GS5A THRU GS5M(S5A THRU S5M)
General Purpose Rectifier
Features
● High efficiency
● High current capability
● High reliability
● High surge current capability
● Low power loss
● Glass passivated chip junction
● Solder dip 265 °C max.10 s, per JESD 22-B106
Typical Applications
For use in general purpose rectification of power
supplies, inverters, converters, and freewheeling diodes for
consumer, and telecommunication.
Mechanical Data
● Package:SMC
Molding compound meets UL 94 V-0 flammability rating,
RoHS-compliant
● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102
● Polarity:Color band denotes cathode end
■ Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
Symbol Unit
GS5/S5
A
B
D
G
J
K
M
Maximum Repetitive Peak Reverse Voltage
V RRM
V
50
100
200
400
600
800
1000
Maximum RMS Voltage
VRMS
V
35
70
140
280
420
560
700
VDC
V
50
100
200
400
600
800
1000
IO
A
5
IFSM
A
120
I2 t
A2s
59.8
Thermal Resistance(Typical)
@Between junction and ambient
RθJ-A
℃/W
47
Storage Temperature
Tstg
-55 ~ +150
Tj
-55 ~ +150
J
K
M
Maximum DC blocking Voltage
Average Forward Current
@Half-sine wave, Resistance load, Tc(Fig.1)
Forward Surge Current (Non-repetitive)
@60HZ sine wave, 1 cycle, Ta=25℃
Current squared time
@1ms≤t8.3≤ms Ta=25℃,Rating of per diode
Junction Temperature
■ Electrical Characteristics(Ta=25℃ Unless otherwise specified)
PARAMETER
Symbol
Unit
Conditions
Peak Forward Voltage
VFM
V
I F =5.0A
Peak Reverse Current
IRRM
μA
GS5/S5
A
B
D
G
1.15
VR =VDC @Ta=25℃
10
VR =VDC @Ta=125℃
250
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2021-11-29
Page:1
■ Characteristics(Typical)
FIG.2: Forward Surge Current Capability
IFSM(A)
IO(A)
FIG.1: Io-Ta Curve
7.0
1000
6.0
8.3ms Single Half Sine Wave
5.0
4.0
100
3.0
2.0
Resistive or Inductive Load
P.C.B. Mounted on 0.3"×0.3"
(8.0mm×8.0mm)Copper Pad Areas
70
90
110
IF(A)
FIG.3: Forward
130
10
150
TL(℃)
Voltage
IR(uA)
1.0
100
TJ=25℃
Pulse width=300us
1% Duty Cycle
1
10
100
Number of Cycles
FIG.4: Typical Reverse Characteristics
100
10
Tj=125℃
10
1.0
1.0
0.1
Tj=25℃
0.01
0.6
0.1
0.8
1.0
1.2
1.4
1.5
VF(V)
Revised: 2021-11-29
60
80
100
Voltage(%)
Page:2
■ Ordering Information (Example)
PREFERED
GS5A THRU GS5M
(S5A THRU S5M)
PACKAGE CODE
MINIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
OUTER CARTON
QUANTITY(pcs)
DELIVERY MODE
SMC
3000
6000
42000
13” reel
■ Outline Dimensions
DO-214AB(SMC)
.129(3.27)
.112(2.85)
Mounting Pad Layout
.245(6.22)
.220(5.59)
0.151
(3.84)
.280(7.11)
.260(6.60)
0.150
(3.82)
.103(2.61)
.078(1.99)
.010 (0.25)
.0
(0.00)
.060(1.52)
.030(0.76)
.320(8.13)
.305(7.75)
.012(0.31)
.006(0.15)
0.119(3.03)
0.390
(9.90)
Dimensions in inches and (millimeters)
Revised: 2021-11-29
Page:3
很抱歉,暂时无法提供与“GS5M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.81198
- 50+0.68435
- 150+0.62043
- 500+0.57261
- 3000+0.51300
- 6000+0.49382
- 国内价格
- 1+0.61930
- 200+0.42790
- 1500+0.38830
- 3000+0.36300
