Metal Oxide Varistors
10D Series
Features
l Wide operating voltage (V1mA) range from 18V to
1800V
l Fast responding to transient over-voltage.
l Large absorbing transient energy capability.
l Low clamping ratio and no following-on current.
General Information
l Surge protection in consumer electronics
General Characteristics
l Surge protection in industrial electronics
l Relay and electromagnetic valve surge absorption
l Body: Nickel Plated
l Transistor, diode, IC, thyristor or triac semiconductor
l Devices with No Leads: Nickel Plated
l Operating Temperature: -40ºC to +85ºC
protection
l Surge protection in electronic home appliances, gas
l Storage Temperature: -40 ºC to +125ºC
and petroleum appliances
l Axial Devices: Tin Plated
Part Number Code
1
Element Diameter
D
4
7
1
K
J
Type
Nominal Varistor Voltage
Surge Series
D:Disk
471=47*101V
No Suffix:Standard
Type
Varistor Voltage
Tolerance
J:High Surge Type
K = ±10 %
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2018-07-17
Page:1
10D Series
Electrical Characteristics
Type Number
Varistor
Voltage
Max. Allowable
Voltage
Max. Energy
(2ms)
VAC(V) VDC(V)
(J)
(J)
Standard High Surge
Standard
High
Surge
V1mA(V)
10D180K
16~20
11
14
1.6
10D220K
20~24
14
18
10D270K
24~30
17
10D330K
30~36
10D390K
10D470K
Max. Clamping
Voltage
(8/20μs)
Withstanding Surge
Current(8/20μs)
I(A)
I(A)
Standard High Surge
IP(A)
VC(V)
5
38
500
2.0
5
43
22
2.4
5
3.0
35~43
25
31
3.5
42~52
30
38
10D560K
50~62
35
45
10D680K
61~75
40
10D820K
10D820KJ
74~90
50
10D101K
10D101KJ
90~110
10D121K
10D121KJ
10D151K
Typical
Rated
Capacitance
Power
(Reference)
(W)
@1KHz(pf)
0.05
7500
500
0.05
6000
53
500
0.05
4800
5
65
500
0.05
4200
5
77
500
0.05
3700
4.2
5
93
500
0.05
3300
5.0
5
110
500
0.05
2900
56
6.1
5
135
500
0.05
2500
65
7.4
9.2
25
135
2500
3500
0.4
2100
60
85
9.0
11.3
25
165
2500
3500
0.4
1700
108~132
75
100
10.8
13.5
25
200
2500
3500
0.4
1500
10D151KJ
135~165
95
125
13.5
16.9
25
250
2500
3500
0.4
1300
10D181K
10D181KJ
162~198
115
150
16.2
20.3
25
300
2500
3500
0.4
470
10D201K
10D201KJ
180~220
130
170
18.0
22.5
25
340
2500
3500
0.4
430
10D221K
10D221KJ
198~242
140
180
19.8
24.8
25
360
2500
3500
0.4
390
10D241K
10D241KJ
216~264
150
200
21.6
27.0
25
395
2500
3500
0.4
360
10D271K
10D271KJ
243~297
175
225
24.3
30.4
25
455
2500
3500
0.4
330
10D301K
10D301KJ
270~330
195
250
27.0
33.8
25
505
2500
3500
0.4
290
10D331K
10D331KJ
297~363
210
275
29.7
37.1
25
550
2500
3500
0.4
280
10D361K
10D361KJ
324~396
230
300
32.4
40.5
25
595
2500
3500
0.4
260
10D391K
10D391KJ
351~429
250
320
35.1
43.9
25
650
2500
3500
0.4
240
10D431K
10D431KJ
387~473
275
350
38.7
48.4
25
710
2500
3500
0.4
220
10D471K
10D471KJ
423~517
300
385
42.3
52.9
25
775
2500
3500
0.4
190
10D511K
10D511KJ
459~561
320
418
42.3
52.9
25
845
2500
3500
0.4
180
10D561K
10D561KJ
504~616
350
460
42.3
52.9
25
920
2500
3500
0.4
180
10D621K
10D621KJ
558~682
385
505
42.3
52.9
25
1025
2500
3500
0.4
160
10D681K
10D681KJ
612~748
420
560
42.3
52.9
25
1120
2500
3500
0.4
140
10D751K
10D751KJ
675~825
460
615
42.3
52.9
25
1240
2500
3500
0.4
130
10D781K
10D781KJ
702~858
485
640
42.3
52.9
25
1290
2500
3500
0.4
130
10D821K
10D821KJ
738~902
510
670
44.3
55.4
25
1355
2500
3500
0.4
130
10D911K
10D911KJ
819~1001
550
745
49.1
61.4
25
1500
2500
3500
0.4
120
10D951K
10D951KJ
855~1045
580
780
51.3
64.1
25
1570
2500
3500
0.4
110
10D102K
10D102KJ
900~1100
625
825
54.0
67.5
25
1650
2500
3500
0.4
100
10D112K
10D112KJ
990~1210
680
895
59.4
74.3
25
1815
2500
3500
0.4
90
10D122K
10D122KJ
1080~1320
750
990
90.0
95.0
25
1980
2500
3500
0.4
85
10D152K
10D152KJ
1350~1650
900
1220
80.0
100.0
25
2475
2500
3500
0.4
80
10D182K
10D182KJ
1620~1980
1000
1465
97.2
121.5
25
2970
2500
3500
0.4
60
Note: The energy (10/1000μs) is about 1.4 times of energy(2ms)
Revised: 2018-07-17
Page:2
10D Series
Electrical Ratings
Items
Test Condition/Description
Requirement
Varistor Voltage
The voltage between two terminals with the specified measuring current 1mA.DC applied is called
Vb.
Maximum Allowable
Voltage
The recommended maximum sine wave voltage (RMS) or the Maximum DC voltage can be
applied continuously.
The maximum voltage between two terminals with the specification standard impulse current.
Applied waveform: 8/20μs
I
1.0
0.9
Maximum Clamping
Voltage
B
0.5
T2
0.1
0.0
To meet the
Specified value
C
O1
T
t
30% max.
T1
T1=1.25*T=8μs±20%
T2=20μs±20%
Rated Wattage
The maximum average power that can be applied within the specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when one impulse of 10/1000μs
or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10% with the standard impulse
current (8/20μs) applied one time.
The change of Vb shall be measured after the impulse listed below which is applied 10,000 times
continuously with the interval of ten seconds at room temperature.
Surge Life
180K to 680K
50A (8/20μs)
820K to 112K
100A (8/20μs)
10Φ series
Revised: 2018-07-17
ΔVb
≤ ±10%
Vb
Page:3
10D Series
Soldering Recommendation
Wave Lead Free Soldering Recommendation
Item
Conditions
Peak Temperature
265ºC
Dipping Time
10 seconds (max.)
Soldering
1 time
300
Preheating
Soldering
Maximum Wave 265°C
Cooling
Temperature(°C)
250
200
150
100
50
1
1.5
2
2.5
Time(minutes)
3
3.5
4
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360ºC (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Dimensions
TABLE 1
Symbol
Millimeters
Inches
H(max)
15.0
0.591
L(min)
15.0
0.591
D(max)
12.0
0.472
D1(±1.0)
7.5
0.295
T(max)
TABLE 2
d(±0.1)
0.8
0.031
Packaging Quantity: 500pcs/bag
TABLE 2---T(max.)
Model
Millimeters
Inches
Model
Millimeters
Inches
180K~390K
6.5
0.256
431K~561K
9.0
0.354
470K~680K
7.0
0.276
621K~781K
9.5
0.374
820K~151K
7.5
0.295
821K~122K
10.0
0.394
181K~271K
8.0
0.315
152K
10.5
0.413
331K~391K
8.5
0.335
182K
11.0
0.433
Revised: 2018-07-17
Page:4
很抱歉,暂时无法提供与“10D301K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.49443
- 100+0.39086
- 500+0.33902
- 1000+0.30024
- 5000+0.26914
- 10000+0.25359
