ES2AA THRU ES2JA
Super Fast Recovery Rectifier Diode
Features
Ideal for automated placement
Glass passivated chip junction
High frequency
High forward surge capability
Meets MSL level 1, per J-STD-020,LF maximum peak of
260 °C
Typical Application
For use in high frequency rectification of power supply,
inverters, converters, and freewheeling diodes for consumer
and telecommunication.
Mechanical Data
Package: DO-214AC(SMA)
Molding compound meets UL 94 V-0 flammability
rating,RoHS-compliant
Terminals:Tin plated leads, solderable per J-STD-002 and
JESD22-B102
Polarity: Cathode line denotes the cathode end
■ Maximum Ratings (Ta=25℃ Unless otherwise specified)
Unit
VRRM
V
IF(AV)
A
Surge(Nonrepetitive)Forward
Current
IFSM
A
Storage Temperature
Tstg
-55 ~ +150
Junction Temperature
Tj
-55 ~ +150
Repetitive Peak Reverse Voltage
Average Forward Current
Conditions
ES2
Symbol
PARAMETER
AA
BA
CA
50
100 150 200 300 400 500 600
60Hz Half-sine wave, Resistance
DA
FA
GA
HA
JA
2.0
load, TL=110℃
60HZ Half-sine wave, 1 cycle,
Ta=25℃
50
Electrical Characteristics(Ta=25℃ Unless otherwise specified)
PARAMETER
Peak Forward Voltage
Peak Reverse Current
Maximum reverse recovery
time
Thermal Resistance(Typical)
Symbol
Unit
Conditions
VFM
V
IF =2.0A
IRRM1
IRRM2
Trr
RθJ-A
RθJ-L
AA
BA
CA
ES2
DA FA
0.95
HA
1.3
Ta=25℃
5.0
Ta=125℃
350
μA
VRM=VRRM
ns
IF=0.5A,IR=1.0A,Irr=0.25A
35
Between junction and ambient
75¹)
Between junction and terminal
20¹)
℃/W
GA
JA
1.7
Notes:
1)
Thermal resistance from junction to ambientand from junction to lead mounted on P.C.B. with 0.27" x 0.27" (7.0 mm x 7.0 mm)copper pad areas
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2021-11-29
Page:1
■ Characteristics(Typical)
ES2AA THRU ES2JA
FIG1: Forward Current Derating Curve
FIG2:Maximum Non-Repetitive Forward Surge Current
FIG3:Typical Forward Characteristics
FIG4:Typical Reverse Characteristics
FIG5:Diagram of circuit and Testing wave form of reverse recovery time
Revised: 2021-11-29
Page:2
■ Ordering Information (Example)
PREFERED
ES2AA THRU ES2JA
PACKAGE CODE
MINIMUM
PACKAGE(pcs)
INNER BOX
OUTER CARTON
QUANTITY(pcs)
QUANTITY(pcs)
DELIVERY MODE
ES2AA~ES2JA
DO-214AC(SMA)
5000
10000
80000
13” reel
ES2AA~ES2JA
DO-214AC(SMA)
7500
15000
120000
13” reel
■ Outline Dimensions
Revised: 2021-11-29
Page:3
很抱歉,暂时无法提供与“ES2DA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23400
- 500+0.15600
- 2500+0.13520
- 5000+0.12376
