VGS=0V,
Coss
Output Capacitance
VDS=-25V,
253
Crss
Reverse Transfer Capacitance
Frequency=1.0MHz
140
td(ON)
Turn-on Delay Time
10.5
Tr
Turn-on Rise Time
VDD=-20V,RG=2.5Ω,
48
td(OFF)
Turn-off Delay Time
IDS=-20A,VGS= - 10V
83
72
76
Tf
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge (Vgs=- 10V)
Qg
Total Gate Charge (Vgs=- 4.5V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS =-32V,ID=-20A
36
15.9
14.2
nC
Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2%
www.hymexa.com
V1.0
3
HYG110P04LQ2C2
Typical Operating Characteristics
-ID-Drain Current(A)
Voltage
Figure 2: Drain Current
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Impedance (℃/ W)
Voltage
RDS(ON)-ON-Resistance(mΩ)
Figure 5: Output Characteristics
-VDS-Drain-Source Voltage (V)
Voltage
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
Figure 6: Drain-Source On Resistance
-VDS-Drain-Source Voltage(V)
Thermal
Normalized Transient
Figure 4: Thermal Transient Impedance
Z jc
Voltage
Figure 3: Safe Operation Area
www.hymexa.com
V1.0
4
HYG110P04LQ2C2
Typical Operating Characteristics(Cont.)
Voltage
-IS-Source Current (A)
Figure 8: Source-Drain Diode Forward
Voltage
Normalized On-Resistance(A)
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
-VSD-Source-Drain Voltage(V)
Voltage
-VGS-Gate-Source Voltage (V)
Figure 10: Gate Charge Characteristics
Voltage
C-Capacitance(pF)
Figure 9: Capacitance Characteristics
Q G-Gate Charge (nC)
www.hymexa.com
V1.0
5
HYG110P04LQ2C2
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
V1.0
6
HYG110P04LQ2C2
Device Per Unit
Package Type
Unit
Quantity
PDFN5*6-8L
Reel
5000
Package Information
PDFN5*6-8L
www.hymexa.com
V1.0
7
HYG110P04LQ2C2
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmaxto TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tpto Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
SeeClassification Tempin table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (T p) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
V1.0
8
HYG110P04LQ2C2
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mm³
Volume mm³
Thickness
很抱歉,暂时无法提供与“HYG110P04LQ2C2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.30980
- 50+1.89659
- 150+1.71958
- 500+1.49861
- 2500+1.16576
- 5000+1.10679
