2R470TK-8
2R470TK-8
    RUILON(瑞隆源)
    插件,8x6mm
    470V 2端 GDT
2R470TK-8 数据手册
Switching Spark Gaps (SSG) 2RK-8 Series Description The principle of gas discharge is used not only for overvoltage protection but also in switching applications. Unlike surge arresters, switching spark gaps are active components that work reliably even after igniting hundreds of thousands of times. RUILON 2RK-8 series Switching Spark Gaps(SSG) can be used in all applications where high voltage pulses are generated, for example to ignite modern high-pressure gas discharge lamps such as xenon lamps in automotive headlights. Ignition performance is determined to a large degree by the properties of the switching component. An extremely fast switch is called for, which operates virtually without loss and with high insulation resistance in the non-conducting state. It should also be as compact as possible, rugged, highly reliable, and capable of operating over a wide temperature range. Features Applications l Extremely long life time l Igniters for architectural and automotive Xenon l Stable performance over life discharge lamps l Insensitive performance against variations in temperature l Electronic igniters for gas heating and gas domestic l Low switching losses appliances, e.g., cookers l Very short breakdown time l Ignition of ultra-high pressure gas discharge lamps for l High reliability by robust design data and video projectors l Lead-free and RoHS compliant l Non-Radioactive Part Number Code 2 R Electrode Numbers 2R: 2 Electrodes x x x x K - 8 K: Switching DC Spark-over Voltage Spark Gaps Lead Type T: Lead S: SMD Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2017-04-25 Product Series Size: Ф8mm*6mm Page:1 Switching Spark Gaps (SSG) 2RK-8 Series Electrical Characteristics Part Number DIP 2R230TK-8 2R250TK-8 2R300TK-8 2R350TK-8 2R380TK-8 3) SMD 2R230SK-8 2R250SK-8 2R300SK-8 2R350SK-8 2R380SK-8 3)
