118825
118825
    LUTZE
118825 数据手册
Technical data sheet · LÜTZE SUPERFLEX® N (C) PUR PUR C-track cable · For the highest requirements Subject to technical modification 118825 Identification Use/Area of application Application Properties Technical data Voltage Test voltage Type Part-No. (12×1.0) 118825 • Machine and device construction, transport and conveyor technology • Through full PUR jacket suited for c-tracks, extremely harsh operating conditions, aggressive coolants and lubricants • Special for industrial environments with interference potential, in machines, plant and device construction • Extreme space-saving design • Low capacitance, very good electrical properties • High active and passive interference resistance • Braided shield optimised for continuous flexible use • Halogen-free, no corrosive gases • Very good alternating bending strength • Low adhesion, abrasion-proof, nick-resistant, tear-propagation-resistant • Hydrolisis-resistant, microbe-resistant, and rot-resistant • Weathering, ozone and UV resistant (normal lighting conditions) • Good industrial- and salt water resistance • Excellent coolant and lubricant resistance • Widely resistant to oils, greases, alcohol-free benzines and kerosene • Free from paint wetting disruptive substances (LABS-free), RoHS-compliant U0/U 3000 V 300/500 V 10.05.2007 – Subject to technical modification Part-No. 118825 USA: LUTZE INC. 13330 South Ridge Drive • Charlotte, NC 28273, USA Tel. +1-704-504-02 22 • Fax +1-704-504-02 23 www.lutze.com • info@lutze.com United Kingdom: LÜTZE Ltd. Unit 4, Brabazon Court • Borman Lichfield Road Industrial Estate • GB-Tamworth, Staffordshire B79 7TA Tel. +44-18 27-3 13 33-0 • Fax +44-18 27-3 13 33-2 www.lutze.com • sales.gb@lutze.co.uk page 1 of 2 Technical data sheet · LÜTZE SUPERFLEX® N (C) PUR Isolation resistance Temperature range Minimum bending radius Halogen-free Number of strands/cross-section Outer-∅ Weight Cu-Index Design Conductor structure Conductor insulation Conductor labelling Ground conductor Stranding Banding Overall shield Outer jacket Jacket colour General data Note min. 100 MΩ × km moving fixed moving fixed according to DIN EN 20264 / EN 50267 / 60684 (12×1,0) 10.2 approx. mm 19.3 kg/100 m 16.7 kg/100 m -25 °C to +80 °C -40 °C to +80 °C Cable diameter × 12 Cable diameter × 6 Bare copper wire, finest multi-strand according to DIN VDE 0295 class 6, IEC 60228 class 6 Special-TPE conductor insulation Conductors black with white number print according to DIN EN 50334 green/yellow according to DIN EN 50334 in the top layer Conductors twisted without mechanical stress, layer pitch optimised Non-woven material over stranded cable Meshwork shielding from galvanised Cu wire, optical covering ≥ 85 %. Full polyurethane jacket, matt, adhesion-free surface grey RAL 7001 CE These products are in conformity to the EC Low Voltage Directive73/23/EWG or 93/ 68/EWG respectively Logo 10.05.2007 – Subject to technical modification Part-No. 118825 USA: LUTZE INC. 13330 South Ridge Drive • Charlotte, NC 28273, USA Tel. +1-704-504-02 22 • Fax +1-704-504-02 23 www.lutze.com • info@lutze.com United Kingdom: LÜTZE Ltd. Unit 4, Brabazon Court • Borman Lichfield Road Industrial Estate • GB-Tamworth, Staffordshire B79 7TA Tel. +44-18 27-3 13 33-0 • Fax +44-18 27-3 13 33-2 www.lutze.com • sales.gb@lutze.co.uk page 2 of 2
118825 价格&库存
很抱歉,暂时无法提供与“118825”相匹配的价格&库存,您可以联系我们找货
