2R090TA-5
2R090TA-5
    RUILON(瑞隆源)
    插件,5.5x6mm
    90V 5KA 2端 GDT
2R090TA-5 数据手册
Gas Discharge Tubes(GDT) 2RA-5 Series Description GDT is placed in front of, and in parallel with, sensitive telecom equipment such as power lines, communication lines, signal lines and data transmission lines to help protect them from damage caused by transient surge voltages that may result from lightning strikes and equipment switching operations. These devices do not influence the signal in normal operation. However, in the event of an overvoltage surge, such as a lightning strike, the GDT switches to a low impedance state and diverts the energy away from the sensitive equipment. Our GDT offer a high level of surge protection, a broad voltage range, low capacitance, and many form factors including new surface mount devices, which makes them suitable for applications such as Main Distribution Frame (MDF) modules, high data-rate telecom applications (e.g. ADSL, VDSL), and surge protection on power lines. Their low capacitance also results in less signal distortion. When used in a coordinated circuit protection solution with PolySwitch devices, they can help equipment manufacturers meet stringent safety regulatory standards. Electrical symbol Features Applications l l l l l l l l l l l l l l l l l l CATV equipment Antennas RS 485 Telecom Base Station Power Supply AC Main EV power Charging Inverter/Variable Frequency Drivers (VFDs) l IEEE 802.3 compliant Ethernet interfaces Excellent response to fast rising transients Stable breakdown voltage GHz working frequency 8/20μs Impulse current capability: 5KA Non-Radioactive Ultra Low capacitance (
2R090TA-5 价格&库存
很抱歉,暂时无法提供与“2R090TA-5”相匹配的价格&库存,您可以联系我们找货
