0819-0012
0819-0012
    ENERSYS(艾诺斯)
    BATTERY LEAD ACID 6V 2.5AH
0819-0012 数据手册
Cyclon Cells and Monoblocs The Cyclon cells and monoblocs offer versatility of using 2 Volt building blocks to satisfy standard industrial and standby applications through to the most demanding requirements, where extreme performance in harsh environments is necessary. DMS technologies can also provide a custom build solution for you from product selection, through to design and finally to manufacture, using Cyclon batteries. Main Benefits Exceptional High Rate performance (up to 26C) Operating temperature range: Cells: -65ºC to +80ºC Monoblocs: -40ºC to +40ºC High shock and vibration resistance Cycle Life - up to 3000 cycles at 30% DOD Float Life: Cells- 15 years at 20ºC Monoblocs - 10 years at 20ºC Storage Life greater than 2 years at 25ºC, from full state of charge Recharge to 95% capacity in under 1 hour Typical Applications Telecommunications - Railways - Industrial - Offshore - Utilities - Medical - Garden Equipment - Switch Tripping Technical Specifications for 2Volt Single Cells at 25ºC DMS Part Number Cell Type Volts Nominal (Ah) Capacity (10hr rate to 1.67VPC) Dimensions mm Weight kg Tabs mm Diameter Height Height over tabs 9810-0004 D cell (2.5Ah) 2 2.5 34 61 68 0.2 4.75 x 0.64 9860-0004 Tall D cell (4.5Ah) 2 4.5 34 96 103 0.3 4.74 x 0.64 9800-0004 X cell (5.0Ah) 2 5.0 44 73 82 0.4 6.35 x 0.64 9850-0004 E cell (8Ah) 2 8.0 44 100 109 0.6 6.35 x 0.64 9840-0004 J cell (12.5Ah) 2 12.5 52 123 136 0.8 7.92 x 0.81 9820-0004 BC cell (25Ah) 2 25.0 65 159 174 1.7 M8+ M6 -studs Discharge Characteristics DMS Part Number Cyclon Type Pulse Amps Continuous Amps 9810-0004 D Single Cell (2V, 2.5Ah) 200 65 9819-0012 D Monobloc (6V, 2.5Ah) 200 50 9860-0004 TD Single Cell (2V, 4.5Ah) 200 65 9800-0004 X Single Cell (2V, 5.0Ah) 285 65 9809-0012 X Monobloc (6V, 5.0Ah) 285 50 9850-0004 E Single Cell (2V, 8.0Ah) 330 65 9859-0012 E Monobloc (6V, 8.0Ah) 330 50 9840-0004 J Single Cell (2V, 12.5Ah) 400 65 9820-0004 BC Single Cell (2V, 25.0 Ah) 665 250 Cyclon Monoblocs and Battery Packs Standard Cyclon Monoblocs and Battery Packs (complete with leads and tags) are available in 4,6,8 and 12 Volt configurations. Please refer to the Cyclon Manual for further information. Other sizes are available dependant on specification requirements. Engineering Tip: When sizing your battery requirements, consider the exceptional power/weight ratio of Cyclon which is significantly better than comparable sealed lead acid and nickel cadmium batteries.
0819-0012 价格&库存
很抱歉,暂时无法提供与“0819-0012”相匹配的价格&库存,您可以联系我们找货
    • 1+1883.357841+242.96868
    • 5+968.726745+124.97373
    • 10+823.7293710+106.26788
    库存:30
