100A1R5CW150X
100A1R5CW150X
    ATC
    CAP_1.4X1.4MM_SM
    贴片电容(MLCC) CAP_1.4X1.4MM_SM
100A1R5CW150X 数据手册
ATC 100 A Series Porcelain Superchip ® Multilayer Capacitors • Case A Size (.055" x .055") • Capacitance Range 0.1 pF to 100 pF • High Q • Ultra-Stable Performance • Low ESR/ESL • High Self-Resonance • Low Noise • Established Reliability (QPL) • Extended WVDC up to 250 VDC ELECTRICAL AND MECHANICAL SPECIFICATIONS ATC, the industry leader, offers new improved ESR/ESL performance for the 100 A Series RF/Microwave Capacitors. This is ATC's most versatile high Q, high self resonant multilayer capacitor. High density porcelain construction provides a rugged, hermetic package. QUALITY FACTOR (Q): greater than 10,000 at 1 MHz. Typical functional applications: Bypass, Coupling, Tuning, Feedback, Impedance Matching and DC Blocking. 0.1 pF to 100 pF: 106 Megohms min. @ +25°C at rated WVDC. 105 Megohms min. @ +125°C at rated WVDC. Typical circuit applications: Microwave/RF/IF Amplifiers, Mixers, Oscillators, Low Noise Amplifiers, Filter Networks, Timing Circuits and Delay Lines. ENVIRONMENTAL TESTS ATC 100 A Series Capacitors are designed and manufactured to meet and exceed the requirements of EIA-198, MIL-PRF-55681 and MIL-PRF-123. THERMAL SHOCK: TEMPERATURE COEFFICIENT OF CAPACITANCE (TCC): +90 ±20 PPM/°C (-55°C to +125°C) INSULATION RESISTANCE (IR): WORKING VOLTAGE (WVDC): See Capacitance Values Table, page 2. DIELECTRIC WITHSTANDING VOLTAGE (DWV): 250% of rated WVDC for 5 secs. RETRACE: Less than ±(0.02% or 0.02 pF), whichever is greater. AGING EFFECTS: None MIL-STD-202, Method 107, Condition A. PIEZOELECTRIC EFFECTS: None (No capacitance variation with voltage or pressure). MOISTURE RESISTANCE: CAPACITANCE DRIFT: ±(0.02% or 0.02 pF), whichever is MIL-STD-202, Method 106. LOW VOLTAGE HUMIDITY: MIL-STD-202, Method 103, Condition A, with 1.5 Volts DC applied while subjected to an environment of 85°C with 85% relative humidity for 240 hours min. LIFE TEST: MIL-STD-202, Method 108, for 2000 hours, at 125°C. 200% WVDC applied. greater. OPERATING TEMPERATURE RANGE: From -55°C to +125°C (No derating of working voltage). TERMINATION STYLES: Available in various surface mount styles. See Mechanical Configurations, page 3. TERMINAL STRENGTH: Terminations for chips and pellets withstand a pull of 5 lbs. min., 10 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Test per MIL-STD-202, method 211. ATC # 001-806 Rev. M 9/14 ATC 100 A Capacitance Values B, C 150 250 B, C, D B, C, D 150 250 B, C, J, K, M F, G, J, K, M CAP. (pF) 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 TOL. RATED WVDC STD. EXT. VOLTAGE 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 CAP. CODE 250 F, G, J, K, M 150 F, G, J, K, M EXTENDED 2R2 2R4 2R7 3R0 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 B RATED WVDC STD. EXT. TOL. VOLT CAP. (pF) 200 EXT CAP. CODE EXTENDED VOLTAGE 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 RATED WVDC STD. EXT. EXTENDED VOLTAGE 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 TOL. EXTENDED VOLTAGE CAP. (pF) EXTENDED VOLTAGE CAP. CODE VRMS = 0.707 X WVDC SPECIAL VALUES, TOLERANCES, HIGHER WVDC AND MATCHING AVAILABLE. PLEASE CONSULT FACTORY. NOTE: EXTENDED WVDC DOES NOT APPLY TO CDR PRODUCTS. CAPACITANCE TOLERANCE Code B C D F J G K M Tol. ±0.1 pF ±0.25 pF ±0.5 pF ±1% ±2% ±5% ±10% ±20% ATC PART NUMBER CODE ATC100 A 10 0 J W 150 X T Packaging T - Tape and Reel, 1000 pc. qty.* TV - Vertical Orientation of Product, Tape and Reel, 1000 pc. qty.* I - Special Packaging. Consult Factory. *Consult ATC for other quantities Series Case Size Capacitance Code: First 2 significant digits for capacitance. R=Decimal Point Indicates number of zeros following digits of capacitance in picofarads except for decimal values. ATC Cap-Pac® packaging (100 pc. qty. std.) is also available. For this option, leave last field blank. Capacitance Tolerance Laser Marking Termination Code WVDC The above part number refers to a 100 A Series (case size A) 10 pF capacitor, J tolerance (±5%), 150 WVDC, with W termination (Tin / Lead, Solder Plated over Nickel Barrier), laser marking and ATC Tape and Reel packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. A M E R I C A N 2 ATC North America sales@atceramics.com For additional information and catalogs contact your ATC representative or call direct at (+1-631) 622-4700. Consult factory for additional performance data. T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.at c er am ic s .c om ATC 100 A Capacitors: Mechanical Configurations ATC ATC SERIES MIL-PRFTERM. & CASE 55681 CODE SIZE BODY DIMENSIONS INCHES (mm) OUTLINES CASE SIZE & TYPE W/T IS A TERMINATION SURFACE Y 100A W CDR12BG A W Solder Plate T L Y 100A P CDR12BG A W Pellet T L Y 100A T N/A A Solderable Nickel Barrier W T L Y 100A CA CDR11BG A Gold Chip W L T LENGTH (L) WIDTH (W) LEAD AND TERMINATION DIMENSIONS AND MATERIALS THICKNESS (T) OVERLAP (Y) MATERIALS .055 +.015 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.38 -0.25) .057 (1.45) max. .010 Tin / Lead, Solder Plated +.010 -.005 over (0.25 Nickel Barrier Termination +0.25 -0.13) .055 +.025 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.64 -0.25) .057 (1.45) max. .010 Heavy Tin/ Lead Coated, +.010 -.005 over (0.25 Nickel Barrier Termination +0.25 -0.13) .055 +.015 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.38 -0.25) .057 (1.45) max. .010 RoHS Compliant +.010 -.005 Tin Plated over (0.25 +0.25 -0.13) Nickel Barrier Termination .055 +.015 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.38 -0.25) .057 (1.45) max. .010 RoHS Compliant +.010 -.005 Gold Plated over (0.25 +0.25 -0.13) Nickel Barrier Termination For a complete military catalog, request American Technical Ceramics document ATC 001-818. A M E R I C A N 3 ATC North America sales@atceramics.com T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.at c er am ic s .c om ATC 100 A Non-Magnetic Capacitors: Mechanical Configurations ATC ATC SERIES MIL-PRFTERM. & CASE 55681 CODE SIZE 100A 100A 100A WN PN TN Meets Requirements Meets Requirements Meets Requirements BODY DIMENSIONS INCHES (mm) OUTLINES CASE SIZE & TYPE W/T IS A TERMINATION SURFACE Y A W Non-Mag Solder Plate T L Y A W Non-Mag Pellet A Non-Mag Solderable Barrier T L Y W L T LENGTH (L) WIDTH (W) LEAD AND TERMINATION DIMENSIONS AND MATERIALS THICKNESS (T) OVERLAP (Y) MATERIALS .055 +.025 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.64 -0.25) .057 (1.45) max. .010 +.010 -.005 (0.25 +0.25 -0.13) Tin/ Lead, Solder Plated over Non-Magnetic Barrier Termination .055 +.035 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.89 -0.25) .057 (1.45) max. .010 +.010 -.005 (0.25 +0.25 -0.13) Heavy Tin / Lead Coated, over Non-Magnetic Barrier Termination .055 +.025 -.010 .055 ±.015 (1.40 (1.40 ±0.38) +0.64 -0.25) .057 (1.45) max. .010 +.010 -.005 (0.25 +0.25 -0.13) RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination All 100 A Capacitors are available laser marked with ATC's identification, capacitance code and tolerance. Suggested Mounting Pad Dimensions Dimensions are in inches. A M E R I C A N 4 ATC North America sales@atceramics.com T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.a tcer am ic s .c om ATC 100 A Performance Data ESR VS. CAPACITANCE ATC SERIES 100, CASE A 10000 0.1 1000 500 MHz 150 MHz 0.01 1 (Typical) 10 CAPACITANCE (pF) 10 100 1 10 100 CAPACITANCE (pF) SERIES RESONANCE VS. CAPACITANCE ATC SERIES 100, CASE A CURRENT RATING VS. CAPACITANCE ATC SERIES 100, CASE A 10 1 0.1 1000 MHz (Typical) 10 0.1 500 MHz 100 RMS CURRENT (Amps) 100 FREQUENCY (GHz) 150 MHz 1000 MHz Q ESR (Ohms) 1 Q VS. CAPACITANCE ATC SERIES 100, CASE A 1 (Typical) 10 The current rating is based on a 65°C mounting surface and a device thermal resistance of 40°C/W. A power dissipation of 1.5 W will result in a case temperature of 125°C. 1000 MHz 150 MHz 500 MHz 1 Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 100 0.1 0.1 1 C CAPACITANCE (pF) 10 CAPACITANCE (pF) CAPACITANCE CHANGE VS. TEMPERATURE ATC SERIES 100, CASE A 1.2 TC= +90 ± 20 PPM/°C % CHANGE IN CAPACITANCE 1 0.8 0.6 0.4 0.2 0 -0.2 -0.4 -0.6 -0.8 -1 -55 -35 -15 5 25 45 65 85 105 125 TEMPERATURE (Degrees C) A M E R I C A N ATC North America sales@atceramics.com 5 T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com w w w.at c er am ic s .c om 100 ATC 100 A Performance Data CURRENT RATING VS. CAPACITANCE ATC SERIES 100, CASE A, EXTENDED VOLTAGE 10 o The current rating is based on a 65°C mounting o surface and a device thermal resistance of o 40°C/W. A power dissipationCof 1.5 W will result in a case temperature of 125°C. 1000 MHz 500 MHz RMS CURRENT (Amps) RMS CURRENT (Amps) 10 CURRENT RATING VS. CAPACITANCE ATC SERIES 100, CASE A, EXTENDED VOLTAGE 150 MHz 1 (Typical) 0.1 0.1 Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 1 10 CAPACITANCE (1 TO 56 pF) 100 The current rating is based on a 65°C mounting surface and a device thermal resistance of 40°C/W. A power dissipation of 1.5 W will result in a case temperature of 125°C. 150 MHz 500 MHz 1000 MHz 1 (Typical) Dotted line = Power dissipation limited 0.1 10 100 CAPACITANCE (62 TO 100 pF) Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. B 12/05). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC's website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product without prior notice. © 1996 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-806 Rev. M 9/14
100A1R5CW150X
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括最大正向电流150mA,最大反向电压5V,最小正向电压1.0V。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于数字通信、测量、自动控制等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1x4.4mm。
100A1R5CW150X 价格&库存
很抱歉,暂时无法提供与“100A1R5CW150X”相匹配的价格&库存,您可以联系我们找货
