111000
111000
    LUTZE
    LUTZE - 111000 - CABLE, SUPERFLEX, 7X1MM, 25M
111000 数据手册
Technical data sheet · LÜTZE SUPERFLEX® N PUR PUR C-track cable · For the highest requirements Subject to technical modification 111000 Identification Use/Area of application Application Properties Technical data Voltage Test voltage Insulation resistance Temperature range Type Part-No. 7×1.0 111000 • Machine and device construction, transport and conveyor technology • Through full PUR jacket suited for c-tracks, extremely harsh operating conditions, aggressive coolants and lubricants • Special for industrial environments, machines and plants • Extreme space-saving design • Low capacitance, very good electrical properties • Halogen-free, no corrosive gases • Very good alternating bending strength • Low adhesion, abrasion-proof, nick-resistant, tear-propagation-resistant • hydrolisis-resistant, microbe-resistant, and rot-resistant • Weathering, ozone and UV resistant (normal lighting conditions • Good industrial- and salt water resistance • Excellent coolant and lubricant resistance • Widely resistant to oils, greases, alcohol-free benzines and kerosene • Free from paint wetting disruptive substances (LABS-free), RoHS-compliant U0/U 3000 V min. 100 MΩ × km moving 300/500 V -25 °C to +80 °C 23.11.2007 – Subject to technical modification Part-No. 111000 USA: LUTZE INC. 13330 South Ridge Drive • Charlotte, NC 28273 Tel.: +1 (704) 504-0222 • Fax: +1 (704) 504-0223 www.lutze.com • info@lutze.com United Kingdom: LÜTZE Ltd. Unit 3 Sandy Hill Park Sandy Way, Amington • GB-Tamworth, Staffs, B77 4DU Tel.: +44 (0)1827 31333-0 • Fax: +44 (0)1827 31333-2 www.lutze.com • sales.gb@lutze.co.uk page 1 of 2 Technical data sheet · LÜTZE SUPERFLEX® N PUR Minimum bending radius Halogen-free Number of strands/cross-section Outer-∅ Weight Cu-Index Design Conductor structure Conductor insulation Conductor labelling Ground conductor Stranding Banding Outer jacket Jacket colour General Note fixed moving fixed according to DIN EN 50264-1; EN 50267-2-1; EN 60684-2 7×1,0 7.3 approx. mm 9.3 kg/100 m 6.9 kg/100 m -40 °C to +80 °C Cable diameter × 10 Cable diameter × 4 Bare copper wire, finest multi-strand according to DIN VDE 0295 class 6, IEC 60228 class 6 Special-TPE conductor insulation Conductors black with white number print according to DIN EN 50334 green/yellow according to DIN EN 50334 in the top layer Conductors twisted without mechanical stress, layer pitch optimised Non-woven material over stranded cable Full polyurethane jacket, matt, adhesion-free surface grey RAL 7001 CE These products are in conformity to the EC Low Voltage Directive73/23/EWG or 93/ 68/EWG respectively Logo 23.11.2007 – Subject to technical modification Part-No. 111000 USA: LUTZE INC. 13330 South Ridge Drive • Charlotte, NC 28273 Tel.: +1 (704) 504-0222 • Fax: +1 (704) 504-0223 www.lutze.com • info@lutze.com United Kingdom: LÜTZE Ltd. Unit 3 Sandy Hill Park Sandy Way, Amington • GB-Tamworth, Staffs, B77 4DU Tel.: +44 (0)1827 31333-0 • Fax: +44 (0)1827 31333-2 www.lutze.com • sales.gb@lutze.co.uk page 2 of 2
111000 价格&库存
很抱歉,暂时无法提供与“111000”相匹配的价格&库存,您可以联系我们找货
相关技术文章
